With PPAP dimension reports what do you do if, as part of the production process, you end up adjusting one dimension to get the others right? The adjustment is needed to make the more important dimensions/criteria right. A significant number will be just outside the tolerances. The product is functionally fit for purpose and would not be noticed by the customer. In fact the last measurement in the Dimension Report is not really needed.
What are the implications if one dimension gets reported as NOK in a Dimension Report? Is it better to leave of the measurement or put it in exactly as it is measured? Perhaps the tolerance is too small and the drawings need changing to reflect this? Perhaps its not worth causing the hassle and just leave it off? I'm sure some companies just make it up too.
