Validation of Processes - How do I address TS 16949 Sec. 7.5.2.1
krishkaar
While understanding the differences between Sec 7.5.2 (ISO 9001:2000) and 7.5.2.1(Supplemental, ISO/TS 16949:2002), how does one address the ISO/TS requiremenst?
Can somebody, please help.
Jen Kirley
Quality and Auditing Expert
Re: Sec. 7.5.2.1-Validation of procsses
My understanding of the supplemental is to over-ride the ISO 9000:2000 (7.5.2) phrase "where the resulting output cannot be verified by subsequent monitoring or measurement."
Anyone have a different view?
V
Valeri
Re: Validation of Procsses - How do I address TS 16949 Sec. 7.5.2.1
I agree with Jennifer, it overrides 7.5.2 to include all processes - automotive requires us to validate all processes.
krishkaar
The purpose o my query is to get a methodology for addressing the requirements of 7.5.2.1.
Any process map or procedures, please???
krishkaar
Is there somebody who is listening to my request, please???
P
potdar
Validation of a process is a proof unto yourself (on record) that the process parameters you use to control a process end up giving you a process that is under control.
In TS implementation, you are putting all process parameters of all processes in their respective control plans. You are also confirming that the process is under control. Maintain the record. You have done it.:cool:
P
potdar
Process validation is easily covered by, for example by following the APQP phases and producing records that satisfy PPAP.
PPAP records are normaly generated only for part approval as a proof unto the customer. They are too much detail for the needs of 7.5.2.1 and include limited processes.
The clause requires validation unto yourself for all processes. PPAP is a good guideline but much less detail would do.
Paul Simpson
Incorrect.
If you read the APQP manual and the PPAP manual (These still apply if you supply the big 3 and other subsribers) then the first is for management of the new product introduction process and the product / process design process and includes all stages of product and process design, verification and validation. The second (PPAP) requirement is that you generate all the documents as proof that you have managed the introduction or change.
Separately under PPAP it then goes on to say you must satisfy the customer's PPAP submission requirements and send them all or a selection of the documents that you have already produced as part of the APQP activity to give them confidence the new parts will satisfy their requirements.
If you want to supply the automotive industry then APQP / PPAP is (one example of) the requirements.
It would certainly not do if you are supplying the Big 3 or subscribing member.
FWIW a lot of the automotive supply chain is "standardizing" on APQP / PPAP.
P
potdar
Incorrect.
Sorry Paul. I disagree.
APQP, yes. Process validation and PPAP both form a small but integral part of APQP, which is an umbrella activity. Indeed, the control plan which I take as the base of process parameters that need to be shown as validated is an output of APQP post PPAP. So far so good. But APQP has two big faults from what I see as the OP's viewpoint. It does not tell how to do process validation and it talks of so many other things irrelevant to 7.5.2.1. One could easily get lost in the maze.
Control Plan is a better starting point for the clause and a backward journey more easily "understood".
Exactly. PPAP is the customer's requirement. It is customer specific. As you say the industry is trying to "standardise" it. The name says it all - Production Part Approval (by customer) Process. Here again, process validation is only a part among so many requirements.
Conversely, 7.5.2.1 is an internal system requirement with its own limited standing. It will play its own small part while conducting APQP and PPAP exercises. Not vice versa.
