VDA 6.3 Automotive Audit with detailed questions Audit Questionnaire
G
guzer
Dear All,
Do you have any audit questionnaire acc. to VDA 6.3 with detailed question for each part, question from the book/ official report ?
For example
6.1.1 Has the project been transferred from development to serial production?
6.1.1 a Who performs the process release?
6.1.1 b Who tests the first piece off the line?
etc.
Thank you in advance.
G
guzer
Could you help me with that please. I was looking for this kind of questionnaire without success.
LUV-d-4UM
Dear All,
For example
etc.
I do not know where I found this but the following is the VD 6.3 process input requirement:
6.1.1
- A process is defined for transferring responsibility between development/production and is controlled.
- A complete production process/product approval/releases with all the documentation required must take place before the first production shipment.
- The PPAP is the final verification of the product, production and transport planning process and a positive result lead to approval/release for serial production.
- Conditions for serial production release are agreed with the customer.
- Reference parts from sample submissions must be retained in accordance with the customer's instructions.
- The process for securing the launch of production is described/installed in order to shorten the run-up phase & ensure a robust production process.
- A process to secure the launch must be carried out for all new parts/modified products requiring initial sample submission approval.
- A production test has been carried out to the customer's requirements & assessed positively. Actions arising from the production test have been completed on time. Production facilities/new parts have been sampled with positive results.
- A process for the further development of the product and process FMEAs is defined and controlled.
- Evidence of feasibility investigations have been provided for all special characteristics.
- Tools, test, inspection and measurement facilities are available in sufficient quantities.
- Responsibility for serial production has been transferred from the project team to the production plant.
Hope this helps a bit.
Kiran Walimbe
6.1.1
Those who seek out the Audit check list for VDA 6.3 process auditing don’t have to go far. The Red Book or the standard itself is a basic check list. However, all VDA 6.3 process auditors are required to plot a turtle diagram of the actual process which they are going to audit; the specific risks are required to be identified; auditor is required to devise ‘Open Ended’ audit questions for verifying the existence or non-existence of these risks; ask these questions; find the truth and then return back to his desks only to convert the data gathered into answers to ‘Closed ended’ question and then fill up the AUDIT ANALYSIS TOOL to arrive at the ratings. This auditing un-earths the true status as well as all risks of processes being audited.
LUV-d-4UM
Can someone send me a copy of the written questionare to pass the VDA 6.3? I did not make 70% and I will retake this test in 2 months. Thank you.I passed the oral exam.
Kiran Walimbe
Reading the one-liner question, I presume, you are talking about passing the written exam on day 5 of the qualifier training. This exam consists of 40 questions with multiple choices. Most options appear to be confusingly right. The participant is needed to choose the most correct option. The minimum passing percentage is 70% and the exam is a closed-book one. The written questionnaire will not be available anywhere as it is an ‘Intellectual Property’ of VDA. What’s more; if the questions were to be available, then this examination would loose any meaning or importance.
The only option available to anyone is to go through the Red Book with a fine tooth comb and to generate as many statements as possible which are similar to those given to you during the exam. Maturity of your own experience and generating a firm grip on the requirements of the standard are the only ways to crack this examination. Please make full use of the two months period available to you. Good luck to you.
Dear All,
Is the written exam timed? What can I expect for the oral exam (e.g. are you presented scenarios that you have to address, asked questions that you have to present the best answer, etc.)? Thank you in advance.
S New to the automotive business and VDA VDA Standards - Germany's Automotive Standards 5
M VDA 6.3 Automotive Requirement vs. ink-off VDA Standards - Germany's Automotive Standards 3
O VDA 2:2020 Appendix 2-Appendix 6 VDA Standards - Germany's Automotive Standards 0
M How to record the effects of adjacent systems (shown in boundary diagram) in the AIAG-VDA DFMEA form FMEA and Control Plans 0
A VDA 19.2 Illig value vs. allowed particle size VDA Standards - Germany's Automotive Standards 4
B VDA 6.3 Action needed score 8? VDA Standards - Germany's Automotive Standards 2
H RPN in AIaG-VDA FMEA Manual FMEA and Control Plans 1
M Options when MSA acc. to VDA 5 is NOK (Qms > 30%) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
W Must VDA 6.3 be assigned to certain project? VDA Standards - Germany's Automotive Standards 0
Sonja D AIAG VDA PFMEA and Control Plan training FMEA and Control Plans 9
M VDA 6.3 – Workshop for Certified Process Auditor VDA Standards - Germany's Automotive Standards 4
OpExPro AIAG VDA FMEA Rating Tables FMEA and Control Plans 5
OpExPro The note at the bottom of DFMEA occurrence tables in AIAG VDA FMEA FMEA and Control Plans 0
OpExPro AIAG VDA DFMEA Template Required FMEA and Control Plans 6
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 6
John C. Abnet VDA 6.3 questionnaire form VDA Standards - Germany's Automotive Standards 1
B VDA Manufacturing and Related Processes 0
B EMPB (Erstmusterprufbericht) VDA form confusion + PSW VDA Standards - Germany's Automotive Standards 4
Richard Regalado Automotive News TISAX - VDA ISA (information security assessment) VDA Standards - Germany's Automotive Standards 6
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 7
M Any way to execute VDA 6.3 audit remotely? VDA Standards - Germany's Automotive Standards 3
sutie How to understand VDA 6.3 2016 P4.1 VDA Standards - Germany's Automotive Standards 6
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 1
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 5
Q VDA 6.3 questions vs IATF 16949 clauses VDA Standards - Germany's Automotive Standards 0
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
B VDA 6.3 Qualification as Process Auditor training course and exam VDA Standards - Germany's Automotive Standards 0
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
M MANUAL FMEA VDA VDA Standards - Germany's Automotive Standards 1
S Yellow print VDA 4 VDA Standards - Germany's Automotive Standards 0
D Where (in US) can I get the VDA Auditor Edition book? VDA Standards - Germany's Automotive Standards 3
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
D FMEA-MSR in the AIAG-VDA Aligned Handbook - What is it? FMEA and Control Plans 5
J Customer VDA Audit - We must provide refresher training? VDA Standards - Germany's Automotive Standards 4
bobdoering AIAG VDA FMEA Handbook - 2019 - something familiar about this.... FMEA and Control Plans 37
J Supplier choice limitation - Many of them dont have PSCR, VDA or even ISO 9001 VDA Standards - Germany's Automotive Standards 0
L VDA 1 Documented Information and Retention (new revision 4, August 2018) VDA Standards - Germany's Automotive Standards 0
Q VDA 6.3 Process Auditor Card VDA Standards - Germany's Automotive Standards 1
Q GAP Analysis between IATF 16949 and VDA 6.3 wanted VDA Standards - Germany's Automotive Standards 4
C VDA Vol.4 - Evaluation of an FMEA FMEA and Control Plans 0
D VDA 6.4 Audit checklist - Production tool suppliers VDA Standards - Germany's Automotive Standards 1
J VDA audit, control plan - My hair is almost gone now VDA Standards - Germany's Automotive Standards 5
R Information on the roll out of the new harmonized DRAFT FMEA AIAG/VDA manual IATF 16949 - Automotive Quality Systems Standard 4
G Options for failing a VDA POTENTIAL audit VDA Standards - Germany's Automotive Standards 2
S VDA 5 Variables Data GR&R Spreadsheet wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
