Re: Handling 7.5.2 Validation of processes for production - How are doing it?
I think we are talking around the issue of the OP. Since you cannot directly measure a weld, you need to validate the process. How one validates the process is to perform the special process and destructively test the output and measure it. Based on the measurement (pass/fail or measurement), you can validate the process. If it is a manual process, then you have some training that must be verified for each operator before they can perform the special process. It is tedious and costly, but if the weld is considered critical, you need to validate the using certain settings and conditions, you will produce acceptable welds with high confidence.
Al Rosen said:
You can't verify a weld(strength) without destroying it, just like sterility in a medical device. That is why it's necessary to validate the process. When there is a manual element such as an operator, it is important to have a trained competent individual(read that certified).
