Version of Medical device safety standard - IEC 60601
P
Pauling
Hi,everybody,
We did the safety test according to IEC 60601-1:1998+A1:1992+A2:1995 to apply CE certificate.Today our client said the the test is not complete and expired.
Since IEC standard is not mandatory,but EN verson is, so i seached the harmonized standard list in EU offical website and found that the version now is EN 60601-1:1900+A1:1993+A2:1995+A13:1996 and except for A13, there are idt IEC version.
What is EN 60601-1 A13 about? Is the test according to IEC 60601-1:1998+A1:1992+A2:1995 expired? And how we could do update test based on the first test result?
Thanks in advance!!
temujin
I don´t know the content of A13, but according to the link below(from which the quote is taken) A13 was incorporated into EN 60601-1 in 1996.
If I understand it right, then A13 is already part of EN 60601-1 provided that your copy is dated after 1996. Take a look at the reference number on the front page of your copy.
http://www.eisnersafety.com/Medical_Device_Sfty_Standards.htm
The second edition of IEC 60601-1 was published in 1988 and was adopted as an EN standard in 1990. Amendments A1, A11, and A12 were added to IEC60601-1 in 1990 & 1991 and were adopted as part of the EN standard in 1993. Amendment A2 is the most important Amendment to date because it added all the requirements to align the standard much closer to the Medical Device Directive Essential requirements (Annex I of the MDD). EN60601-1 was adopted with this amendment in 1995. Amendment A13 was incorporated into EN60601-1 in 1996. The Third Edition of IEC 60601-1 was published December 15, 2005 and will likely be adopted by many national standards organizations in 2006. After that occurs the Certification Agencies will determine how they will certify products to that standard.
By the way, neither IEC nor EN standards are mandatory (unless you are doing business in Brazil).
Are you sure your client is not referring to the 3rd edition of 60601-1?
Hope this helped, otherwise I know there are numerous 60601 competent people here that might help you out.
regards
t.
P
Pauling
Thanks you so much!
You remind me we did the test in Sep. of 2006 that is late for the date of A13 incorporated into EN60601-1 .
However i still don't know the relationship of EN60601-1.90+A1+A2+A13 and IEC 60601-1:1998+A1:1992+A2:1995. Are they equivalence?
I'm sure our client didn't refer to the 3rd version of 60601-1.
And our product is sold to EU, so we have to get CE mark. According to MDD, i think the harmonized standard EN60601-1.90+A1+A2+A13 is mandatory. Refer to my previous attached file, 3rd version of 60601-1 haven't been harmonized yet.
Thanks again!
temujin
Hi again,
IEC 60601-1:1988 was published as a European norm in 1990 under EN 60601-1:1990. So IEC 60601-1:1988 = EN 60601-1:1990.
The harmonized standard with amendments are (as you point out)
EN 60601-1:1990
+ A1:1993 to EN 60601-1:1990
+ A2:1995 to EN 60601-1:1990
+ A13:1996 to EN 60601-1:1990
As far as I know, IEC standards are normally adopted as European norms without changes, so it does not really matter if you use IEC or EN.
I think you need to add A13, but you write "IEC 60601-1:1998". Is the "1998" a typo? You might have a consolidated version of the standard. Take a look at the Reference Number on the standards front page...
regards
t.
P
Pauling
:eek: Sorry.
It's my type mistake. It should be "1988".
Do you mean add the A13 directly on the test of IEC version? Since
IEC standards are normally adopted European norms without changes
However just the same reason, I confuse about A13 . I think maybe i should find the standard A13 to compare with IEC version.
You help me a lot. Thanks so much!!
temujin
No. A13 might be modifying requirements of the base standard.
Just buy A13 and have a look at it...it costs less than EUR 15. Your Notified Body might also be able to help you out.
t.
PS: I had a typo in the sentence you qouted...I have changed it in the post. This should be right:
Marcelo
Just a quickie :
IEC 60601 plus it´s two ammendments are almost equivalent to EN 60601-1 plus it´s three amendments. There´s some minor differences, that´s why the EN is not a EN IEC.
Also, EN standards are not mandatory, the same as with the IEC standards.
