Viscometer Gage R&R (GR&R) Questions
jmarcus - 2008
I'm fairly new to the GR&R process. I've ran two so far with not great results. I've ran a Digital Caliper and a Viscometer. My question is about the viscometer
We don't have many lots of product to choose from, so I figured if I can't have 10 samples and 3 trials I would do 3 samples and 10 trials.
Our product is solvent based, has a tolerance of +/- 30 mPa and it seems to change over the 20 minutes it takes to measure it, not much 2-3 units, but still changes.
I plug it into our GR&R spread sheet and I get numbers in the 40-50%.
I do not understand how the statistical date is working. I would think a 5% change could still be controlled with us knowing that it will change slightly over time.
Plus all the readings were well within Tolerance.
Is there a trick in running GR&R on a product that isn't 100% stable?
Thank you in advance.
David DeLong
Re: GR&R Questions
In some situations, a R & R study may not be appropriate and your may be in one of those situations. Statistical studies on variable gauges are to reflect variations in the gauges and I would perform a stability study on this gauge rather than an R & R.
Get a sample and measure it every day for 25 days. Plot it on an individuals and moving range chart and calculate the control limits. Are your readings within the control limits?? Great! Now that is easy.
jmarcus - 2008
Re: GR&R Questions
How is measureing the sample over 25 days different then measuring it 25 times over a single day and running those charts?
Also would these types of test be exceptable for an external TS16949 audit?
Thanks again.
David DeLong
Re: GR&R Questions
Thanks again.
Running 1 per day for 25 days is different from 25 time during a day since we have a greater interval between using the gauge. We could run 25 consecutive readings but that is not really a good feel of the gauge over time.
Stability studies are included in the MSA 3rd edition and I would always have those handy when 3rd party audits are involved.
Some gauges, such as hardness testers, spectrometers, and viscosity measuring systems are not conducive to R & R studies. One would probably have difficulty getting a good R & R study if your samples are are not much different from each other. One must have samples are both ends of the specification limits to achieve a good result.
I would change it to a stability study.
When you state that the readings change over the 20 minutes, does this mean that one measurement takes 20 minutes, or that it takes 20 minutes to perform all of the R&R measurements?
Does the product eventually stabilize after 20 minutes, or does it continue to change?
You would definitely need to use the method for a destuctive gage study. If the product eventually stabilizes, perform the measurements after it has stabilized. If does not stabilize, you may need to get inventive and perform a regression study versus time, then apply a correction factor to your measurements based on the time.
Please review earlier posts in this forum for a discussion on collecting samples for an MSA based on whether the gage is used as an inspection gage, or as a process control gage. David made a good point about the effect that the variation of your test samples has on your results. Make sure that you are using the correct metric (P/T Ratio or %GRR) and that your samples represent the process variation if %GRR is used.
Please note that a stability study is intended to assess the stability of the measurement system. The basic assumption is that the standard itself is stable and unchanging. This seems to violate that assumption. A similar study would be worthwhile to assess the stability of the product over time, but this has a different purpose than a gage stability study.
jmarcus - 2008
It takes about 20 minutes to take all the readings, and it never truly stabilizes. The solvent changes the viscosity slightly over time. Internally during production check it every two hours and reset the viscosity if it's out of our specification.
Are all of these statistical methods found in the MSA / SPC books?
Thanks again
G
Geoff Withnell
I would strongly recommend "Evaluating the Measurement Process" by Donald Wheeler. I had a similar problem in measurement some years ago, and his work was very useful in understanding how to evaluate our measurements. It is not available from Quality Press, but I believe Amazon can get it.
Geoff Withnell
Ron Rompen Laboratory Viscometer Recommendations Calibration and Metrology Software and Hardware 4
M Viscometer MSA / GR&R failure - High Variability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
D Brookfield Viscometer: Correlation Centipoise to Seconds - Centistoke General Measurement Device and Calibration Topics 2
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
S Type 1 Gage R&R or something else? Reliability Analysis - Predictions, Testing and Standards 6
R Gage R&R Excel templates Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Gage R&R with more than 3 appraisers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Definitive answer on Type 1 vs Type 2 vs Type 3 Gage Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
V Gage Management and Gage R&R Software General Measurement Device and Calibration Topics 1
D Gage R&R Study on Load Cells - Large chemical blending tanks IATF 16949 - Automotive Quality Systems Standard 1
S Gage R&R on alloy Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
8 Need Help - Runout - Function Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
L Gage R&R studies for identical Devices - Need to confirm the requirement to perform them Reliability Analysis - Predictions, Testing and Standards 2
G Stab Pin Size For Check Gage Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
E Functional Gage for TOP applied at RFS Design and Development of Products and Processes 5
F No reproducibility Error in Gage R&R? Reliability Analysis - Predictions, Testing and Standards 4
M Template for Attribute Gage R & R wanted Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
G Warning about Deltronic Gage Pins - The "Certification of Accuracy" document General Measurement Device and Calibration Topics 13
A Gage type 1 study on CMM Capability, Accuracy and Stability - Processes, Machines, etc. 2
Q Gage R&R for Instant Measurement Machine Manufacturing and Related Processes 6
M Gage R&R with large inter part variance - Torque Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
D Do we need normal data for gage r&r studies? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R&R Standard Deviations Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J Informational Gage R&R: Swapping operators Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Gage R & R for large amount of inspections IATF 16949 - Automotive Quality Systems Standard 10
S Ring Gage Thermal Expansion General Measurement Device and Calibration Topics 4
L Gage R&R for test precision or uncertainty prediction? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Minor diameter of threaded ring gage General Measurement Device and Calibration Topics 1
A Does Torque Gage Need Validation? Reliability Analysis - Predictions, Testing and Standards 4
J Ignoring a Failed Gage R&R and upcoming external audit IATF 16949 - Automotive Quality Systems Standard 22
