Validation of process for releasing the UDI
Cybel
my NB asked for the validation of the process for releasing the UDI.
We have a SOP describing how the UDI is assigned and a spreadsheet containing the list of the UDI-DI for each device and configuration. In the same spreadsheet we register the UDI-PI each time. (We are a small company with not so many UDI-DI, but with a number of UDI-PI. We manufacture low risk class IIa devices, a mistake in the UDI may result in a logistic/regulatory issue - no harms to patients/users).
The UDI-DI is indicated in the DMR, while the UDI-PI is defined by the production dep. according to LOT number, manufacturing date, and so on and reviewed. The production dep. has a program for printing the UDI, in the format of GS1 data-matrix, on the stickers that are applied on each device. Finally, GS1 data-matrix codes printed on the stickers are checked by sample with a barcode verifier (verification).
How would you validate this process (= confirm that the data content within a barcode is correct) ?
Thank you for any input you can give me!
Billy Milly
From what you describe, it seems easy ;) Document the chain you described (assigned unique number, transferred to labelling SW, printed, verified) in form of a protocol, then add proof - printscreens, pictures, spreadsheet...
Show evidence that spreadsheet cannot be changed after PIs are recorded.
Side note - have another look at risks. In my opinion, mistake in UDI can trigger the use of unsuitable device, if the whole chain up to the end user reiles on it (which is the long-term intention of UDI) or inadequate reporting on adverse events - just a few.
Cybel
Thank you Billy Milly.
This sounds similar to the documented information recorded in the DHR and production reports, isn't it?
This is the improvement I have thought to. I'm wondering if the spreadsheet validation would satisfy the NB, considering that I think the rest is already implemented in DHR and production reports.
Thank you very much for these inputs!
andrei iuganu
If you can think that you could give us an example of what your SOP looks like? thx in advance
Cybel
basically my SOP is structured as follows:
- purpose of the procedure
- reference documents (regulations, guidances)
- responsibilities
- definitions (UDI, DI, PI, EUDAMED, BASIC UDI-DI, GMN. I’ve included the GUDID as well, as per the requirement USA FDA)
- management of the UDI codes:
a) definition of the BASIC UDI-DI
b) definition of the UDI-DI
c) definition of the UDI-PI
d) operative process (how the code is chosen, for example between GS1 vs datamatrix, how it is generated, program used, printing, verification methods, records to be produced)
e) registrations required (EUDAMED - GUDID)
f) specific cases and direct marking
This is mine, but this may not be good for other companies…
Hope it helps.
B SPECIAL PROCESS VALIDATION & REVALIDATION Qualification and Validation (including 21 CFR Part 11) 4
B How to satisfy clause 5.7.1.5 process validation for valve production API 6D Oil and Gas Industry Standards and Regulations 13
Melissa Process Validation of Rotary Heat Sealer Speeds Design and Development of Products and Processes 4
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
mustomutlu Process Validation Final Report Other Medical Device and Orthopedic Related Topics 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
R PCBA process validation Qualification and Validation (including 21 CFR Part 11) 2
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
D Questions regarding process validation ISO 13485:2016 - Medical Device Quality Management Systems 15
A Validation of Forced Aeration Process ISO 13485:2016 - Medical Device Quality Management Systems 3
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
G Devices from IQ, OQ or PQ process to be used for verification, validation and summative? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
E Equipment Qualification - IQ/OQ per ISO 13485:2016 section 7.5.6 Process validation ISO 13485:2016 - Medical Device Quality Management Systems 7
B API Q1 5.7.1.5 Process Validation - Machining, heat treating, Manganese Phosphate and Zinc Plating Manufacturing and Related Processes 2
N Validation procedure, Major NC CAP - Equipment Validation process is not effective ISO 13485:2016 - Medical Device Quality Management Systems 5
D ISO13485:2016 7.5.6 Process Validation Responsibilities ISO 13485:2016 - Medical Device Quality Management Systems 1
Z Who is responsible for writing the validation of a new process? Manufacturing and Related Processes 7
M Requirement for manufacturing process validation in IATF 16949 IATF 16949 - Automotive Quality Systems Standard 8
E Sampling plan for orthopedic implant - Process Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Z Class 2 medical device - Process Validation - Test sterile or non-sterile units? Qualification and Validation (including 21 CFR Part 11) 4
T ISO 13485:2016 - Processes exempt from process validation ISO 13485:2016 - Medical Device Quality Management Systems 12
L Injection Moulding Process (Special Process) Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
K Is Mold qualification / process validation always required? Manufacturing and Related Processes 7
R Process Validation on CNC Lathe and Milling machining process Design and Development of Products and Processes 1
Q Release of the first batch of a cleared product before process validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Process Validation sample size selection Statistical Analysis Tools, Techniques and SPC 0
P Auditing "process validation" process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
E Cleaning Validation Process of Non-Sterile Implants and Instruments Other Medical Device Related Standards 2
W Design and Process Validation - Different? ISO 13485:2016 - Medical Device Quality Management Systems 6
A Supplier - Process Validation Manufacturing and Related Processes 3
M Medical Device Process validation, Validation of excel spreadsheets used for process Other Medical Device and Orthopedic Related Topics 4
V Tyvek packaging for Medical device process validation Qualification and Validation (including 21 CFR Part 11) 2
L Process Definition and Process Validation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Can we sell units that were chosen for process validation? ISO 13485:2016 - Medical Device Quality Management Systems 6
S How do I do a Process Validation for soldering process Manufacturing and Related Processes 5
S Process validation when changing location ISO 13485:2016 - Medical Device Quality Management Systems 10
A Process Validation of QMS Software ISO 13485: 2016 Cl. 4.1.6 ISO 13485:2016 - Medical Device Quality Management Systems 26
P Root Cause for a Process Validation Batch Failure 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
GoSpeedRacer Validation of Processes 7.5.6 - Do cosmetic welds need process validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Is Aeration Process in ETO Sterilization Validation Required? Manufacturing and Related Processes 7
C Does Japan accept the Bracketing Approach for Process Validation Japan Medical Device Regulations 1
A Robotic Sanding and Painting Process Validation Manufacturing and Related Processes 5
alonFAI Gamma Irradiation Process Validation Help Other Medical Device Related Standards 2
J Where does process validation fit within design & development? Design and Development of Products and Processes 7
O Process Mapping prior to Validation and Software to use to Map Process Maps, Process Mapping and Turtle Diagrams 12
M Justification for Not Having a Validation Plan for a Critical Process ISO 13485:2016 - Medical Device Quality Management Systems 4