K UDI "Version or Model" for Stand-Alone Medical Device Software US Food and Drug Administration (FDA) 6
L Medical Device Software Document released version (article 5.8.4) IEC 62304 - Medical Device Software Life Cycle Processes 7
K Medical Device Software Version Upgrade Regulation Impact 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
M Informational EU – MANUAL ON BORDERLINE AND CLASSIFICATION IN THE COMMUNITY REGULATORY FRAMEWORK FOR MEDICAL DEVICES Version 1.22 (05-2019) Medical Device and FDA Regulations and Standards News 2
O Chinese language version of Medical Devices Directive CE Marking (Conformité Européene) / CB Scheme 3
bio_subbu CDSCO Published Draft version of Medical Devices Guidance Documents Other Medical Device Regulations World-Wide 3
bio_subbu European Borderline Product Guidelines Version 1.5 - Medical Devices EU Medical Device Regulations 1
B Struggling with using the 5.6 version Ford Capacity Analysis Report APQP and PPAP 5
S API Spec.Q1 Standards Version in Purchasing Information Oil and Gas Industry Standards and Regulations 1
Q Version/Revision Control of CAD files Document Control Systems, Procedures, Forms and Templates 2
R Shall a new UDI-DI be required when stand-alone software device's version is updated? EU Medical Device Regulations 1
N Which EN ISO 17664 version compliance to EU MDR? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 3
M When is EN 62133-1 (new version i.e. IEC 62133:2017) mandatory in EU Other ISO and International Standards and European Regulations 3
I Reissuing documents due to missing version / issue numbers Document Control Systems, Procedures, Forms and Templates 3
M Can someone share a scrubbed version of Clinical Evaluation Plan (CEP) EU Medical Device Regulations 8
F Management of Software version while NB reviews Technical file CE Marking (Conformité Européene) / CB Scheme 7
M Harmonised RED Standard ETSI EN 440 - Which Version? Other ISO and International Standards and European Regulations 0
M Informational EU – Manufacturer incident report (MIR) for serious incident- template 2020 (Directives and new regulations) version 7.2 and related documents Medical Device and FDA Regulations and Standards News 2
dgrainger Informational Updated Borderlines manual - Version 1.22 (05-2019) EU Medical Device Regulations 0
A Usable version of MDR in Word format CE Marking (Conformité Européene) / CB Scheme 0
dgrainger MHRA guidance on Virtual manufacturing - version 2 EU Medical Device Regulations 1
M Scrubbed version of a labeling procedure that is MDR compliant wanted EU Medical Device Regulations 3
B QRQC vs JIDOKA - I read somewhere that QRQC is like a French version of JIDOKA Problem Solving, Root Cause Fault and Failure Analysis 2
C Has an amended version of IEC 60601-1-6 TRF been released for use in conjunction with IEC62366-1:2015? Human Factors and Ergonomics in Engineering 0
Sidney Vianna Accessing the Xenforo version of Elsmar via a smartphone Elsmar Xenforo Forum Software Instructions and Help 8
A AS9100 Rev:D in Spanish - where can I find a Spanish version? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
D I heard that there is no new version of ISO 18001 OHSAS after 2017 version Occupational Health & Safety Management Standards 3
M Which Version of 60601-1 to Purchase (IEC, EN, ANSI...)? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M How to get an electronic version of IATF 16949:2016 which is Searchable IATF 16949 - Automotive Quality Systems Standard 8
E CER (Clinical Evaluation Report) MEDDEV Version 4 Template wanted CE Marking (Conformité Européene) / CB Scheme 5
B Where can I find an English version of Japan's PMD Act? Other ISO and International Standards and European Regulations 2
S Pre-release version of the upcoming AIAG FMEA Revision 5 FMEA and Control Plans 1
I ISO 22001 and ISO 22003 French version Food Safety - ISO 22000, HACCP (21 CFR 120) 2
D Referencing Standards in Procedures - Current version or actual? Document Control Systems, Procedures, Forms and Templates 6
R IEC 60601-1 4th Edition - Is a "Red-line" version available? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R Current version of EN62304/A1 IEC 62304 - Medical Device Software Life Cycle Processes 5
Y Which version of ISO 13485 would be considered for MDSAP certificate? Canada Medical Device Regulations 8
G Insights into the 2016 Version of TS16949 (IATF 16949) IATF 16949 - Automotive Quality Systems Standard 74
T Firmware version in EMC report / DoC CE Marking (Conformité Européene) / CB Scheme 1
M Current standard references IEC 60601:1988 instead of current version EU Medical Device Regulations 5
P Is an English version of CFDA YY0664-2008 available? China Medical Device Regulations 3
R Knowing when an EN version modifies the base standard CE Marking (Conformité Européene) / CB Scheme 14
C Registration to the 2015 Version of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J How to document discontinuation or end of life for a software version ? IEC 62304 - Medical Device Software Life Cycle Processes 3
R EU updated borderline manual - version 1.16 EU Medical Device Regulations 2
S How to upload GM's MMOG survey version 4 to GM Powersupply Customer and Company Specific Requirements 3
V Locking in a Standards Version (ANSI Z1.4) Statistical Analysis Tools, Techniques and SPC 1
S Is Revision and Version the same in the Quality Manual? Quality Management System (QMS) Manuals 13
S Queries of new version ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
