Vernier Calibrations & more
mpfizer
We recently had an ISO 13485 2016 change audit. The NB auditor pointed out that we should increase the calibration frequency of verniers that we use daily from once in a year to once every quarter . There was no proper justification given . He just stated that for daily use instruments the validation frequency of one year is too long.We have not had any problems with these instruments for last more than three years .
What should we do ? As our cost go very high we have 100 such instruments
Can we do some verification or validation ourselves every quarter and if yes what would be procedure. We are just checking OD . ID and depth with these instruments.
Any help would be highly appreciated.
Michelle
re: Vernier Calibrations & more
The auditor is using bias to make such comments. What should happen is that the previous calibration data should have been reviewed to determine the condition of the calipers the last time they were calibrated - the 'as found" condition data. You could still do that to disprove the auditor's comment.
In reality, calibrations shouldn't be based on calendar but on use.
Marc
<snip> He just stated that for daily use instruments the validation frequency of one year is too long. <snip>
Either your auditor or you are probably mixing up terms.
Remember - Validation of a measurement device is not the same as the calibration of a measurement device, and verification of a measurement device is also not the same as either calibration or validation.
Validation - A gage R&R study will tell operators if the measurement system is acceptable for its intended use.
Calibration - See: Verification vs. Validation vs. Calibration - What is the difference? (See Hershal's response in post #4) - "Calibration" is comparison of a measurement device against a known standard and adjustment if necessary.
Verification - Same link as the calibration link above. A check against a reference standard, usually done daily or weekly on daily use instruments, especially those used on critical measurements.
Also see: Calibration vs. Verification of Calibration vs. Verification - Definitions and Calibration vs. Verification - Definition of
dwperron
You have calibration records on these 100 or so verniers.
Analyze their calibration history - what percentage of these were found to be in tolerance when calibrated?
If you find that say about 95% of them are found in tolerance then you have them at a valid calibration interval, there is no reason to decrease it. In fact, you would have justification to extend the calibration intervals.
On the other hand, if you had less than 85% in tolerance (not a hard and fast number here, just a suggestion) you should be reducing the calibration intervals.
Everything these days is based on a risk assessment. How much would it hurt you if 5%, or 25%, or whatever of your measurements are questionable? How critical are these measurements to your processes? If you calibrate verniers to 0.001" and the measurement they are used on has a 0.01" tolerance there will likely be little risk if a vernier is out of tolerance.
ScottK
Not out of the crisis
I agree that this is a biased comment.
a "should", if you will.
did he write it as a finding or OFI?
As the others have said - look at the past data. If they are always in spec "As found" then your interval is fine.
If they need frequent recalibration then you should take action.
Scanton
Wearer of many hats
We have about 50 digital verniers on our system, the majority of which get used multiple times a day. I calibrate mine every six months as I can then detect measurement variation long before it becomes a problem or the gauge fails calibration. They used to be calibrated annually but I found that a gauge could be ok one year and could then fail calibration the next. I have not had this since I have been calibrating them every six months (about 5 years ago).
Agreeing with what has been said previously, my six month calibration cycle is set that way because it works for me and not because an auditor arbitrarily told me to do it that way, in fact I have had quite the opposite experience with auditors asking me why I do it so frequently and not annually like many of the other companies they have visit.
