G
Hi
I have to pull a plan together to validate / verify glue dispenser units for the bonding of various silicone joints to tubing. I will have 10 dispensers going into production for approximately 12 different joints / components. I'm trying to work out how best to approach this.
The dispenser is a constant flow of glue that the operator inserts the tubing into the glue "waterfall". I therefore cannot perform a capability analysis on the volume of glue dispensed. Also, all bonded components will be subject to 100% inspection post the bonding process.
Do I perform a TMV / Gage R&R on each component - 10 separate TMVs - to verify the bonding process is successful?
Once I've passed the TMV do I perform it on each dispenser or if they are all the same model can we "assume" (I know...) that the other dispensers will provide the same result?
Or do I perform a TMV on each dispenser using a different component for each one?
Thank you in advance for any help / guidance with this.
