Thanks Somashekar; so, for example, in the case of packaging validation, the validation approach that we are taking (seal strength testing, ageing testing, transit testing etc) needs to be reviewed and approved before we begin actual validation?Philip.
Before you get on with the procedure, understanding the requirement of validation must be good with everyone across the team.
This review and approve is not about any document.
Its about your process criteria that you are up with validating. May be Temperature, Pressure, RPM, Voltage, Time, Hardness, ....
Thanks Shimon, but is the standard talking about the process itself (how we package devices) or the validation process (how we validate the packaging process)?Hi Philip,
The criteria for review and approval of the processes needs to be defined prior to the execution of the protocol.
Otherwise it would be like shooting the arrow and then marking the target...
Cheers,
Shimon
Thanks Kreid, that makes perfect sense and is what we do anyway thankfully!The standard is talking about validating the (packaging) process and the process you use for that validation.
So you have to approve the validation protocol before using it and then validate the processes by using the protocol.
If that makes sense?!
