VDA 6.3 Process Audit - but we're ISO9001:2008
TPMB4
Quick question. If our systems are in control based on ISO9001:2008 then how far out do you think we could be if we had a VDA 6.3 audit?
I guess I am asking is how comparable are VDA and ISO9001? I guess some non-conformance but surely a good system is transferable to a large degree to another process based standard. If not then isn't it time the Automotive sector agreed a unified standard to be used by all??
Howard Atkins
Forum Administrator
Re: VDA6.3 - but we're ISO9001:2008
VDA 6.3 is a process audit and not a systems audit.
The systems version is VDA 6.1
There are a number of issues that are not covered in ISO 9001.
I suggest that you request from the body auditing you the questionnaire that they will use.
You can also buy the standard VDA Webshop
qusys
Is this a customer audit?
I say so, because the customer send in advance this type of form based on DVA 6.3 when they search for new supplier in the automotive sector.
Before performing audit on your premises, they send you the form with a series of question based on that standard where you are supposed to evaluated yourself with evidences. They will successively make double check on the field.
TPMB4
Yes, customer audit. One of many. It must be Audit season or something!!
Not had any questions through but time for that I reckon.
I've read up a bit on VDA6.1 and VDA 6.3. I just wonder if we have a good quality system in place that is in control then we should be ok. Since I reckon the ultimate goal of any quality standard is to ensure a level of quality or conformance to quality (forgive my naive use of terms) then one system should produce results when audited against another that is at least considered acceptable. However I somehow doubt it is ever that simple.
qusys
Be prepared to accomplish this and take it as an opportunity to improve your QMS. remember also that the fact to meet customer requirment during this audit will increase your business!:bigwave:
qusys
Your customer will also ask you abit control plan, fmea pm, process flow , msa, spc etc... this are included in automotive items.
Did you ever sing off a PPAP or is this the first time that you have links with this customer?
TPMB4
That is the whole point of the audit for both sides. We take any CA required as a positive to the bottom line as it means more work is likely. Or more accurately if we don't make the required changes (aren't there always some of these) then the new tranche of work won't be coming our way. The customer takes from them the supplier that has systems in place that is likely to meet their requirements. Also they can gauge the attitude of the management and particularly whether they are customer orientated. A supplier with the right attitude for your company is also important. You want to work with them when they are like that and not clobber them every time there is a problem (if there is a problem that is).
Mind you it does seem that some Corrective actions or issues that get picked up are a bit subjective.
Spring2011
Since June 2012, we have been through two VDA 6.3 audits, finishing the second one yesterday, 11.08.2012. I will say this... TS16949/QS9001 audits are a walk in the park compared to a VDA audit. Yes, we successfully passed both audits with "A" scores, however, it was not easy. Just make sure that you have every "T" crossed and every "I" dotted and still that may not be enough. A word of advice that will be of great benefit, purchase the VDA 6.3 Process Audit standard and go through it with a fine tooth comb. Good Luck!!!
