Validation of Processes - Plastic Injection Moulding - ISO 9001 Clause 7.5.2
L
lrsiyer
LRS IYER
Hi!
Validation of processes of ISO 9001:2000 tells thru 7.5.2 that if the results are apparent only when the product use is started or subsequent verification of the result of the process could not reveal the process conformity then that process needs to be qualified. My doubt is:
1. A plastic injection moulding process making an automobile part. Drawing is available. After the process/production the operator/ supervisor is able check the product as per drawing. Is this process need to be validated? If yes why?
2. A blow moulding process which is a combination of extrusion and blow moulding. a similar thing that of No.1. Is this process need to be validated? If yes why?
3. an automobile chasis welding process for which the company is having checking method of NDT(LPT). Is this process need to be validated? If yes why?
if these things are answred then I have some more doubts about the same clause applicability.
V
vanputten
All 3 questions are "No."
I beleive the process output in all 3 cases can be verified by subesequent monitoring or measuring.
What do you think? Can you verify the process output for injection and blow molding and the welding?
How and when do you know your output is acceptable is the question?
Do you know your product is good before the customer (internal or external) puts it in use?
Regards,
Dirk
Kevin Mader
One of THE Original Covers!
Maybe (not sure of the full set of requirements in your examples above. I agree with the advice given by the members above.
Reference your design requirements/input documents with respect to the process of manufacture - can they all be verified (e.g. product/quality characteristic confirmed by inspection/test) or do some require validation (can't be fully verified or verification is too costly or destructive; confirmation that the characteristic is consistently achieved under varying process conditions, actual and extreme)? A robust process properly validated (and perhaps with well established process controls) can significantly reduce or eliminate inspection and test.
Good luck.
Kevin
Jen Kirley
Quality and Auditing Expert
My understanding of the element is that it is for parts that can't be inspected because, for example, the only acceptable test is a destructive test. In such cases the process must be validated by means of expendable samples or some other validation technique.
I do not think any of your examples qualifies because:
1. The part can be inspected. If there are surfaces which cannot be inspected and are still critical (such as a completely or almost closed hollow part) then a sample may need to be sacrificed for a destructive test.
2. Same as #1.
3. NDT means Non Destructive Test, which is not supposed to render the part unusable. Dyes, ultrasound, magnetic particle, and xrays don't typically destroy the part. If it does, the test is called Destructive Testing. Peel test, bend test, break/shear test...you get the idea I'm sure, so now I'm getting off my soap box.
P
potdar
LRS IYER
Hi!
The clause is worded a bit differently. It says validation is required when "the product cannot be verified by subsequent monitoring or measurement." It includes what you have listed above.
In your example, validation will not be required if a check on the dimentional parameters / weld integrity is sufficient for your purpose.
However, normally it is found that in such cases, strength and appearance checks will also be necessary. Strength checks, if required, will necessarily need process validation.
Even otherwise, validation of such processes is recommended as these fall under the catagory earlier termed as 'special processes' - processes whose outcome is controlled by controlling the process control parameters.
alekra
Besides the drawings, there may be other specifications with mechanical properties. Normally, then is the case of deciding (depending on the requirements of the specification) on NDT or destructive testing. If a destructive is needed, the validation is necessary.
Ajit Basrur
LRS IYER
Hi!
You can refer this Process validation Guidance document from GHTF. Though this document is applicable for Medical devices, you can use this document for reference and for better understanding of validation concepts. Also tell which processes have to be validated and which processes to be verified. :bigwave:
Th
L
lrsiyer
QUalityalways!!!!
Thanks for the needed help:applause: . wrong notion of exempting the 7.5.2 would fetch trouble of facing many questions like strength, UV effect, Physical properties, different metals in fusion etc.
KNOW THE THEORY & DO IT YOURSELF!!!! thanks.
