Variable Gage R&R - Two operators instead of three
BSwan
Good afternoon,
Quick questions. We are doing variable gage R&R's on our attribute fixtures and using 2 operators, 10 parts, 3 trials.
I understand the range method is 2 operators, 5 parts, 1 trial.
I think we are going above and beyond that and we can determine some the causes of our variation with the method we are using.
I'm concerned during audit time that people may be looking for a third operator. Right now our only customer is general motors and our IATF is coming up in a couple months. Has anyone ever had any issues with this concern? Thoughts on our method?
AMIT BALLAL
re: Variable Gage R&R - Two operators instead of three
Good afternoon,
Quick questions. We are doing gage R&R's on our attribute fixtures and using 2 operators, 10 parts, 3 trials.
TBMK, Range method you have specified is used for variable studies, not for attribute.
Sent from my CPH1821 using Tapatalk
BSwan
Its an attribute gage with tons of fixed stab pins, but we are using the SPC bushings for our gage R&R data.....so its essentially a variable study. Attribute gage with some added SPC points. Variable Gage R&R study. Bad clarification on my part.
Since you are using 10 parts and 3 replicates, you are complying with this portion of the standard AIAG approach to an R&R study. The only difference is in your use of 2 vs. 3 operators.
There are two possible scenarios.
  1. There are only 2 operators that ever perform this measurement in actuality. In this scenario, you are fully justified in only using two operators (the same two) in your study, and the results are reflective of reality.
  2. The other scenario is that the two operators are representative of a larger group of operators that could perform this measurement. In this scenario, you run a risk that two operators MAY underestimate the amount of Reproducibility variation in your system. At a minimum, the degree of uncertainty in the estimate is greater. This would be more difficult to justify.
Regarding"I understand the range method is 2 operators, 5 parts, 1 trial.", where have you seen this? 5 parts is next to useless, and 1 trial will not estimate repeatability.
AMIT BALLAL
This method is specified in AIAG MSA 4th edition manual on page 102. But this method is to quick check change in GRR / to get overall picture of the measurement system (as specified in this manual), not to determine repeatability and reproducibility. I also don't find it useful.
L Gage Blocks: Attribute or Variable Gage? General Measurement Device and Calibration Topics 3
BHobbs_Busche All Measurements taken with a Variable Gage have to be Recorded 100% IATF 16949 - Automotive Quality Systems Standard 14
E Gage Repair Shops near Pheonix, AZ - Variable Gages - Micrometers, Calipers, etc. Calibration and Metrology Software and Hardware 3
M Gage R&R for Big Parts - Approving a Variable Gage using only 1 Part Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
A Acceptable Criteria for Variable Gage R&R according to the MSA Manual 3rd Edition Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Complying with Ford customer requirement 4.35 Variable Gage Studies General Measurement Device and Calibration Topics 3
P Long and Short (Variable Data) Gage Studies - Urgent Help needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
G Customer is requesting Variable Data for Attribute Gages in Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
S Is there a "Cross Method" gage R&R for variable gages? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
S Excel .xls spreadsheet file for Gage R&R for Variable Data Excel .xls Spreadsheet Templates and Tools 6
K Transform variable data into attribute data Reliability Analysis - Predictions, Testing and Standards 24
B To detect the non standard variable IATF 16949 - Automotive Quality Systems Standard 5
J Sample size for creating a data base as a reference to a tested variable Other Medical Device and Orthopedic Related Topics 6
E Sample size for design verification of variable in single use device Design and Development of Products and Processes 20
N Variable Data Test Never Fails Capability, Accuracy and Stability - Processes, Machines, etc. 9
Q Can there be a mix of good and bad parts for a variable GR&R? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
E GR&R for a test fixture that outputs variable data per measurement Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T Attribute vs Variable Inspection Data ISO 13485 Requirement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
A Taguchi Minitab - Continuous Data - What should I choose as response variable? Using Minitab Software 3
V Why Gauge R&R 10% is acceptable for variable instruments ? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
Douglas E. Purdy C=0 Sampling for Variable Characteristics Quality Manager and Management Related Issues 14
J Passing a variable to the ODBC call in Minitab Using Minitab Software 8
S How to use Dummy Variable in Regression Model in Minitab Six Sigma 2
T Variable Dimensions / Part of Production / PPAP Dimensional Report Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Do all non-random patterns apply to attributes and variable charts including R chart? Statistical Analysis Tools, Techniques and SPC 5
M Sampling for Variable Data to determine the size of a Mould Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Regression analysis with discrete dependent variable and continuous independent var. Statistical Analysis Tools, Techniques and SPC 13
K How to group 5 questions to be one variable for Likert Scale question Using Minitab Software 11
M Destructive VTMV Subgroups - A Destructive Variable Test Method to Validate Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
B Using a File Name as a Variable in an Excel Macro Excel .xls Spreadsheet Templates and Tools 11
S Strange PT Ratio on an Excel spreadsheet for variable GRR ANOVA Method Excel .xls Spreadsheet Templates and Tools 2
A Sample Size Selection for Peel Strength for Variable Data using a 95%/99% Confidence Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
S Probability Density Function of a Function of a Random Variable Statistical Analysis Tools, Techniques and SPC 13
Wayne User's Manuals for Variable Screw Thread Measurement Systems General Measurement Device and Calibration Topics 1
S What should I use for Variable Sample with Size 3, 4, and 5 - xbar-R or xbar-S? Statistical Analysis Tools, Techniques and SPC 4
X Fanuc Injection Moulding Machine - Variable stage speed/pressure injection profiles Manufacturing and Related Processes 1
K DOE - Variable and Discrete Data - Minitab Using Minitab Software 11
M Regression Analysis Help - Factors influencing a Dependent Variable Using Minitab Software 7
Marc Steve Durnin's Infinitely Variable Transmission World News 0
N Variable Control Limits Calculation - P Chart Statistical Analysis Tools, Techniques and SPC 8
V Questions on Variable and Attribute MSA Interpretation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
N AQL - Sampling plan (variable, inspection level ii, normal inspection S-method) AQL - Acceptable Quality Level 2
E Variable Data - Total Percent Nonconforming from Different Nonconformances Quality Tools, Improvement and Analysis 4
E Barcode Format Question - Variable vs. Fixed Segment Length Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
J Critical Characteristics need to be measured 100% if they are variable in nature Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
bobdoering Determining a Good Variable for Small Scale Weld Integrity Capability Evaluation Capability, Accuracy and Stability - Processes, Machines, etc. 7
P P-Chart with variable sample size - How to update the chart? Statistical Analysis Tools, Techniques and SPC 6
A Sampling - Measuring and Inspecting a part with both Variable & Attribute Data Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
C Minitab Column Sorting Issue - Invalid variable(s) to sort Using Minitab Software 9