O VDA 6.3 Process Audit Template wanted VDA Standards - Germany's Automotive Standards 5
R Audit Planning - Process Audit agenda - VDA 6.3 VDA Standards - Germany's Automotive Standards 4
P System Audit Approach - Application of VDA 6.3 - Process Auditing VDA Standards - Germany's Automotive Standards 2
Crimpshrine13 Is VDA 6.3 required for Manufacturing Process Audit (ISO/TS 16949)? Manufacturing and Related Processes 5
P VDA 6.3 Process Audit Scoring Guidelines VDA Standards - Germany's Automotive Standards 14
A Process Audit VDA 6.3 - Form or template file Process Audits and Layered Process Audits 10
A VDA 6.3 - Process Audit Evaluation Sheet VDA Standards - Germany's Automotive Standards 2
antoine.dias VDA 6.3 - Process Audit - New version now available - September 2010 VDA Standards - Germany's Automotive Standards 16
P VDA 6.3 - Process Audit - You think you had it bad? VDA Standards - Germany's Automotive Standards 35
C VDA 6.3 Process Audit Evaluation Sheet VDA Standards - Germany's Automotive Standards 24
J Process Audit recommendation within ISO TS 16949? Does it exist like in VDA? Process Audits and Layered Process Audits 18
B VDA 6.3 Qualification as Process Auditor training course and exam VDA Standards - Germany's Automotive Standards 0
C FMEA Process assessment In the Draft for the AIAG/VDA FMEA Manual is gone FMEA and Control Plans 0
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
Q VDA 6.3 Process Auditor Card VDA Standards - Germany's Automotive Standards 1
P VDA 6.3 - How can I build the process NTF? VDA Standards - Germany's Automotive Standards 2
I Where to find VDA 6.3 Robust Production Process (rpp) PDF file ? VDA Standards - Germany's Automotive Standards 1
P Challenge Supplier Process Audits to VDA 6.3 VDA Standards - Germany's Automotive Standards 1
S VDA 6.3 - Requirement for Process Audits all shifts VDA Standards - Germany's Automotive Standards 2
V P2, P3, P4 Necessity in regular VDA 6.3 Process Audits VDA Standards - Germany's Automotive Standards 4
5 Is anybody aware of a VDA 2 Revision which includes parts of the APQP process? VDA Standards - Germany's Automotive Standards 3
Y VDA & TS 16949 Release Parts Process Comparison VDA Standards - Germany's Automotive Standards 14
O AIAG VDA DFMEA Template Required FMEA and Control Plans 2
John C. Abnet VDA 6.3 - Question 7.3 - "blocking of parts" VDA Standards - Germany's Automotive Standards 6
John C. Abnet VDA 6.3 questionnaire form VDA Standards - Germany's Automotive Standards 1
B VDA Manufacturing and Related Processes 0
B EMPB (Erstmusterprufbericht) VDA form confusion + PSW VDA Standards - Germany's Automotive Standards 2
Richard Regalado Automotive News TISAX - VDA ISA (information security assessment) VDA Standards - Germany's Automotive Standards 5
J Which OEM or customers are now requiring the new AIAG/VDA FMEA format? FMEA and Control Plans 2
M Any way to execute VDA 6.3 audit remotely? VDA Standards - Germany's Automotive Standards 3
sutie How to understand VDA 6.3 2016 P4.1 VDA Standards - Germany's Automotive Standards 6
C AIAG/VDA FMEA - Is the new better? FMEA and Control Plans 0
P VDA AIAG FMEA - Slides for Quality Audience FMEA and Control Plans 4
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 0
B AIAG/VDA’s FMEA Manual Is a Major Advance (my take on this subject) FMEA and Control Plans 2
B AIAG-VDA FMEA - When the new format will be required FMEA and Control Plans 5
Q VDA 6.3 questions vs IATF 16949 clauses VDA Standards - Germany's Automotive Standards 0
M How to complete structure Analysis and Function analysis sections' columns of AIAG-VDA DFMEA form FMEA and Control Plans 0
M MANUAL FMEA VDA VDA Standards - Germany's Automotive Standards 1
S Yellow print VDA 4 VDA Standards - Germany's Automotive Standards 0
D Where (in US) can I get the VDA Auditor Edition book? VDA Standards - Germany's Automotive Standards 3
D FMEA-MSR in the AIAG-VDA Aligned Handbook - What is it? FMEA and Control Plans 5
J Customer VDA Audit - We must provide refresher training? VDA Standards - Germany's Automotive Standards 4
bobdoering AIAG VDA FMEA Handbook - 2019 - something familiar about this.... FMEA and Control Plans 37
J Supplier choice limitation - Many of them dont have PSCR, VDA or even ISO 9001 VDA Standards - Germany's Automotive Standards 0
L VDA 1 Documented Information and Retention (new revision 4, August 2018) VDA Standards - Germany's Automotive Standards 0
S New to the automotive business and VDA VDA Standards - Germany's Automotive Standards 5
Q GAP Analysis between IATF 16949 and VDA 6.3 wanted VDA Standards - Germany's Automotive Standards 4