C Teaching Metrology - Vernier vs Digital General Measurement Device and Calibration Topics 8
S Calibrating our own equipment, can we? Micrometers to calibrate vernier calipers General Measurement Device and Calibration Topics 13
C Micrometer and Vernier Caliper simple calibration process General Measurement Device and Calibration Topics 8
A MSA for Vernier used rarely Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
B Please review my Vernier Caliper Gauge R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
V Gauge R&R on Vernier Calipers used to Measure 5 CTQ Features Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
F Adjusting Digital and /or Vernier Calipers General Measurement Device and Calibration Topics 2
T Vernier Caliper Accuracy Issue - Inside measurements were slightly off General Measurement Device and Calibration Topics 7
A Usage of Calibrated Equipment - Vernier Caliper Misc. Quality Assurance and Business Systems Related Topics 10
S Vernier Calibration Characteristics - OK/NOK? Calibration Frequency (Interval) 9
B Must a vernier caliper and a rule be calibrated according to ISO 9001? General Measurement Device and Calibration Topics 50
R Need of working standard for vernier and micrometer calipers General Measurement Device and Calibration Topics 2
R Self (In-House) Calibration of Measuring Tools (vernier, micrometers etc.) General Measurement Device and Calibration Topics 17
K Technicians Mis-reading Vernier Micrometers General Measurement Device and Calibration Topics 9
V Calibration of a Digital Vernier - Need to check/calibrate/validate all 3 functions? General Measurement Device and Calibration Topics 9
L Best Caliper for Shop Use? Digital vs. Dial Caliper vs. Vernier-type General Measurement Device and Calibration Topics 53
I What is Gauge Capability? Dial Thickness Gage and Digital Vernier Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 17
C Work Instructions for Vernier & Micrometer General Measurement Device and Calibration Topics 9
C Control of Vernier Calipers - Calipers easily switched between operators and lost Quality Assurance and Compliance Software Tools and Solutions 16
A How to Calibrate a Vernier Caliper - Detailed Procedure General Measurement Device and Calibration Topics 25
S OEM full range calibrations vs Validation special test points Medical Device and FDA Regulations and Standards News 0
D Naming of SOP doc's - Specific to Calibrations ISO 13485:2016 - Medical Device Quality Management Systems 2
A Large outside micrometers calibrations General Measurement Device and Calibration Topics 2
S Internal calibrations - Part of an ISO 17025 accredited testing laboratory (Automotive) ISO 17025 related Discussions 16
H Can a calibration lab still use ISO 6789:2003 as guide for torque calibrations Other ISO and International Standards and European Regulations 1
M Calibration Records Requirements for all the Calibrations and Verifications we do General Measurement Device and Calibration Topics 4
K Hexalobe Go/NoGo Gage Calibrations General Measurement Device and Calibration Topics 3
Y Identifying lighting requirements for in house Calibrations General Measurement Device and Calibration Topics 8
C User Measurement Equipment Calibrations In Companies General Measurement Device and Calibration Topics 7
J Appropriate Test Environments for In-Glass Liquid Thermometer Calibrations General Measurement Device and Calibration Topics 2
J Is it possible to train our lab technician to perform balance calibrations? General Measurement Device and Calibration Topics 2
L Is Uncertainty Calculation Mandatory for Field calibrations? General Measurement Device and Calibration Topics 5
M Limited Calibrations - An instrument that will not pass a full calibration, OOT General Measurement Device and Calibration Topics 8
J Performing Internal Calibrations - Dial gauges, micrometers, height gauges, calipers General Measurement Device and Calibration Topics 8
A Quality Audit Advice - Past Due Device Calibrations due to Cal Supplier Issues Quality Manager and Management Related Issues 14
P How to handle Out of Tolerance during Calibrations and exceeded Alert Action Limits Quality Manager and Management Related Issues 4
G Are One-Point ISO 17025 Equipment Calibrations OK ISO 17025 related Discussions 12
D Torque Calibrations - Uncertainty Components Measurement Uncertainty (MU) 3
T Training Employees to Perform Calibrations / Minor Adjustments to Inspection tools Training - Internal, External, Online and Distance Learning 6
L Would like to start in-house calibrations and would like to know requirments General Measurement Device and Calibration Topics 1
J Temperature / Pressure / Vacuum training - In-House Calibrations to save money Training - Internal, External, Online and Distance Learning 13
S MU of Mass & Pressure Calibrations Measurement Uncertainty (MU) 1
D Electrical Calibrations - Uncertainty Components General Measurement Device and Calibration Topics 2
B Room temperature for calibrations on basic equipment like calipers, micrometers, etc. General Measurement Device and Calibration Topics 14
K Subcontracting of Tests and Calibrations - ISO 17025 Sec: 4.5 ISO 17025 related Discussions 11
J Using Outside Accredited Calibration Laboratories vs. In-house Calibrations General Measurement Device and Calibration Topics 10
B Calculating Contributors to MU - Developing MU budgets for in house calibrations Measurement Uncertainty (MU) 7
F Certifying for Calibrations of Network Analyzers - Looking for classes/training General Measurement Device and Calibration Topics 1
A Controlled Environment - Environmental Requirements for calibrations General Measurement Device and Calibration Topics 10
C Bringing Simple Calibrations Back In-House General Measurement Device and Calibration Topics 16
