Vendor (Supplier) Audit Form as a Controlled Form and as a Record
John Nabors - 2009
#11
Dutton T-
At my previous employer, we first had 2 main catagories of suppliers: those who supplied material made to our drawings, and suppliers of 'stock' or 'off the shelf' items. We had two very different supplier evals for each catagory because we had different concerns: e.g., a supplier of stock items would be evaluated on, among other things, product literature, something that would not really apply to a supplier of parts made to our drawings. Conversely, a supplier of parts made to our drawings would be evaluated on, for example, their control of our engineering documents which of course would not apply to a stock item supplier. Therefore we had separate forms for each catagory.
Also, within the catagory of suppliers making parts to our drawings we had two distinct sub-catagories of parts: machined parts and fabricated parts. We had some concerns and expectations that differed to some extent between each sub-catagory so the form had two sections, each addressing each sub-catagory and the suppliers would fill out one or the other, or both as appropriate.
Each of these forms was a controlled form in our document control system.
That help at all?
Regards -John
W
Willem
#12
Dutton T
We are using a basic questionaire for all our suppliers. Important of such a questionaire/evaluation/audit is to make sure that it is based on your individual needs as a cutomer. In our case we don't expect our suppliers to be ISO9001.2000 listed. We have critical and non critical suppliers. Critical is suppliers that supply products that is used in manufacturing parts that can affect the quality of our final product. Non-critical is suppliers that supply products that can't affect our quality. We will only use our questionaire on the critical suppliers. Non-critical suppliers will be evaluated based on performance.
The questionaire is a form that is controlled by means of a numer that is recorded in my manual. The questionaire become a record once it is completed by the supplier.
We have basic quesions like:
1) What is your lead time. (based on their lea time we will give them a point)
2) Are inspection activities done on all products that are supplied.
etc
All of the best:biglaugh:
Craig H.
#13
Re: Vendor audit form as a record
Thanks,
I had thought about using one for all, however I get a lot of "to many questions". So I will be using product or supplier specific questions and try to keep around 10 questions.
Dutton,
I may be a little "different" in my approach, but I dislike the computer-generated lists of audit questions. They, in total, will cover all of the bases, but they can also turn the audit into an endless bunch of questions, the answers to which can be painfully obvious.
What I like to try to do is to use open-ended questions that should lead to the Operator (or insert another employee position here) eventually answering most of the questions without being asked. Of course this works for in-person audits only.
For written questionnaires (which I despise, BTW) many companies have a statement somewhere that allows the supplier to omit most of the questionnaire if they can attach a valid 9001 (QS, whatever) certificate. Still, I don't like them. When we used them years ago the highest score ever (98, if memory serves) came from our WORST supplier. Its like the first line of the cover letter says, "please lie to me, if you like".
John's comments about different supplier levels are also very important. Why expend the same effort on the supplier of a critical component as you expend on the supplier of disposable washroom products? You can have as many levels as you like. Just do what makes sense for you.
Oh, and try a serch on this site. We have had many conversations about this topic over the years.
Benjamin28
#14
:2cents:
Written questionaires are done to satisfy a requirement, I have yet to come across a quality professional who thinks supplier surveys are a valuable tool. They are a poor solution to the fact that it's not financially possible to audit all suppliers. I receive such surveys daily, and can say without a doubt that they are a waste of time and effort. For example, yesterday I recieved a survey which one question asked if I was planning on being Y2K compliant in regards to software upgrades....I checked the revision date of the document...2002??
Anyhow, the point being, if you are going to put out a generic, everything on one document, questionaire, try to glean whatever value you can out of it, keep it concise and up to date, otherwise it's just wasted time.
W
Willem
#16
I agree with Craig H. Normal audit questions can result in a lenghty questionaire. We've drawn up a quesionaire that we can use to evaluate the supplier and also be re-evaluated by ourselfs on a timeline scheduled by ourselfs.