LRS Iyer
N Validation of special processes - thread closed Oil and Gas Industry Standards and Regulations 3
M Is Validation of Plating Processes required and who is responsible? Qualification and Validation (including 21 CFR Part 11) 11
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
T ISO 13485:2016 - Processes exempt from process validation ISO 13485:2016 - Medical Device Quality Management Systems 12
J ISO 13485 - 7.5.2 cleanliness , 6.4.2 validation of special processes, and 6.4.2 contamination ability to be exempt? ISO 13485:2016 - Medical Device Quality Management Systems 5
GoSpeedRacer Validation of Processes 7.5.6 - Do cosmetic welds need process validation? ISO 13485:2016 - Medical Device Quality Management Systems 3
P Validation of Processes - What is meant by 7.5.6 (a) - Defined Criteria for Review ISO 13485:2016 - Medical Device Quality Management Systems 7
S Re-validation NCR - In which cases re-validation of processes is required Oil and Gas Industry Standards and Regulations 6
M AS9110C Clause 8.5.1.2 Validation and Control of Special Processes for Repair Station AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
W AS9100D Clause 8.5.1.2 Validation and Control of Special Processes AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 37
D 7.5.2 Validation of Processes for Production and Service Provision AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
L Validation Processes of Production & Servicing - API Q1 clause 5.7.1.5 Oil and Gas Industry Standards and Regulations 2
A 7.5.2.1 Validation of Processes for Production and Service Provision IATF 16949 - Automotive Quality Systems Standard 7
I Bracketing for Validation - Processes that share some unitary operations Qualification and Validation (including 21 CFR Part 11) 4
D 7.5.2 Validation of Processes for Production and Service Provision - Distributor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Y 7.5.2 Validation of Processes for Production and Service Provision Discussions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J ISO 9001 Clause 7.5.2 Validation of Processes - How to comply? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
M Looking for a simple procedure on section 7.5.2 for Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S ISO/TS 16949 - 7.5.2 - Validation of Processes And 7.5.2.1 All Processes IATF 16949 - Automotive Quality Systems Standard 1
E What are Validation Requirements for Vendor (Supplier) Processes Supplier Quality Assurance and other Supplier Issues 5
K Validation of Processes does not seem to apply - Scientific Research Company Design and Development of Products and Processes 1
H Excluding 7.5.2 - Validation of Processes for Production and Service Provision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
S 7.5.2 Validation of Processes for Production and Service Provision AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 56
F External Storage of Data - ISO 9001 Clause 7.5.2 Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Validation of Special Processes - Are Casting and Forging Special Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
N Validation of Special Processes - N/A of ISO 13485 Clause 7.5.2 ISO 13485:2016 - Medical Device Quality Management Systems 12
B Validation of Processes for Production and Service Provision - 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Understanding AS9100 Clause 7.5.2 Validation of Processes for Production and Service AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Validation of Processes - Is Cl 7.5.2 applicable to bricktile firing in an oven? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Outsourcing "passivation" - Clause 7.5.2 Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Validation of processes for production for Test Equipment ISO 13485:2016 - Medical Device Quality Management Systems 9
O Format for Clause 7.5.2 (Validation of Processes) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T Validation of processes 7.5.2 - We are a label printer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
B Validation of processes for production & service provision - Service industry ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
S Validation Of Outsourced Special Processes under AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
V Validation & which processes are called special processes & why not all the processes Manufacturing and Related Processes 9
V Validation of Processes for Production and Service Provision Procedure Document Control Systems, Procedures, Forms and Templates 8
C Equipment, Software and Processes Validation for Medical Devices - 21CFR 820.75 (a) ISO 13485:2016 - Medical Device Quality Management Systems 35
R Validation of Processes for Production and Service Provision - Clause 7.5.2 IATF 16949 - Automotive Quality Systems Standard 4
K Validation of Processes - How do I address TS 16949 Sec. 7.5.2.1 IATF 16949 - Automotive Quality Systems Standard 30
L Validation of Processes - Resulting Output can not be Verified - Exclusion to 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
R Validation of Processes for Production - How are doing it? Clause 7.5.2 Reliability Analysis - Predictions, Testing and Standards 25
R Validation of outsourced processes - Calibration - How do we validate that? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
M Software Validation Processes - Telecommunications software Software Quality Assurance 10
A Validation of Processes - How to meet requirement of TS 16949 para. 7.5.2.1? IATF 16949 - Automotive Quality Systems Standard 12
M Examples for Clause 7.5.2 - Validation of processes for production and service ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
F Process Validation of 'Special Processes' - How do I? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Exclusion from Validation of Processes for Production and Service Provision? Service Industry Specific Topics 17
J 7.5.2.1 Validation of processes - supplemental requirement IATF 16949 - Automotive Quality Systems Standard 11
S How to cope with the validation of processes - Services Service Industry Specific Topics 6
