Verification/release medical device modules
Belen Sanchez
I have a doubt about verification/release of a medical device in the place of operation.
Our medical device is a class IIa and because is so bigger, in our facilities we can only verificate it by moduls, not like a final product (assembled). Only when the device is installed at hospital, we can verificate its perfomance. This final verification is made by a third person (technical service of our distributor).
My question is when the release of the medical device is done by the manufacturer (our company)? now we do it with the device not assembled (before leave our facilities) but I'm not sure if this way will change or not with the new 2017/745 MDR.
Thanks a lot
yodon
I think you may be talking to different activities here.
Design verification is intended to demonstrate your design has implemented the requirements correctly. You certainly wouldn't want to defer this activity to when you're installing the product (nor would that be legal since you wouldn't have been able to get through any pre-market clearance requirements without doing so!). There is no requirement that design verification be done on a fully-assembled device (although 13485 now talks to interfaces with other devices).
Design validation is intended to demonstrate your design meets user needs / intended use and there is a requirement that validation is conducted on "representative" product. Again, though, you couldn't defer this to installation time since validation must be completed prior to release to customer. This could be done at a customer site but it needs to be quite clear that it's not released for use.
There are separate requirements for installation activities - which is what you're talking about and 13485 talks specifically to your situation:
The organization shall document requirements for medical device installation and acceptance criteria for verification of installation, as appropriate.
If the agreed customer requirements allow installation of the medical device to be performed by an external party other than the organization or its supplier, the organization shall provide documented requirements for medical device installation and verification of installation.
Both design verification and design validation need to be conducted "in accordance with planned and documented arrangements" and so in your case, if you're unable to conduct design verification on finished product, you may want to float your plans by your NB and get agreement that the approach will be acceptable.
Belen Sanchez
Thanks, for clearing, but I'm still with the doubt :rolleyes:
I'm not talking about design phase, this is already verified and validated.
I'm talking about production phase:
1) we verificate that each modul is according to our specifications,
2) the device is released (in a document),
3) each released modul is packaged and shipped,
4) the device is installed in a hospital by a third person under our specifications (verification of assemblied device),
5) it's ready to use
We keep records of all steps, but I'm not sure if we can still doing that according to ISO 13485 and MDR 2017/745, in other words, I don't know how justify how release of asemblied device is before to final verification of the device (assembled device).
kreid
I assume your 3rd party installer carries out some type of installation validation, and maybe there is a customer acceptance test?
The evidence of these final steps should be part of your technical file, and hence, prove that the full assembled device is valid.
yodon
Thanks for clarifying. Sounds like what your doing is about all you can do. Ensure your records show the modules were accepted and then, as @kreid notes, make sure your 3rd party installer captures installation records showing the installation was verified.
Belen Sanchez
Thanks for your comments. Now our Notified Body has told me that with the new MDR it will be necesary the verification of assemblied device before releasing, do you know where is that requirement in the MDR 2017/745?
yodon
Ask them what clause they are citing that's driving this.
I see in Article 15, item 3(a) (the PRRC is responsible for ensuring that):
the conformity of the devices is appropriately checked, in accordance with the quality management system under which the devices are manufactured, before a device is released;
I would certainly think it would be defensible to ensure that each module meets spec and show that if this is the case and installation instructions are followed, the fully-assembled device will meet spec. You might need to do some validation work on the installation process (assembling the modules, considering failures and risks - a pFMEA might be helpful) and have that available for the NB to support your position.
The situation is pretty fluid right now. The NB may be taking a hard-line stance. Hopefully they can come around to some common-sense thinking. I think your best bet is to have the dialog.
Ronen E
Problem Solver
Moderator
Just change the definition so that Release occurs not when you deliver the modules but after installation, including verification is complete. Maybe consider changing your process so that the installer is required to send you a copy of the signed-off installation / whole-device verification, and only then you issue the user a formal document asserting that the device is released for use. The EU terminology has a useful term - Putting into Service (rather than Making Available on the Market). Maybe you can leverage that concept. Please send me a PM if you're interested in me studying your situation in-depth.
