Validation of Washing and Degreasing (Solvent Washer) for Precision Machine Parts
Validation2011
Hi All,
I work for a precision machining company and we are currently validating various pieces of equipment.
We have a Washing unit that we use for washing and Degreasing (Solvent washer) of our parts.
Our Customer has requested that we qualify/validate this piece of equipment.
We are trying to develop a performace qualification protocol to test the unit but the problem is that when we remove the parts from the machine all we do is look at them and verify that they are "Visually Clean". We have no other method of testing the parts.
The customer has suggested we look into Dyne Testing the parts, but im not sure how well this would work with our process.
Has anyone validated a similar process? or can anyone offer some advise?
pkost
Re: Validation Help!!
The question you have to ask, or more specifically your customer has to answer is "how clean do we want it to be" and as ka pilo suggested..."how sure do we want to be that the cleaning process worked".
Obviously considering that the more certain you are the more expensive it gets. We have in the past used XPS analysis to confirm identify an measure surface contamination, which is probably a little extreme if you believe visual inspection is sufficient
Depending on the size of your product, you could use gravimetric techniques to detect the change in mass resulting from the contamination being removed.
bobdoering
Stop X-bar/R Madness!!
There are cleanliness standards in many industries - they generally refer to rinsing down a product in an appropriate solvent, drawing it through a vacuum filtration and observing the results on the filter paper with a criteria of how much and/or how large the remaining particles are. You really need to have that specified before you start.
However, you can do that once with a new system and fresh washing solution and pass the requirement - but the key is to run the process to the point of normal preventive maintenance, and check the product then to assure that over the "life" of the solution, filters, etc., the washing system is effective.
Otherwise, you are kidding everyone.
automoto
Hi All,
You can do that with cleanliness test (see ISO 16232). Perform cleanliness test on part before degreasing and after degreasing. With that analysis you will found out how many particles are removed during washing.
If you want to validate only degreasing you can do that easily by testing the surface tension with test pen.
P
Peterseb
I have participated in a number of validations of washing procedures. In its simplest form, one way of determining whether the surface is sufficiently clean or not it to use "white glove test", which is actually mentioned in a standard for parts that come in contact with oxygen. Whether this method is acceptable or not of course depends on your client's requirements.
There are chemical methods to analyze the amount of carbon hydrogen contaminants per surface area available. But once. again, it depends on the requirement on cleanliness.
HTH,
Peter
cosmobenz
Hello, I'm also in a medical device company. We are 9001 13485 certified. We were asked to validate our cleaning process. Washing parts, degrease, ultrasonic clean etc.
How is the best way to perform this validation?
Thank you.
Cosmo
cosmobenz
Peterseb, we have not been given a requirement to meet on cleaning. Basically it should be free of grease , oil, dirt etc. I appreciate any help you can provide me.
ScottK
Not out of the crisis
In my last company we had to clean parts for oxygen service.
I forgot the standard we had to comply with, but there are test labs that will test your parts for hydrocarbons and contamination after cleaninig.
The key, as many have pointed out, is you need a standard for cleanliness. From there you set up your process, define the validation protocol, and find a test lab to do the testing on cleaned parts to see if you comply.
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 2
C Spreadsheet Validation and Release Qualification and Validation (including 21 CFR Part 11) 2
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
M Sterile packing validation tests to be performed and protocol Other Medical Device and Orthopedic Related Topics 1
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
C ISO 19227 Validation Cost Other Medical Device Related Standards 2
A CNC Mill and Lathe - Validation Manufacturing and Related Processes 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
B Oracle Cloud ERP Validation during Quarterly Patch ISO 13485:2016 - Medical Device Quality Management Systems 1
D Software validation team Misc. Quality Assurance and Business Systems Related Topics 3
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 2
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R PCBA process validation Qualification and Validation (including 21 CFR Part 11) 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
B Sterilization Validation Plan Other Medical Device Related Standards 3
T Laboratory Verification after validation ISO 17025 related Discussions 3
silentmonkey Rationalising the level of effort and depth of software validation based on risk ISO 13485:2016 - Medical Device Quality Management Systems 10
D Questions regarding process validation ISO 13485:2016 - Medical Device Quality Management Systems 6
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 3
A Validation of Forced Aeration Process ISO 13485:2016 - Medical Device Quality Management Systems 3
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
I ISO 2233:2000 Question - Medical Device Shipping/Transportation Validation Other ISO and International Standards and European Regulations 1
B TMV - Selection of TM's for Validation ISO 13485:2016 - Medical Device Quality Management Systems 5
S Forced ServiceNow validation - No change in our current user and functional requirements IT (Information Technology) Service Management 4
P Human Factors / Usability validation in the time of COVID Human Factors and Ergonomics in Engineering 17
C Template for Excel Validation Reliability Analysis - Predictions, Testing and Standards 6
M IT validation for a paper based MD repair company QMS ISO 13485:2016 - Medical Device Quality Management Systems 6
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 39
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
M Is Validation of Plating Processes required and who is responsible? Qualification and Validation (including 21 CFR Part 11) 11
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Rees System Validation Qualification and Validation (including 21 CFR Part 11) 1
K PQ validation qualification - Asked to write a PQ protocol ISO 13485:2016 - Medical Device Quality Management Systems 6
Stoic Are any medical device companies using the 2011 FDA process validation guidance instead of GHTF/SG3/N99-10:2004? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
K Old medical devices -> 7.3.7. Design and development validation ISO 13485:2016 - Medical Device Quality Management Systems 1
S SOP for ISO 13485:2016 Quality related Software validation ISO 13485:2016 - Medical Device Quality Management Systems 9
