Validation of existing equipment - I have been asked to write a quality assessment for equipment
duff999
I have been asked to write a quality assessment for equipment that has already been installed to be used as an assessment against no IQ performed, Also I have asked to perform an assessment of the PQ that has not been performed, any good advice on where to start. This is for an existing very small manufacturer who is in the process of getting ISO 13485 accreditation.
yodon
I personally would start by ensuring that everyone knew that being a small company doesn't earn them any exemptions. :)
Seriously, I would start with a master validation plan and establish a risk-based approach. I personally wouldn't buy into the "just because we haven't seed anything bad so it must all be good" approach. Maybe you can leverage data collected to date to help scope / frame a validation but not as a substitute.
You can then compile an inventory of equipment and use, apply your risk-based criteria, and develop your plans. FMEAs can be helpful in understanding risk.
If you've been producing product with unqualified equipment / processes that should have been validated but weren't, I'd recommend you start building the case (documented) why the product released under those conditions don't pose a safety threat and meet all efficacy claims.
Bob Jenkins
For reference information on IQ, OQ and PQ I included an FDA presentation and what appears to still be regarded as the "go to" reference for IQ, OQ, PQ validation (even 15 years later).
Having a Master Validation Plan written out is the best first step.
Bob Jenkins
MedAccred Certified Pre-assessment SME/Auditor/ ISO 13485 Lead Auditor
duff999
How would I determine WHAT equipment requires validation. Is it safe to say any piece in the production/manufacturing process needs to be validated. What if the piece of equipment does not affect any workflow, production, etc
yodon
This is why I endorse a a master plan with risk-based criteria for decision-making coupled with an inventory list of equipment with the risk criteria applied. That enables you to document decisions based on a solid foundation.
(Maybe semantics but equipment is qualified and processes are validated.)
Using reasonable risk-based criteria, equipment not used in workflow or production would not require any qualification (no risk of failure).
Processes are a bit different. Any process whose output is not 100% verified is subject to validation. Again, use risk-based criteria to justify the level of validation (or lack of validation).
duff999
Thank you, that is good information. I will incorporate those thoughts into the master validation plan. I am struggling because the equipment is already installed but we are now wanting to get ISO 13485 certified so I am trying to come up with justification on why there is no need to validate based on our 100% inspection that is in place for products produced. If I dont have to worry about the equipment that is not used in production that makes it somewht easier to figure out, the process validation is for another time. Any more tips are appreciated.
yodon
A good tip: stay active here in the Cove! :) Good luck. Do post questions if you hit any potholes along the way.
duff999
Thanks, I think I just need that push at the start and I can go from there, searching for examples how to get started
duff999
Could you give me a risk based approach example. For example, we have a number of equipment that was just calibrated, I would assign a low risk to these because they were just calibrated are in working order. For larger pieces equipment, such as a 3D printer that is used for the main production, it has not been validated but we do have 100% inspection on the final product through QC, what type of risk assesment do you assign to this and what is the rationale?
Thank you
yodon
Calibration is just calibration - either calibrated or not - so there's no need for a risk-based approach.
You only need to validate if the outputs aren't 100% verified so you could argue that the 3D printing process need not be validated. On the flip side of that, though, is that you're only verifying dimensional aspects, I expect. Are there any requirements that can't be verified like hardness, strength, etc?
You would still likely want to qualify the equipment to ensure it's properly installed, proper PM is defined, etc.
Risk, per 13485, "pertains to safety or performance requirements of the medical device or meeting applicable regulatory requirements" so your risk classifications would be (worst case) death then go down from there. So if a process could introduce something that would cause harm, that gets the higher levels of validation. Sterilization is a good example of a process that requires the most vigorous validation. A misprinted label may not result in harm (maybe!!) but would certainly be a regulatory nonconformity. You have to determine, based on the risk, where that failure would fall on the risk scale.
D Validation of existing equipment - Risk based approach example ISO 13485:2016 - Medical Device Quality Management Systems 3
X Existing Toolroom Process Validation - Need to identify clauses addressed. Manufacturing and Related Processes 7
B Validation of IVD - Existing Product produced with New Machine ISO 13485:2016 - Medical Device Quality Management Systems 6
E Validation master plan - Existing cleanroom facility that will be upgraded ISO 13485:2016 - Medical Device Quality Management Systems 11
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 2
C Spreadsheet Validation and Release Qualification and Validation (including 21 CFR Part 11) 2
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
M Sterile packing validation tests to be performed and protocol Other Medical Device and Orthopedic Related Topics 1
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
C ISO 19227 Validation Cost Other Medical Device Related Standards 2
A CNC Mill and Lathe - Validation Manufacturing and Related Processes 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
B Oracle Cloud ERP Validation during Quarterly Patch ISO 13485:2016 - Medical Device Quality Management Systems 1
D Software validation team Misc. Quality Assurance and Business Systems Related Topics 3
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 3
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R PCBA process validation Qualification and Validation (including 21 CFR Part 11) 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
B Sterilization Validation Plan Other Medical Device Related Standards 3
T Laboratory Verification after validation ISO 17025 related Discussions 3
silentmonkey Rationalising the level of effort and depth of software validation based on risk ISO 13485:2016 - Medical Device Quality Management Systems 10
D Questions regarding process validation ISO 13485:2016 - Medical Device Quality Management Systems 6
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 3
A Validation of Forced Aeration Process ISO 13485:2016 - Medical Device Quality Management Systems 3
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
I ISO 2233:2000 Question - Medical Device Shipping/Transportation Validation Other ISO and International Standards and European Regulations 1
B TMV - Selection of TM's for Validation ISO 13485:2016 - Medical Device Quality Management Systems 5
S Forced ServiceNow validation - No change in our current user and functional requirements IT (Information Technology) Service Management 4
P Human Factors / Usability validation in the time of COVID Human Factors and Ergonomics in Engineering 17
C Template for Excel Validation Reliability Analysis - Predictions, Testing and Standards 6
M IT validation for a paper based MD repair company QMS ISO 13485:2016 - Medical Device Quality Management Systems 6
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 39
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
M Is Validation of Plating Processes required and who is responsible? Qualification and Validation (including 21 CFR Part 11) 11
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Rees System Validation Qualification and Validation (including 21 CFR Part 11) 1