A ?820.30(d) Design Output Release - Before or After Verification? Design and Development of Products and Processes 6
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
W Seeking Guidance Verification Test Strategy for Class B Medical Devices IEC 62304 - Medical Device Software Life Cycle Processes 1
NDesouza Verification of Supplier RCCAs Nonconformance and Corrective Action 5
I IATF 2016 - 8.5.1.4 Verification after shutdown due to COVID19 Process Maps, Process Mapping and Turtle Diagrams 1
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
G Supplier flowdown verification of tests and revisions Supplier Quality Assurance and other Supplier Issues 0
G Devices from IQ, OQ or PQ process to be used for verification, validation and summative? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Calibration or Verification? What terminology to use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Bev D Verification and Validation of Measurement Systems Misc. Quality Assurance and Business Systems Related Topics 0
A Our auditor told if we didn't have a patent we would have to do a validation or verification ISO 13485:2016 - Medical Device Quality Management Systems 6
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
D Design Verification - Is testing required? Design and Development of Products and Processes 5
J Verification of purchased product / Alexa as a medical device ISO 13485:2016 - Medical Device Quality Management Systems 6
C Machine Verification Plan Manufacturing and Related Processes 2
A What to do when 100 % verification is not 100 % Manufacturing and Related Processes 5
R Design Verification Documentation ISO 13485:2016 - Medical Device Quality Management Systems 19
D 510K and Changes to Verification and Validation US Food and Drug Administration (FDA) 1
R Design verification for interim design outputs - sampling rationale ISO 13485:2016 - Medical Device Quality Management Systems 2
V Calibration certificate verification Qualification and Validation (including 21 CFR Part 11) 3
Ed Panek Label verification and validation US Food and Drug Administration (FDA) 5
D Testing to failure for design verification Reliability Analysis - Predictions, Testing and Standards 11
D Supplied item design verification Supplier Quality Assurance and other Supplier Issues 5
Ronen E A Rational Basis for Design Verification Design and Development of Products and Processes 5
V Which batches should or could be considered for design validation and design verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 0
R Supplier related drawings and verification of process requirements - Source Inspection AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
R Medical Device Design verification sample prototype Other Medical Device and Orthopedic Related Topics 14
I Medical device Validation/Verification template ISO 13485:2016 - Medical Device Quality Management Systems 1
G KPC & KCC verification and updates FMEA and Control Plans 15
APHX02 Thread Roll Process Verification w/in AS9100 (i.e. BSP-F-69/AS8879) Manufacturing and Related Processes 2
R Plan to Volvo Cars for capacity verification in Phase 3 of PPAP Customer and Company Specific Requirements 3
F AS9100 D - Verification of purchased product - Sheet metal and aluminum extrusion stock AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 2
Prashant G AS9100 Requirement - Verification of characteristics results with drawing requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 13
S Testing (Evaluation of) and Verification of Employee Color Vision Human Factors and Ergonomics in Engineering 19
I Bench Testing & Pre-verification vs. Formal verification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
M Does anyone has a good verification and validation plan template? ISO 13485:2016 - Medical Device Quality Management Systems 3
Sidney Vianna Informational AS13100 A - Delegated Product Verification Training Requirements AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 0
E Sample size for design verification of variable in single use device Design and Development of Products and Processes 19
C ICP versus AA: How to determine appropriate specification for assay method verification Qualification and Validation (including 21 CFR Part 11) 1
S Source of QMS templates including templates for design verification/design validation Document Control Systems, Procedures, Forms and Templates 2
L Document review is a kind of verification? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S VoC (Verification of Conformance) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S DO 178B - What is the difference between review and verification? Federal Aviation Administration (FAA) Standards and Requirements 1
Ed Panek Verification & Validation requirements - Patch that adheres to skin ISO 13485:2016 - Medical Device Quality Management Systems 2
C Deviation in Design verification Other Medical Device Related Standards 6
S "Process Verification" of manual process Design and Development of Products and Processes 2
J Calibration/Verification Records (IATF 16949 7.1.5.2.1) IATF 16949 - Automotive Quality Systems Standard 5
