Validation vs. Confirmation in the context of an Analytical Laboratory
Basem
Hello every one
Would anybody please tell the difference between validation and confirmation.
thanks
Stijloor
Re: validation and confirmation
Hello Basem,
Before we get too carried away here: In what context are these words used?
What specific process are we talking about?
Stijloor.
Basem
Thank you for fast reply
In a test laboratory (food analysis), If we use international test method like ISO or EN standards should we validate it or confirmate it (what is the difference).
thank you
DsqrdDGD909
Do you currently use AOAC methods also?
From a google search...
"When is validation needed?
• Before introduction of a new method into routine use
• Whenever the conditions change for which a method has
been validated, e.g., instrument with different
characteristics
• Whenever the method is changed, and the change is
outside the original scope of the method
L. Huber (2001) Validation of Analytical Methods: Review and Strategy. Supplied by www.labcompliance.com"
Assumptions When Performing Validation
• The equipment on which the work is being done is
broadly suited to the application. It is clean, wellmaintained
and within calibration.
• The staff carrying out the validation are competent in the
type of work involved.
• There are no unusual fluctuations in laboratory
conditions and there is no work being carried out in the
immediate vicinity that is likely to cause interferences.
• The samples being used in the validation study are
known to be sufficiently stable.
Roper, P., et al. (2001) Applications of Reference Materials in Analytical Chemistry. Royal Society of
Chemistry, Cambridge, UK, pp. 110-111.
Stijloor
thank you
Hi Basem,
That's a little bit out of my league...I hope my Fellow Covers will respond to your question.
Covers in the Food Industry? Any takers?
Stijloor
Basem
Yes
We use AOAC methods now but without validation
harry
thank you
Read this extract from ISO 17025 & GMP
EN ISO/IEC 17 025
Validation of methods (titration, UV/VIS, gravimetry, HPLC, GC)
Validation is the confirmation by examination and the provision of effective evidence that the particular requirements for a specific intended use are fulfilled.
The laboratory shall validate non-standardized methods, laboratory designed/developed methods, standardized methods used outside their intended range and amplifications of standardized methods to confirm that the methods are fit for the intended use.
GMP: ICH Q2(R1) Validation of Analytical Procedures: Text and Methodology (CPMP/ICH/381/95)
Objective of validation of an analytical procedure is to demonstrate that it is suitable for the intended purpose.
Types of analytical procedures to be validated are:
* Identification tests.
* Quantitative tests for impurities‘ content.
* Limit tests for control of impurities
* Quantitative tests of the active moiety in samples of drug substance or drug product or other selected component(s) in drug product.
Y
Yew Jin
Hi Harry,
We are using the term of validation and verification.
From ASQ glossary,
Validation - The act of confirming a product or service meets the requirements for which it was intended
Verification - The act of determining whether products and services conform to specific requirements
harry
Thanks Yew Jin. The definitions you gave are the generally accepted ones. For validation, if you substitute 'service' with provision of lab analysis and report and 'requirements for which it was intended' with ISO 17025 or GMP/GLP requirements then you get the exact definition of validation as found in ISO 17025. That's why in post #2, Stijloor asked for the exact context or process that the OP was referring to.
G
glyhkn
if you are using standart methods like ISO you do not need validation but you need to do verification.
That verification may include formation of control charts, controls of calibrated equipment you use (temperature checks for furnaces or checks of balances with certified mass)
T Monitoring & Measuring Software confirmation (validation) - TS 16949 Section 7.6 Statistical Analysis Tools, Techniques and SPC 1
M Is validation required when consumables are changed Qualification and Validation (including 21 CFR Part 11) 3
C 8.3.4 Verification and Validation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Transport validation Qualification and Validation (including 21 CFR Part 11) 12
mustomutlu Process Validation Final Report Other Medical Device and Orthopedic Related Topics 2
P Software verification and validation procedure IEC 62304 - Medical Device Software Life Cycle Processes 6
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 6
C Spreadsheet Validation and Release Qualification and Validation (including 21 CFR Part 11) 2
M Packing Validation & Accelerated Aging Test ISO 13485:2016 - Medical Device Quality Management Systems 2
M Sterile packing validation tests to be performed and protocol Other Medical Device and Orthopedic Related Topics 1
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
H Software Validation for FFS Packaging Machine Qualification and Validation (including 21 CFR Part 11) 1
Q ISO 13485 7.5.6 Validation - Off the shelf Software ISO 13485:2016 - Medical Device Quality Management Systems 3
M ERP / QMS related software standards for Validation IEC 62304 - Medical Device Software Life Cycle Processes 6
C ISO 19227 Validation Cost Other Medical Device Related Standards 2
A CNC Mill and Lathe - Validation Manufacturing and Related Processes 2
N Sterilization Protocol Change in Validation Process and further impacts ISO 13485:2016 - Medical Device Quality Management Systems 1
B Oracle Cloud ERP Validation during Quarterly Patch ISO 13485:2016 - Medical Device Quality Management Systems 1
D Software validation team Misc. Quality Assurance and Business Systems Related Topics 3
J Validation Sample Size for Tray Seal Qualification and Validation (including 21 CFR Part 11) 3
F AS9100 - Validation, FAIR's, ITAR and Sub-Contracting AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R PCBA process validation Qualification and Validation (including 21 CFR Part 11) 2
A ISO 17025 - Methods validation and clients ISO 17025 related Discussions 3
S Sterilization validation after changing sterilization process provider Qualification and Validation (including 21 CFR Part 11) 3
B Sterilization Validation Plan Other Medical Device Related Standards 3
T Laboratory Verification after validation ISO 17025 related Discussions 3
silentmonkey Rationalising the level of effort and depth of software validation based on risk ISO 13485:2016 - Medical Device Quality Management Systems 10
D Questions regarding process validation ISO 13485:2016 - Medical Device Quality Management Systems 6
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
Z Is IQ necessary for laser marking validation? EU Medical Device Regulations 3
E 13485:2016, Sections 4.1.6, 7.5.6 and 7.6 - Validation of Software - Need some Advice please ISO 13485:2016 - Medical Device Quality Management Systems 3
A Validation of Forced Aeration Process ISO 13485:2016 - Medical Device Quality Management Systems 3
M API 4F/7K/8C Design Package Validation Oil and Gas Industry Standards and Regulations 2
I ISO 2233:2000 Question - Medical Device Shipping/Transportation Validation Other ISO and International Standards and European Regulations 1
B TMV - Selection of TM's for Validation ISO 13485:2016 - Medical Device Quality Management Systems 5
S Forced ServiceNow validation - No change in our current user and functional requirements IT (Information Technology) Service Management 4
P Human Factors / Usability validation in the time of COVID Human Factors and Ergonomics in Engineering 17
C Template for Excel Validation Reliability Analysis - Predictions, Testing and Standards 6
M IT validation for a paper based MD repair company QMS ISO 13485:2016 - Medical Device Quality Management Systems 6
P Unrealistic Packaging Validation Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 41
D Test summary report example for design validation wanted - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 1
M Is Validation of Plating Processes required and who is responsible? Qualification and Validation (including 21 CFR Part 11) 11
T ISO 13485 - Process validation at critical suppliers ISO 13485:2016 - Medical Device Quality Management Systems 7
K Software Validation for Measurement Tools used in Process Validation ISO 13485:2016 - Medical Device Quality Management Systems 2
Stoic Manual soldering processes - 100% verifiable, or always requiring validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