J Setting up a Vendor (Supplier) and Internal Audit System - Need help Internal Auditing 4
U Approved Vendor (supplier) List Supplier Quality Assurance and other Supplier Issues 8
R Supplier/Vendor Surveys (360) Supplier Quality Assurance and other Supplier Issues 1
B Vendor (Supplier) Evaluations and Reports Supplier Quality Assurance and other Supplier Issues 11
Q AS9120 Vendor of ESD Monitoring Equipment needs to be in the Approved Supplier List? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P Supplier (Vendor) Evaluation Criteria - IATF 16949 Cl. 8.4.1.2 IATF 16949 - Automotive Quality Systems Standard 1
S Vendor Control for Customer Designated Supplier ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L What to look for in a Vendor (Supplier) Evaluation for AVL ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
O Vendor (Supplier) Responsibility - Re: Quality Audits 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Evaluating Vendor (Supplier) Products using SQC Statistical Analysis Tools, Techniques and SPC 6
M Difference between Vendor List and Supplier List Quality Manager and Management Related Issues 20
M Documenting Vendor (Supplier) Issues Document Control Systems, Procedures, Forms and Templates 4
E What are Validation Requirements for Vendor (Supplier) Processes Supplier Quality Assurance and other Supplier Issues 5
H Medical Device Vendor (Supplier) Audits - Foreign Languages and Translations General Auditing Discussions 7
L Access to Hospitals - Vendor (Supplier) Credentialing Misc. Quality Assurance and Business Systems Related Topics 1
K Approved Vendor (Supplier) List and Supplier Evaluation Supplier Quality Assurance and other Supplier Issues 16
G Auditor Requirements - AS9100 Vendor (Supplier) Audits Quality Manager and Management Related Issues 2
N Using a Vendor's (Supplier's) Quality System ISO 13485:2016 - Medical Device Quality Management Systems 7
Q Vendor (Supplier) Quality Plan vs. Our QMS? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
I Supplier (Vendor) Contract Review Process Contract Review Process 11
M Do we need to conduct Vendor (Supplier) Evaluation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
P Calibration Vendor (Supplier) Performance and Expectations General Measurement Device and Calibration Topics 8
T AVL (Approved Vendor List) Supplier Listing - ISO 13485 Requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
T Diversity Vendor (Supplier) Requirements for Tier 1 and 2 Companies Customer and Company Specific Requirements 3
N Acceptance of Supplier to AVL (Approved Vendor List) - How long? Supplier Quality Assurance and other Supplier Issues 9
D Template for Vendor (Supplier) Qualification ISO 13485:2016 - Medical Device Quality Management Systems 26
N Vendor (Supplier) Notification template Document Control Systems, Procedures, Forms and Templates 7
F Vendor (supplier) for ISO 13485 Medical Devices Co. minimum QA System ISO 13485:2016 - Medical Device Quality Management Systems 3
J New Vendor (Supplier) Certification & AQL Question AQL - Acceptable Quality Level 1
R Approved Vendor (Supplier) List contain Vendor Evaluation? Supplier Quality Assurance and other Supplier Issues 6
R Nonconformance Material - Return to Vendor (Supplier) Procedure Nonconformance and Corrective Action 4
S Are vendor (supplier) quotes records that must be saved (controlled)? Records and Data - Quality, Legal and Other Evidence 22
T Vetting a potential calibration vendor (supplier evaluation) General Measurement Device and Calibration Topics 7
K Auditing the Internal Vendor (Supplier) Management Process Supplier Quality Assurance and other Supplier Issues 2
F Vendor (Supplier) Survey template needed Supplier Quality Assurance and other Supplier Issues 5
Z Ring Gage Calibration Sizes Shrunk with New External Vendor (supplier) General Measurement Device and Calibration Topics 16
P Vendor (Supplier) Management in TS16949 General Auditing Discussions 4
S Auditor recommends better Vendor (Supplier) Auditing Supplier Quality Assurance and other Supplier Issues 20
S Is there a Vendor (Supplier) Preventive Action? Preventive Action and Continuous Improvement 9
R Approved Vendor (Supplier) if Customer Pays Sub-tier Shipping Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
J Should the term "Supplier" or "Vendor" be used within procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S Staff Augmentation Vendor (Supplier) - Performance Evaluation (rating & index) Supplier Quality Assurance and other Supplier Issues 9
D How can a vendor (supplier) with no third party certification be approved? Supplier Quality Assurance and other Supplier Issues 1
R Definition What is exactly meaning of word between "Supplier" and "Vendor" ? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
Steve McQuality How to Determine Critical Supplier/Vendor Supplier Quality Assurance and other Supplier Issues 15
A Vendor (Supplier) Evaluation of Service Providers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Vendor (Supplier) Approval Procedure - Scope of the procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Vendor (Supplier) Satisfaction Survey questionnaire Supplier Quality Assurance and other Supplier Issues 5
Q Do I have to qualify my approved vendor (supplier) status? Supplier Quality Assurance and other Supplier Issues 2
O Certificate of Compliance for a Vendor (Supplier) - Looking for an example Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
