Vetting a potential calibration vendor (supplier evaluation)
TJM05
I am new to the Cove. Glad to be here...:cool:
In our process of ISO registration we are looking into using an outside source for gage calibrations. Are there any specific things I should be looking for in a potential vendor (other than accreditation)? Any specific questions to ask? I'm new to ISO and the science of calibration, so any assistance is appreciated.
Thanks,
TJM
Hershal
Metrologist-Auditor
Re: Vetting a potential calibration vendor
The move is completed to obtain further input from other cal users and labs themselves, to hopefully help the poster avoid pitfalls, and to obtain the best solution.
Hershal
Metrologist-Auditor
Welcome to the Cove.
For a cal lab, besides the accreditation certificate, you need to look at the scope of accreditation. This is the part of the document that describes what calibrations the laboratory is accredited for, and therefore considered competent for, to provide to customers.
A laboratory may be able to provide excellent service on other calibrations also that are not under the scope, but those have not been established formally.
The accreditation may be provided by any of six U.S. based accrediting bodies (ABs), and since you are in NY you may also see our Canadian colleagues (SCC/CLAS). The six in the U.S. are IAS, NVLAP, A2LA, PJLA, L-A-B, and ACLASS.
You might want to also obtain uncertainty with the calibrations. However, under the American National Standards refering to the 4:1 Test Uncertainty Ratio (TUR) is also allowed.
Hope this helps a bit.
Joe222
Did PJLA ever get recognized for Calibration? I know they were recognized for accrediting Testing labs, but were still working on getting recognized to accredit Calibration. This was a few months ago, maybe they are now.
Joe222
I just looked it up and they are now recognized for calibration as of May 31.
TJM05
Please explain "refering to the 4:1 Test Uncertainty ratio". I'm a newbie to this stuff, so please forgive my over inquisitiveness, lack of understanding of terminology, etc.
TJM
Joe222
Re: Vetting a potential calibration vendor (supplier)
TUR is taken from the NCSL/ANSI Z540. The 4:1 ratio is that the standard used should have an uncertainty 4 times better than the unit under test.
For 17025 Accredited calibrations, you need the measurement uncertainty.
Hershal
Metrologist-Auditor
TMJ05, no sweat, we are here to help.
Joe222 is right in that it is a ratio. This used to be known as Test Accuracy Ratio or TAR.
The definitions have changed as well. Joe is also right about Z540, which has three versions.
ANSI/NCSL Z540-1-1994 (now retired) in Paragraph 10.2.b describes, allows, and for some applications requires use of the 4:1 TAR. This Standard is still in common use and is likely to remain so for the foreseeable future. This Standard is literally the combination of two previous Standards. ISO Guide 25 takes care of Part 1 and MIL-STD-45662A takes care of part 2, both long since retired.
ANSI/NCSL Z540-2-1997 is also known as the "U.S. GUM" or Guide to the Expression of Uncertainty in Measurement, and while exceptionally informative and technically correct, it is also the most boring document in the history on Mankind in my opinion. But for Metrology professionals, Z540-2 or the ISO GUM is indispensable.
ANSI/NCSL Z540.3-2006 is the current replacement for Z540-1 and Clause 5.3 (and sub-Clauses) describe the Test Uncertainty Ratio known as TUR.
Joe is perfectly correct for TAR, but the TUR is now defined as "The ratio of the accuracy tolerance of the unit under calibration to the uncertainty of the calibration standard used." (where: Uncertainty is expressed as expanded uncertainty at approximately 95% confidence) And this is a two-sided approach to account for various ways of expressing tolerances.
Now, if this is confusing, don't stress, you are not even remotely close to being alone, many are.
If your organization is open to assuring ou have the training that you will find useful, on a short notice, there is training in uncertainty at NCSLI in about 12 days in San Antonio, website: www.ncsli.org
If like most they prefer to plan a bit, then other organizations also provide training in ANS/ISO/IEC 17025:2005 and uncertainty among other topics. There are calendar entries and notes describing upcoming training.
Hope this helps.
