Validation procedure, Major NC CAP - Equipment Validation process is not effective
Good Day Everyone!
First post here on the forum, I work as the Quality Manager of small ISO 13485:2016 certified facility that is a contract manufacturer for surgical instruments (non-sterile). We recently underwent our recertification audit and a Major NC was found and described as " Equipment Validation process is not effective because the organization does not document procedures for validation of process including:
a) defined criteria for review and approval of processes;
b) equipment qualification and qualification of personnel;
c) use of specific methods, procedures and acceptance criteria;
d) as appropriate, statistical techniques with rationale for sample sizes;
e) requirements for records;
f) revalidation, including criteria for revalidation;
g) approval of changes to the processes"
My reason for joining posting here, is to request help for how to proceed with my CAP. My current SOP specifies what processes we deem special internally, what specifics must be included in the report for special process validations, the other aspects of the validation program are captured in our MVP which is a controlled document. The MVP specifies re-validation frequencies, protocols, record keeping requirements, approval/change requirements for the document to be revised, and RPN scores for processes.
Could any one please provide some guidance on how to go about generating an acceptable Corrective action plan? This is my first audit to actually have a major NC. I know I will need to revise my procedure to encompass the above listed elements, but I am on a very short time table for the corrective action plan submission and want to be thorough to ensure its acceptance.
edit: I am in process on performing a 5 why root cause analysis now
Thank you all in advance for your help!
Ronen E
Problem Solver
Moderator
I don't understand what further guidance you need.
Fixing your PV SOP would be the correction. Make sure that your SOP covers all that's required of the MVP as well, even if you already have a template that contains all required elements.
As for the CA, it shouldn't be different from any other CA. Identify the root cause (seems like you already started working on that) and then define and implement the CA, verify implementation and verify effectiveness (=successful elimination of identified root causes). IMO the failure/problem you need to look for the root cause of is a failure to identify and address an applicable ISO 13485 requirement for a documented procedure.
Hi Ronen,
Thank you for the reply. Allow me to elaborate and clarify my request, after reviewing I can see why you say that. After performing my 5 why analysis, root cause can be attributed to my procedure not clearly specifying validation requirements for non-special processes. I am in process on revising my procedure to meet the requirements set fourth, but am struggling with sub section(s)
d) as appropriate statistical techniques with rationale for sample sizes
Since this portion of the procedure I am writing will apply to all non-special processes how do I go about specifying specific methods to be used when the procedure will apply to different processes. Also what statistical techniques are they referencing in regard to the validation process?
I can verify the procedure meets all requirements except C and D, those are the two sub sections I am seeking guidance on how to adjust my procedure to meet.
Al Rosen
Hi Ronen,
Your procedure is a description of what you will do in general. You can state that a Validation plan will be developed (this is process or equipment specific) that will include:
  • Criteria for review and approval of the process
  • Approval of equipment and qualification of personnel
  • Approval and use of specific methods and procedures and instructions
  • Statistical techniques with rationale for sample size
  • Requirements for records
  • Requirements for revalidation
  • Approval of changes
Hi Al,
Thank you very much for the clarification, that seems to be at better approach that will still allow the necessary flexibility to fit the validation to specific equipment and processes.
Ronen E
Problem Solver
Moderator
@needinginfo, Thanks for elaborating.
You've asked some more specific questions that I can try to answer, but you've also got me a little more confused in general.
To me that seems not like a root cause but like a more pin-pointed rephrasing of the NC.
I'm also not sure what you mean by "non-special processes". In the context of process validation (PV), "special processes" are those for which the output can't be (or just isn't, for whatever reason) 100% verified - in these cases a PV is required. Following this line, "non-special processes" don't require a PV.
This means that your SOP needs to state in some reasonable detail (but still in a manner general enough to fit all/most of the relevant manufacturing processes) how you will go about validating, what are the steps etc. You also need to state the acceptance criteria in general terms such as stability, capability etc.
For an example of stating and rationalising statistical techniques / sample sizes without relying on input specifics, you can refer to my article about Design Verification. The details in there might not be relevant to PV, because it's a different beast from Design Verification, but the general yet prescriptive approach to statistical techniques might be of some help.
