Verification Test for Hydrogen De-embrittlement?
micking1
#22
Hai,
We are one of the Automotive component suppliers. We had a complaint of screw head(low carbon, cold forged,bought-out from sub vendor) breakage in one of our model. Currently we are perfoming Hydrogen De embrittlement process for the screw to overcome the above said problem, but our customer asks for some type of verification test to ensure that de embrittlement has been done on screws and checking to be carried-out daily i.e., for every lots. Now we are conducting destructive test to find out the torque at which screw head breaks. Can anyone specify en easier test method for ensuring embrittlement is done on screws without breaking the part.
regards,
Guru Prasad
Prasad:
I have been experiencing the same problem from a customer's perspective. We had a batch of screws suddenly start breaking after days of installation. This has required me to learn about the problem.
The other replies are correct about the hydrogen atoms collecting in the screw substrate. According to my research, the atoms begin to find places where they can combine into Hydrogen (H2) mollecules. This increases pressure and then can cause screw failure. The hydrogen will collect preferentially to areas of higher strain. For example, screw heads are never perfectly perpendicular to the screw shaft, or the hole they are being screwed into are not perfectly perpendicular to the surface under the head. This will put a torque on the head, increasing the strain on one side of the screw. The hydrogen pressure builds up there, and that will probably be the site of the initial crack. A lot of this is theory, of course, since there is no way to measure the hydrogen level in the screw. Also, be aware that hydrogen embrittlement may cause screw failure days, weeks or even months after plating.
The standard test for hydrogen embrittlement is to have a plate with holes in it. You put a standard washer under the head, and torque the screw down to some value you think is right. Then you wait 24 hours to see if any heads come off. This is, of course, a destructive test, so you do it on a sample of a batch of screws.
We have come up with a test that is a little tougher on the screw, and which I believe is a good accelerator for screw failure. We make a bar with screw holes drilled and tapped. The surface where the head will seat is machined down at a 3deg. angle from perpendicular to the hole. This causes a reliable strain in the screw. Then we screw it down with a washer, at the torque with which it will be screwed in service. We wait for 24 or 48 hours, then we torque each screw until it breaks. The break force will tell us whether we have a good batch. Batches with bad hydrogen embrittlement will break with almost no torque. Some of the heads just fall off. Good batches will have high torque. The level that is good will be found by testing several batches with known good and bad HE.
I have found that the critical factors for making a good screw are:
1. Minimize the time between the wet baths and the oven. It is best to put the parts directly in the hot oven when they come out of the last bath, but probably before chromate, as the color will be poor if you chromate before bake.
2. The literature that I read indicates much longer baking time. We were having problems at 4 hours of baking, but found the parts much stronger after 8 hours.
3. High hardness screws have the problem worse.
4. Carburized screws have the probelm worse.
Good Luck.
Mike
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
W Seeking Guidance Verification Test Strategy for Class B Medical Devices IEC 62304 - Medical Device Software Life Cycle Processes 1
T ISO 17025 Method Verification - One sided “F” test or two sided “F” test ISO 17025 related Discussions 1
S What is the difference between Verification and Validation of Test Reports? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
O Location of Verification Test Procedures 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
L How do I document the chemical attributes in the Mill Test Report (MTR) verification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Is Ship Test considered Design Verification or Design Validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Checklist for RA and QA Review of DVT (design verification test) for Software Other US Medical Device Regulations 2
A AS9100 - Verification of Raw Material Supplier Test Reports AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
F Medical Device Cleaning Lifecycle test - Developing a Design Verification Spec Other Medical Device and Orthopedic Related Topics 2
E XRF vs. Spark Test for RoHS Compliance Verification RoHS, REACH, ELV, IMDS and Restricted Substances 24
H Verification of a Test Apparatus by using known nonconforming part(s) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
C Raw Materials verification - Melt Flow Test - Resins: Customer not Satisfied ISO 13485:2016 - Medical Device Quality Management Systems 4
J How & how often to perform verification of Test Software of Automatic Test Equipment? General Measurement Device and Calibration Topics 3
F 4.11.1 Test Software Verification ? QS-9000 - American Automotive Manufacturers Standard 1
P Software verification and validation procedure IEC 62304 - Medical Device Software Life Cycle Processes 5
Y SaMD Verification and Validation SOP and Plan IEC 62304 - Medical Device Software Life Cycle Processes 3
S How to perform verification of the Statistical Analysis Software? Qualification and Validation (including 21 CFR Part 11) 3
M Sample record for verification performed by importers before placing a device on the market EU Medical Device Regulations 0
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
M ISO14971:2019 - Verification of implementation and effectiveness of risk control ISO 14971 - Medical Device Risk Management 3
C Stress / Challenge Conditions for Design Verification Testing to Reduce Sample Size 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
A Verification protocol example Design and Development of Products and Processes 2
Q Sampling method for Distributor verification activities EU Medical Device Regulations 1
D Design Verification Sample Size vs Repeats Statistical Analysis Tools, Techniques and SPC 9
S IEC 62304 - Software verification cost IEC 62304 - Medical Device Software Life Cycle Processes 3
T Laboratory Verification after validation ISO 17025 related Discussions 3
D ISO 13485 - 7.3.6 Design and development verification - Do most folks create a separate SOP? ISO 13485:2016 - Medical Device Quality Management Systems 6
T Calibration or Verification -> Cm and Cmk, etc. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
K IEC 62304 compliance - Code reviews as part of verification strategy IEC 62304 - Medical Device Software Life Cycle Processes 5
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
NDesouza Verification of Supplier RCCAs Nonconformance and Corrective Action 5
I IATF 2016 - 8.5.1.4 Verification after shutdown due to COVID19 Process Maps, Process Mapping and Turtle Diagrams 1
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
G Supplier flowdown verification of tests and revisions Supplier Quality Assurance and other Supplier Issues 0
G Devices from IQ, OQ or PQ process to be used for verification, validation and summative? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Calibration or Verification? What terminology to use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Bev D Verification and Validation of Measurement Systems Misc. Quality Assurance and Business Systems Related Topics 0
A Our auditor told if we didn't have a patent we would have to do a validation or verification ISO 13485:2016 - Medical Device Quality Management Systems 6
N Design Verification & Process Validation - Statistical sample sizes Design and Development of Products and Processes 2
D Design Verification - Is testing required? Design and Development of Products and Processes 5
J Verification of purchased product / Alexa as a medical device ISO 13485:2016 - Medical Device Quality Management Systems 6
C Machine Verification Plan Manufacturing and Related Processes 2
A What to do when 100 % verification is not 100 % Manufacturing and Related Processes 5
R Design Verification Documentation ISO 13485:2016 - Medical Device Quality Management Systems 19
D 510K and Changes to Verification and Validation US Food and Drug Administration (FDA) 2