S Potential Equalization Conductor vs Functional Earth Terminal IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
G Self Assessment Audit from a new potential customer General Auditing Discussions 3
T Potential Off-Label Use question 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
M Informational USFDA – Efforts to evaluate materials in medical devices to address potential safety questions Medical Device and FDA Regulations and Standards News 0
M Medical Device News TGA Consultation: Potential reclassification of active medical devices for diagnosis and patient therapy Medical Device and FDA Regulations and Standards News 0
M Medical Device News Letter to the health and care sector: update on preparations for a potential no-deal Brexit Medical Device and FDA Regulations and Standards News 0
G Options for failing a VDA POTENTIAL audit VDA Standards - Germany's Automotive Standards 2
S FMEA column column ''therblig motion'' for a given potential failure FMEA and Control Plans 12
M Should Potential Customer Complaint Outcome Define Registrar NC Rating? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
C Selecting potential internal auditors Internal Auditing 3
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
L "Potential" Essential Performance in IEC 60601-2-54 (Definition) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
kedarg6500 Potential Effects of Failure(s) FMEA and Control Plans 23
R Need Help on Analysis: How to know potential causality model from historical data Problem Solving, Root Cause Fault and Failure Analysis 5
J Potential Customers Asking for EIRs / 483s when evaluating a CRO for future work US Food and Drug Administration (FDA) 2
G ISO/TS 5.6.2.1 - Potential Field Failures on OEMs IATF 16949 - Automotive Quality Systems Standard 3
P TS 16949 Clause 5.6.2.1 - Review of Potential Field Failures IATF 16949 - Automotive Quality Systems Standard 16
J CRB (Certification Registration Body) Notification of Potential Escape AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
Marc LinkedIn Accused Of Secretly Selling Members Professional Data To Potential Employers World News 9
N Scouting Potential Suppliers - Strategy and Tactics Supplier Quality Assurance and other Supplier Issues 7
Colin Interesting Discussion Potential Issues for Auditing ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 84
B Providing a potential Customer with a Sample Medical Device in Brazil Other Medical Device Regulations World-Wide 1
Ron Rompen Wording of potential cause of failure in a PFMEA FMEA and Control Plans 8
F Supplier Quality Engineer Beginner - Potential Interview Questions Supplier Quality Assurance and other Supplier Issues 3
A Potential Equalization Conductors IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
GURU SDI VDA 6.3 Hand Book - Two sections for Potential Analysis VDA Standards - Germany's Automotive Standards 1
H Identifying Potential Automotive Suppliers before Developing New Products Supplier Quality Assurance and other Supplier Issues 2
T Attribute (Check Fixtures) - Breaking the Ice with Potential Customers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Lessons Learned Identification - Potential Preventive Action Responsibilities Preventive Action and Continuous Improvement 4
Hershal Metrology Careers - Potential good Paying Jobs in the Science of Measurement Field Career and Occupation Discussions 1
C List of Potential Hazards Definitions in Annex E of BS EN ISO 14971:2009 ISO 14971 - Medical Device Risk Management 4
Mikey324 Assessing Potential Field Failures (TS 16949 Requirements) Quality Manager and Management Related Issues 5
K Observation - Potential Nonconformity - How to address this Audit Finding? General Auditing Discussions 9
8 Introducing a Balance Line - Identifying potential future pitfalls etc. Lean in Manufacturing and Service Industries 2
M Analysis of Potential Field Failures - Impact on Quality, Safety or the Environment Management Review Meetings and related Processes 10
Q Potential Field Failure as Mgmt Review Input for TS16949: How to meet the clause? IATF 16949 - Automotive Quality Systems Standard 1
hogheavenfarm Potential Employer Questions Reason for Leaving Career and Occupation Discussions 37
B Mining Nonconformance Data for Potential Missed Audit Findings Misc. Quality Assurance and Business Systems Related Topics 2
M Correlation between 2 Variables - Potential X's that might affect yield percentage Quality Tools, Improvement and Analysis 5
M PFMEA (Process FMEA - Potential Causes and Failure) - Operator's Role FMEA and Control Plans 11
E Tips on how to notify customers (and potential ones) of ISO Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Procedure to Identify Potential Emergency Situations and Accidents Miscellaneous Environmental Standards and EMS Related Discussions 4
S Should an auditor document potential nonconformities in the audit report? General Auditing Discussions 41
N Definition Nonconformity vs. Potential Nonconformity - Difference? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 3
automoto ISO TS 16949 Management Review Input - Potential Field Failures IATF 16949 - Automotive Quality Systems Standard 10
Chennaiite FMEA Severity Rating for Potential Manufacturing Effect mentioned in the FMEA manual FMEA and Control Plans 9
J Google Offers Peek at Operating System, a Potential Challenge to Windows After Work and Weekend Discussion Topics 2
J Sources of Potential Measurement Variation for Brinell Hardness Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L ISO 17025 4.12: "...potential sources of nonconformities...shall be identified." ISO 17025 related Discussions 21
