Verifying a Standard with a Standard using Micrometers
jrose
Greetings everyone :agree:
I have a 6 inch starrett standard that is used to verify a set of micrometers before use. I was wondering if I can verify this with another standard? The other standard is a gagemaker Mictrac. Thanks for any help.
E
erbearica
Re: Verifying a standard with a standard
Hi jrose,
As a calibration technician I personally would say no. If I feel that they are questionable I use my set of certified gage blocks to verify them.
jrose
Hi erbearica. So Then it will be okay to verify them with another standard?
howste
Thaumaturge
Hi Jrose, welcome to the Cove Forums. :bigwave:
I'd say it depends on a number of factors. First, the standard used for verification must be traceable to national or international standards. You also want the standard used to be more accurate than the item being verified. The preference is 10 times more accurate, but 4 times more accurate may be acceptable. So, the 6" standard has to be more accurate than the micrometers, then the Mictrac would need to be more accurate than the 6" standard.
Do you know the accuracy of each one? Does the Mictrac have enough resolution to distinguish the accuracy required?
jrose
Hello howste, The mictrac is traceable back to nist and is accurate out to 5 decimal places. I do not however know what the accuracy of the starrett standard is supposed to be. Thanks for your time
howste
Thaumaturge
As the user of the instruments you have the ability to specify the accuracy needed for each. Look at what the micrometers are used to measure and determine the accuracy required. The 6" standard should be at least 4 times more accurate, and the Mictrac at least 4 times more accurate than that.
If the best you have is a 4:1 (versus 10:1) ratio, you should also pay close attention to the measurement uncertainties reported (I hope) on the calibration certificate for the Mictrac, as this will also help to decide if a 4:1 ratio is enough. Ideally you should also determine the uncertainty of the verification you do on the 6" block.
BradM
The accuracy ratios essentially increase your confidence in the results. If you have a 1 to 1 ratio, then you are almost flipping a coin. :)
http://www.transcat.com/PDF/TUR.pdf
This Transcat document does a pretty decent job of visually showing the value of obtaining high ratios.
I think you should write up a comparison ratio between the stated accuracy of the mictrac, and the required accuracy of the micrometers that you are assessing.
How long have you been using this verification process? Have you noticed any issues? Have your customers reported any failures?
While you do need to assure adequate ratios (gives more confidence in the results), it's more important to establish a measuring system that is valid, and one that will detect when you have a problem. :)
jrose
Hmmm this is more complicated than I thought :tg:. Perhaps its a better option for us to send those standards out to a third party for calibration.
I
Inunez
i believe you are talking about a 6" length rod, correct? in this case, assuming (because you didnt mention anything about a vernier scale) your micrometers measure to a resolution of .001", your length rod should be accurate to .0001". there are plenty of options for measuring length rods, just make sure you adhere to the 10:1 rule if possible. personally i would say you need a surface plate, a vice, and a height gage. hope this is helpful:popcorn:
step30044
Is the Mictrac accurate to 5 decimals OR is the resolution 5 decimals places? You have to be careful when stating accuracy.
K Verifying gas tight glass syringe used for making standards General Measurement Device and Calibration Topics 4
D Tolerance when verifying an analytical balance General Measurement Device and Calibration Topics 3
L Verifying training effectiveness for procedure changes ISO 13485:2016 - Medical Device Quality Management Systems 4
X Heat Treat - Verifying mechanical properties on heat treated material per the ASTM Manufacturing and Related Processes 6
F Checking Gages In and Out and Verifying Calibration Status Calibration and Metrology Software and Hardware 8
G Verifying Calibration of Thermocouples at different Temperatures General Measurement Device and Calibration Topics 9
G Acceptance Criteria when Verifying a Gauge General Measurement Device and Calibration Topics 2
G Verifying the Documents we have in place AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Verifying In House Laboratory Weight Sets General Measurement Device and Calibration Topics 2
T What is clause ISO9001:2008 for Acc/Rej Criteria and Verifying QA process Internal Auditing 2
R Verifying Documents have been removed or destroyed once the Retention Period expires ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Basis for Verifying Corrective Actions and Effectiveness ISO 13485:2016 - Medical Device Quality Management Systems 12
AnaMariaVR2 Tracking Water Resistivity - Verifying Reverse Osmosis Water Purification Misc. Quality Assurance and Business Systems Related Topics 3
J Verifying the Effectiveness of Corrective Action - Challenge with an external auditor Nonconformance and Corrective Action 16
D Difficult Inspection Level/AQL - Verifying it is the correct part AQL - Acceptable Quality Level 5
N Sampling Plan for Verifying Inventory Status Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Different Methodologies for Verifying Legal Compliance Under ISO 22000:2005 Food Safety - ISO 22000, HACCP (21 CFR 120) 5
T Calibrating or Verifying Metal or Steel Tape Measures General Measurement Device and Calibration Topics 195
B Are there any guidelines / procedures / books to verifying a new equipment? Manufacturing and Related Processes 1
P Verifying Applied Torque General Measurement Device and Calibration Topics 11
P Verifying improvement results - Indication that controls have worked Statistical Analysis Tools, Techniques and SPC 5
C Need help verifying certification for 3000 psi pressure gauge General Measurement Device and Calibration Topics 3
C I need help verifying formula's in a database for LCL UCL Cp Cpk PPk Statistical Analysis Tools, Techniques and SPC 14
B Verifying Accuracy Automated Measurement Device - Width of a strip of steel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
I Verifying our process to approve suppliers for indirect material Supplier Quality Assurance and other Supplier Issues 2
T Closing Out Corrective Actions and Verifying their Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
S Corrective Actions - Specifically closing out and verifying effectiveness Nonconformance and Corrective Action 30
SABRINA DJILALI SAIAH Implementation of the ISAS-MEDIA 9001 standard in a TV channel ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
D Which ISO Standard to purchase? ISO 13485:2016 - Medical Device Quality Management Systems 7
C Standard -Machinist Handbook Customer Complaints 4
N EN 813, EN 12277, EN 1497 - Testing some harness prototypes to an EN standard Various Other Specifications, Standards, and related Requirements 0
R Remote Audits for ISO 9001 (or any other standard) General Auditing Discussions 31
S Shore A hardness Tester Acceptance Criteria Standard Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
Sidney Vianna What ISO Standard (under the TC 176) supports the UN Sustainable Development Goal #10? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 11
John Broomfield Vote - Should ISO9004 Become a Requirements Standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Q EN ISO 13485:2016/AC:2018 - AC:2018 being stated in the applicable harmonized standard listing Other ISO and International Standards and European Regulations 1
J SAE J1739 standard IATF 16949 - Automotive Quality Systems Standard 2
Marcel DS LV 123 - BMW, AUDI, Mercedes Standard VDA Standards - Germany's Automotive Standards 1
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
M FDA News FDA Releases Draft Guidance Clarifying Application of ISO 10993-1 Biocompatibility Standard Medical Device and FDA Regulations and Standards News 0
Y UL 1998 Standard: software classes Software Quality Assurance 0