N Validation of special processes - thread closed Oil and Gas Industry Standards and Regulations 3
M Is Validation of Plating Processes required and who is responsible? Qualification and Validation (including 21 CFR Part 11) 11
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
T ISO 13485:2016 - Processes exempt from process validation ISO 13485:2016 - Medical Device Quality Management Systems 12
J ISO 13485 - 7.5.2 cleanliness , 6.4.2 validation of special processes, and 6.4.2 contamination ability to be exempt? ISO 13485:2016 - Medical Device Quality Management Systems 5
GoSpeedRacer Validation of Processes 7.5.6 - Do cosmetic welds need process validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
P Validation of Processes - What is meant by 7.5.6 (a) - Defined Criteria for Review ISO 13485:2016 - Medical Device Quality Management Systems 7
S Re-validation NCR - In which cases re-validation of processes is required Oil and Gas Industry Standards and Regulations 6
M AS9110C Clause 8.5.1.2 Validation and Control of Special Processes for Repair Station AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
W AS9100D Clause 8.5.1.2 Validation and Control of Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
D 7.5.2 Validation of Processes for Production and Service Provision AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Validation Processes of Production & Servicing - API Q1 clause 5.7.1.5 Oil and Gas Industry Standards and Regulations 2
A 7.5.2.1 Validation of Processes for Production and Service Provision IATF 16949 - Automotive Quality Systems Standard 7
I Bracketing for Validation - Processes that share some unitary operations Qualification and Validation (including 21 CFR Part 11) 4
D 7.5.2 Validation of Processes for Production and Service Provision - Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Y 7.5.2 Validation of Processes for Production and Service Provision Discussions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001 Clause 7.5.2 Validation of Processes - How to comply? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
M Looking for a simple procedure on section 7.5.2 for Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO/TS 16949 - 7.5.2 - Validation of Processes And 7.5.2.1 All Processes IATF 16949 - Automotive Quality Systems Standard 1
E What are Validation Requirements for Vendor (Supplier) Processes Supplier Quality Assurance and other Supplier Issues 5
K Validation of Processes does not seem to apply - Scientific Research Company Design and Development of Products and Processes 1
H Excluding 7.5.2 - Validation of Processes for Production and Service Provision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
S 7.5.2 Validation of Processes for Production and Service Provision AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 56
F External Storage of Data - ISO 9001 Clause 7.5.2 Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Validation of Special Processes - Are Casting and Forging Special Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N Validation of Special Processes - N/A of ISO 13485 Clause 7.5.2 ISO 13485:2016 - Medical Device Quality Management Systems 12
B Validation of Processes for Production and Service Provision - 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Understanding AS9100 Clause 7.5.2 Validation of Processes for Production and Service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Validation of Processes - Is Cl 7.5.2 applicable to bricktile firing in an oven? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Outsourcing "passivation" - Clause 7.5.2 Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Validation of processes for production for Test Equipment ISO 13485:2016 - Medical Device Quality Management Systems 9
O Format for Clause 7.5.2 (Validation of Processes) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Validation of processes 7.5.2 - We are a label printer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Validation of processes for production & service provision - Service industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
S Validation Of Outsourced Special Processes under AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
V Validation & which processes are called special processes & why not all the processes Manufacturing and Related Processes 9
V Validation of Processes for Production and Service Provision Procedure Document Control Systems, Procedures, Forms and Templates 8
C Equipment, Software and Processes Validation for Medical Devices - 21CFR 820.75 (a) ISO 13485:2016 - Medical Device Quality Management Systems 35
R Validation of Processes for Production and Service Provision - Clause 7.5.2 IATF 16949 - Automotive Quality Systems Standard 4
L Validation of Processes - Plastic Injection Moulding - ISO 9001 Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
L Validation of Processes - Resulting Output can not be Verified - Exclusion to 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
R Validation of Processes for Production - How are doing it? Clause 7.5.2 Reliability Analysis - Predictions, Testing and Standards 25
R Validation of outsourced processes - Calibration - How do we validate that? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Software Validation Processes - Telecommunications software Software Quality Assurance 10
A Validation of Processes - How to meet requirement of TS 16949 para. 7.5.2.1? IATF 16949 - Automotive Quality Systems Standard 12
M Examples for Clause 7.5.2 - Validation of processes for production and service ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F Process Validation of 'Special Processes' - How do I? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Exclusion from Validation of Processes for Production and Service Provision? Service Industry Specific Topics 17
J 7.5.2.1 Validation of processes - supplemental requirement IATF 16949 - Automotive Quality Systems Standard 11
S How to cope with the validation of processes - Services Service Industry Specific Topics 6