P Software verification and validation procedure IEC 62304 - Medical Device Software Life Cycle Processes 6
R ISO 13485 Software validation procedure and Quality Objectives Monitoring wanted Document Control Systems, Procedures, Forms and Templates 1
L ISO 17025 Para. 5.4.5 - Method (Calibration Procedure) Validation Requirements ISO 17025 related Discussions 2
M Chosing a procedure title - "Validation of equipment" or "Qualification of equipment" Document Control Systems, Procedures, Forms and Templates 8
J Sterilization Validation Procedure Needed? ISO 13485:2016 - Medical Device Quality Management Systems 3
M Looking for a simple procedure on section 7.5.2 for Validation of Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Writing a Procedure for Validation of an Analytical Method General Measurement Device and Calibration Topics 5
A Should the FSMS have a Documented Generic Procedure for Verification and Validation Food Safety - ISO 22000, HACCP (21 CFR 120) 2
S Writing a Test Method Validation Procedure as well as Validation of Test Methods General Measurement Device and Calibration Topics 1
A Installation and Validation Procedure for IT Laboratory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
C Software Validation Procedure per FDA requirement Qualification and Validation (including 21 CFR Part 11) 3
C Process Validation procedure for ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 5
C Do I have to establish a software validation procedure? Qualification and Validation (including 21 CFR Part 11) 11
T Oven Validation Protocol (procedure) needed General Measurement Device and Calibration Topics 19
R Validation of A Procedure for Calibrating Dial Calipers using Traceable Gauge Blocks General Measurement Device and Calibration Topics 6
V Validation of Processes for Production and Service Provision Procedure Document Control Systems, Procedures, Forms and Templates 8
B Software Validation Procedure Question - Complaint Handling Process software Software Quality Assurance 9
T ISO 17025 Validation Procedure - Need Example ISO 17025 related Discussions 11
Ajit Basrur Molding Validation procedure - New medical component ISO 13485:2016 - Medical Device Quality Management Systems 1
V Explain the process validation procedure in the manufacture of IVD products ISO 13485:2016 - Medical Device Quality Management Systems 1
T Searching for: Procedure for validation of dry measure Document Control Systems, Procedures, Forms and Templates 2
F Procedure for Software Validation and Control Quality Assurance and Compliance Software Tools and Solutions 4
T Anyone have an example of a calibration method validation procedure? General Measurement Device and Calibration Topics 4
M Initial Importer/Distributor and Software Validation IEC 62304 - Medical Device Software Life Cycle Processes 0
P Test Method Validation (TMV) for all Measurement Methods in Rec/Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
M Validation of Data verification tool per 21 CFR 820 Quality Assurance and Compliance Software Tools and Solutions 1
G Number of Destructively Tested Devices Needed for Ethylene Oxide Validation Other Medical Device Related Standards 4
E ISO 13485 software validation ISO 13485:2016 - Medical Device Quality Management Systems 7
R SAP B1 Computer System Validation Qualification and Validation (including 21 CFR Part 11) 0
A GAGE R&R Binomial with master list (for method validation) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Y ISO 13485:2015 Software Validation IQ/OQ/PQ ISO 13485:2016 - Medical Device Quality Management Systems 13
N Validation of special processes - thread closed Oil and Gas Industry Standards and Regulations 3
L Validation without Tolerance Qualification and Validation (including 21 CFR Part 11) 0
shimonv Test Method Validation ISO 13485:2016 - Medical Device Quality Management Systems 10
R Debug mode in software/device validation IEC 62304 - Medical Device Software Life Cycle Processes 2
M Software verification and validation AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Melissa Process Validation of Rotary Heat Sealer Speeds Design and Development of Products and Processes 4
C Validation of process for releasing the UDI EU Medical Device Regulations 4
C Validation of process for production and servicing 5.7.1.5 API Spec Q1, 9th Edition Oil and Gas Industry Standards and Regulations 9
W Transport validation Qualification and Validation (including 21 CFR Part 11) 4
M Is validation required when consumables are changed Qualification and Validation (including 21 CFR Part 11) 7
C 8.3.4 Verification and Validation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Transport validation Qualification and Validation (including 21 CFR Part 11) 12
mustomutlu Process Validation Final Report Other Medical Device and Orthopedic Related Topics 2
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 8
C Spreadsheet Validation and Release Qualification and Validation (including 21 CFR Part 11) 2
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
M Sterile packing validation tests to be performed and protocol Other Medical Device and Orthopedic Related Topics 1
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 1
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
