VDA 19.2 Illig value vs. allowed particle size
Dears,
is any direct dependence /connection between Illig value (VDA 19.2 point G. 2 / G 2.3) and allowed particle size?
What I mean: if allowed particle size for produced part is for example 500µm, and illig value will be for example 750 - that means that environmet is not adequate for this process or there is another dependence?
malasuerte
I am not 100% what you mean by dependence; but your own response is correct "the environment is not adequate for the process".
I will attempt to understand what you mean by dependence here - the 'dependence' would be, do you have systems that can detect a particle size greater than 500 and then be able to scrap that part so it doesn't make it to the customers.
  • Just because an environment is not 'rated' for what you need, doesn't mean it is not possible that you get what you need. So you would then have screening/measure to ensure only passing parts are produced.
Thanks.
In other words: Illig value = max. particle allowed for components?
I mean 1 to 1, like Illig 500 for environment = 500µm for component?
malasuerte
Thanks.
Apologies, but for not understanding clearly the question. :(
Let me try again:
  • So the illig value for your particular environment if 750?
  • The max value for the component is 500
Hence,
  • Yes, YOUR environment is not adequate for the process.
However,
  • That is not the only factor. Particles can come from more than the environment. They are generated as part of the process. Or just naturally over time. But if the environment is not adequate, then you now have an additional variable that can cause particles of this level.
R VDA Potential Analysis - Similar product from other customer and confidentiality VDA Standards - Germany's Automotive Standards 0
W Cross reference between APQP and VDA MLA? APQP and PPAP 0
Sidney Vianna IATF 16949 News AIAG/VDA harmonized approach to FMEA IATF 16949 - Automotive Quality Systems Standard 0
S AIAG-VDA FMEA tutorial and completely filled FMEA FMEA and Control Plans 1
C VDA 6.2 version 2020 - coversheet VDA Standards - Germany's Automotive Standards 0
Q VDA Standard - VDA FMEA VDA Standards - Germany's Automotive Standards 11
M AIAG-VDA DFMEA 2019 - it is compulsory? FMEA and Control Plans 7
C VDA 6.3 Auditor Expiration - Grace Period? IATF 16949 - Automotive Quality Systems Standard 7
Casana Step 7 in AIAG/VDA FMEA form FMEA and Control Plans 17
U New Yellow Print VDA 6.3 4th Edition - May 2022 VDA Standards - Germany's Automotive Standards 1
A VDA 19.2 vs. ISO 14644-1 VDA Standards - Germany's Automotive Standards 0
O What is SW-PNR in VDA 2:2020 P74? VDA Standards - Germany's Automotive Standards 0
I VDA Standard search VDA Standards - Germany's Automotive Standards 1
M Should there be another column in the Optimization section (step 6) of AIAG-VDA DFMEA form? FMEA and Control Plans 1
M Inconsistency of VDA-AIAG severity table for DFMEA with the manual text FMEA and Control Plans 0
M How to record the effects of adjacent systems (shown in boundary diagram) in the AIAG-VDA DFMEA form FMEA and Control Plans 0
B VDA 6.3 Action needed score 8? VDA Standards - Germany's Automotive Standards 2
H RPN in AIaG-VDA FMEA Manual FMEA and Control Plans 1
M Options when MSA acc. to VDA 5 is NOK (Qms > 30%) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
W Must VDA 6.3 be assigned to certain project? VDA Standards - Germany's Automotive Standards 0
Sonja D AIAG VDA PFMEA and Control Plan training FMEA and Control Plans 9
M VDA 6.3 – Workshop for Certified Process Auditor VDA Standards - Germany's Automotive Standards 4
OpExPro AIAG VDA FMEA Rating Tables FMEA and Control Plans 5
OpExPro The note at the bottom of DFMEA occurrence tables in AIAG VDA FMEA FMEA and Control Plans 0
OpExPro AIAG VDA DFMEA Template Required FMEA and Control Plans 6
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 6
John C. Abnet VDA 6.3 questionnaire form VDA Standards - Germany's Automotive Standards 5
B VDA Manufacturing and Related Processes 0
B EMPB (Erstmusterprufbericht) VDA form confusion + PSW VDA Standards - Germany's Automotive Standards 4
Richard Regalado Automotive News TISAX - VDA ISA (information security assessment) VDA Standards - Germany's Automotive Standards 7
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 11
M Any way to execute VDA 6.3 audit remotely? VDA Standards - Germany's Automotive Standards 3
sutie How to understand VDA 6.3 2016 P4.1 VDA Standards - Germany's Automotive Standards 6
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 1
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 6
Q VDA 6.3 questions vs IATF 16949 clauses VDA Standards - Germany's Automotive Standards 0
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
B VDA 6.3 Qualification as Process Auditor training course and exam VDA Standards - Germany's Automotive Standards 0
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
M MANUAL FMEA VDA VDA Standards - Germany's Automotive Standards 1
S Yellow print VDA 4 VDA Standards - Germany's Automotive Standards 0
D Where (in US) can I get the VDA Auditor Edition book? VDA Standards - Germany's Automotive Standards 3
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
D FMEA-MSR in the AIAG-VDA Aligned Handbook - What is it? FMEA and Control Plans 5
J Customer VDA Audit - We must provide refresher training? VDA Standards - Germany's Automotive Standards 4
