Variables Gage R&R study for 8 Cavities tool - Die casting industry
P
pejcinovski
Hello everyone,
i work in die casting indystry. I have tool with 8 cavities. For R & R study, should i take only one same part for every trial, every operator, or all of them???
Thank you:)
P
prototyper
Re: R & R study
Is this an attribute or variables study?
What type of gauge are you using?
P
prototyper
Re: Variable R & R study for 8 Cavities tool - die casting industry
The R&R study is to assess how suitable the gauge is for the application so it doesn't matter which mould the parts come from. The important thing is that you select parts which cover the full range of the process.
Part selection is one of the most important aspects of conducting an R&R study and it is where most people new to R&R go wrong.
P
pejcinovski
So i should take and measure the same part and same dimension in every trial, and for every operator???
RickHiller
Could you expand this statement? I am dealing with small rubber parts molded in tools having hundreds of unmarked cavities.
bobdoering
Stop X-bar/R Madness!!
The point of gage R&R is to determine if the gage is the correct gage for the job. That is not related to the number of cavities, except for the fact that the sample of parts you are verifying with the gage should be representative the the amount of variation that specific dimension will have. Which cavities the samples come from are not important.
Also, mark the parts and have the operators measure the dimension at the exact same location every time.
I prefer 3 operators, one very well trained, one of the least trained that would likely use the gage, and someone in the middle. This generates a result that should be applicable with any potential future operator. I would suspect that is particularly important when measuring rubber!
Make sure you watch the gage R&R process - observe the technique variation (another common error). If the gage R&R fails, you may need to control the technique to get it to pass, rather than buy a more expensive gage. If you have the AIAG book, be sure to pull out the list of between and within errors, and watch for them during the Gage R&R process.
P
prototyper
The parts selected should be representative of the whole population of your product, i.e. take one part from the lower end of the population, one part from the upper end of the population and the rest somewhere in between.
One of the reasons for conducting GRR is to determine if the gauge can distinguish between distinct categories of parts within the population. If you take consecutive parts from a process they are unlikely to include all of the variation you would expect over a long period of time and you will more than likely get a poor result on the GRR.
bobdoering
Also, for rubber parts, watch out for gage pressure. Low pressure or non-contact gages should be the preference, especially as the lower the durometer gets.
Be very careful with this statement. If the gage will be used for inspection and the metric used is the P/T Ratio (%Tol), this statement is fine as is.
However, if the gage will be used for process control and the metric used is %GRR (%SV), this statement is misleading. The standard deviation of the samples used must match the standard deviation of the process. You may or may not achieve this by sampling as you suggested.
B Can the Variation on Data be too small in a Variables Data Gage R&R Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
V Gage R&R for Variables Data on a CMM (Coordinate Measurement Machine) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
Q Mitutoyo USB Cables for Variables Data Collection using a Dial Snap Gage Statistical Analysis Tools, Techniques and SPC 2
C GAGE R&R for Variables - Myth or reality? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Variables Gage R&R - Minitab v14 - F statistic Calculation - ANOVA - Methods validity Using Minitab Software 2
gramps What is the difference between discrete and continuous variables? Problem Solving, Root Cause Fault and Failure Analysis 3
E Sampling for capability studies for variables and attributes Capability, Accuracy and Stability - Processes, Machines, etc. 4
S VDA 5 Variables Data GR&R Spreadsheet wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M How to find the number of required data - Correlation with 4 variables Using Minitab Software 2
O Test of Significance for Input Variables Statistical Analysis Tools, Techniques and SPC 2
B ISO 3951 - Sampling procedure for Inspection by Variables Data AQL - Acceptable Quality Level 11
0 Visualizing ranges of 3 parameters with 6 variables Quality Tools, Improvement and Analysis 5
R Variables Data Type Analysis help Quality Tools, Improvement and Analysis 4
D Pre-Design Verification - Using Continuous / Variables Data Statistical Analysis Tools, Techniques and SPC 2
M Practical Methods using Sampling by Variables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
kedarg6500 Acceptance Sampling Plan for Variables - Product Performance Testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
C Optimize One Response with Three Variables Using Minitab Software 8
B Doing MSA Variables Data Study on Threads Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
A Effects of categorical variables on single response Using Minitab Software 9
L Moving SPC Data from Variables to an Attributes Chart Statistical Analysis Tools, Techniques and SPC 4
E Binomial Process Capability Sample Size - Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 4
Proud Liberal Making a simple Sampling Plan by Variables Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Incoming Inspection Acceptance Sampling by Variables and Minitab Quality Tools, Improvement and Analysis 1
I Critical Variables Monitoring during Process Validation Qualification and Validation (including 21 CFR Part 11) 4
N Linear Regression Formula with Four Variables to a Power Regression Formula Using Minitab Software 2
C MSA (Measurement Systems Analysis) Variables Template Document Control Systems, Procedures, Forms and Templates 0
C Process Capability - Variables Data Analysis (Template) Document Control Systems, Procedures, Forms and Templates 0
B SPC on Weight of Plastic Injection Molded Parts - What variables affect my process Statistical Analysis Tools, Techniques and SPC 2
M DOE (Design of Experiments) for 3 Variables, Many Levels Quality Tools, Improvement and Analysis 2
T Recording of Measured (Variables) Inspection Data vs. Check Boxes Inspection, Prints (Drawings), Testing, Sampling and Related Topics 17
W Sampling Plan problem - Determining Sample Size for both Attribute and Variables Data ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Correlation between 2 Variables - Potential X's that might affect yield percentage Quality Tools, Improvement and Analysis 5
S Attribute vs. Variables Specifications - Test Methods Benchmarking 15
O Capability Studies: Can I combine Attribute Data and Variables Data Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Process Capability Study using Variables Data (weight of the product) Statistical Analysis Tools, Techniques and SPC 9
W Discrete vs. Continuous Variables and Linear Regression. Statistical Analysis Tools, Techniques and SPC 7
P Must Key Product/Process Characteristics (KPC's) always be variables? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
T Double-sided (USL, LSL) Variables sampling plan Z1.9 - Use in Excel spreadsheet? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
M Chi Square Help - One of my variables has three possible results Using Minitab Software 15
H Removing fixed effects (time demeaned variables) in Minitab Using Minitab Software 12
U Variables Control Chart options - Tightly toleranced machined components Statistical Analysis Tools, Techniques and SPC 1
R Quantity of Samples (Variables and Attributes) vs. C/I and T/I Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
S Is it possible to calculate percentiles for rating scale variables? Statistical Analysis Tools, Techniques and SPC 2
S Sampling plan for Inspection by Variables (high volume production) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
S DOE (Design of Experiment) with Several Output Variables Quality Tools, Improvement and Analysis 4
C Designing control chart for non-normal variables Statistical Analysis Tools, Techniques and SPC 3
A Variables control chart (XBar & R) template needed Statistical Analysis Tools, Techniques and SPC 2
R Multivariate Control Charts? Control of 2 or more correlated variables Statistical Analysis Tools, Techniques and SPC 6
R Calibration Intervals (Frequency) derived from Variables Data Calibration Frequency (Interval) 30
Randy Definition Independent vs. Dependent Research Variables - Define and distinguish Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
