Vision System Recommendations - Sheet metal fabrication industry
jdtrixler
I am a new QM in a sheet metal fabrication industry. When I first started I remember working with a vision system that was like a big copy machine, it checked the parts like a scanner. We are looking at buying a vision system to check flat parts, but the one that is currently being recommended is basically a non-contact CMM. Does anyone have any recommendations on what might be easier or cheaper? I am looking for a bed size around 36" by 36". Thanks in advance for all of your help!
Roto_Manic
Hi JD,
It really boilds down on what you are trying to "detect" with the vision system. For example, we are using ours to insure componentry is there as well as checking on orientation of certain tubes. We compared a National Instruments model as well as a Banner system. We chose the NI model for adaptability and ease of programming.
Do a web search for National Instruments and Banner Engineering for some helpful hints. I'd post the url, but I'm not quite high enough on my post count yet;)
CarolX
Hi jdtrixler and congrats on your first post!
I also work in the sheet metal industry. We use FabriVision for flat part inspections on first piece approvals off the punch press. I believe that their new unit is laser based, but without improvement in accurancy. We have had our unit for about 8 years, without too many major issues. The unit is designed to be used on the shop floor, and it works fine in that enviroment. I don't know what the accuracy of other vision systems. Fabrivision has only +-.002. If you are running FabriWin for punch press programming, all that is required is a download of the part file - no programming by shop or inspection personel required.
Hope this helps a bit!
ScottK
Not out of the crisis
welcome to the cove!
I've worked with scanner type device called a Romidot.
http://www.romidot.com/romidot/home.asp
I used the Romishape DT and used it in vinyl extrusion to check the profile dimensions.
The Romishape is smaller than 36x36, but I think they make bigger models.
Nice tool.
jdtrixler
FabriVISION is the one that I had used in the past, thanks. I am getting quotes and info from all of the suggestions that have been posted. Thank you all for your help. Most of our tolerances (most features ±.060) will be fine with an accuracy of ±.002, so that should not matter. We are mainly looking to be able to check more parts to ensure that our laser is not having any issues, and that the programs were copied properly.
Crash Not
I have been using a Micro-Vu video measurement system for about 8 years checking tool and die sections and components. Some tolerances are as tight as +or- .0001 in. It has a work envelope of 24x18x12 in. and is programmable.
Cost was about 45K eight years ago. I am very satisfied with performance, realibility, support, and ease of operation.
P Looking for recommendations for an automated vision measuring system Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
D Choosing a Vision System - Recommendations for a User Friendlier System Quality Tools, Improvement and Analysis 3
B Camera Vision System Measurement System Analysis (MSA) Reliability Analysis - Predictions, Testing and Standards 3
Proud Liberal Setting up Prolink's QC-Gage to a Keyence IM-6225 Vision System Statistical Analysis Tools, Techniques and SPC 2
P Vision Measurement System - Software Program Qualification Qualification and Validation (including 21 CFR Part 11) 6
M Vision Inspection System Validation Capability, Accuracy and Stability - Processes, Machines, etc. 5
T MSA on Camera Vision System and other Process Measurement Systems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Camera Vision Measurement System Gage R and R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
K Vision System Camera Adjustment - Change Verification? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
N Process Validation on Vision Inspection System Capability, Accuracy and Stability - Processes, Machines, etc. 8
M CPK and MSA for Vision System - Example PSW Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Which Manual Vision System to Buy Manufacturing and Related Processes 5
2 How to GR&R a Vision System to measure features in silicone ie. jello Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Information on Starrett Galileo Vision Measurment System model AV300 requested Calibration and Metrology Software and Hardware 2
3 Vision System Optical Calibration Standard General Measurement Device and Calibration Topics 6
I Part Variation for Gage R&R of Vision Inspection system Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
I Gage R&R on a Programmed Vision System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
S GR&R (Gage R&R) for an Optical Comparator or Vision System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Verify Accuracy for Validation of CNC Starrett Vision System Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Vision System - Camera vs. Sensor to perform 100% EOL Inspection Quality Tools, Improvement and Analysis 2
C Multiple Fixture Automated Vision System GR&R (Gage R&R) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Vision system - how critical is part set up? General Measurement Device and Calibration Topics 4
S Can we comingle Gauging Vision System and 3 Point Micrometers? Manufacturing and Related Processes 2
B Automated Vision Inspection System MSA (Measurement Systems Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Advice on Handling a Camera Vision System Calibration Master General Measurement Device and Calibration Topics 7
C Vision System which verifies the correct part is present - Calibration / Verification Calibration Frequency (Interval) 9
O GRR (Gage R&R) Method for Camera Vision Inspection System Hardware and Software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 19
D MSA for Vision Sorting Equipment (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
J SSQR-01 Vision Requirements- Color Blindness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B CQI-15 Weld Inspector vision reviewed annually Various Other Specifications, Standards, and related Requirements 5
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
M (How To) Getting Data From Vision Machine To Reporting Software Misc. Quality Assurance and Business Systems Related Topics 0
S Testing (Evaluation of) and Verification of Employee Color Vision Human Factors and Ergonomics in Engineering 19
J Manual Vision CMM Calibration General Measurement Device and Calibration Topics 7
M Medical Device News FDA News - 26-09-18 - FDA Reveals Vision for the Transition to ISO 13485 Other US Medical Device Regulations 1
B 7.1.5.1.1 MSA for inline dimension vision inspection equipment IATF 16949 - Automotive Quality Systems Standard 5
Q Really do they add value (Vision, Mission, Values)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Bar Lights vs LED-606 in vision inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R AC 7120 Vision and Color Blindness Testing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
D Automated Vision Systems - Cost, Value and Payback of Implementation Statistical Analysis Tools, Techniques and SPC 2
Sidney Vianna Vision 2050 - Utopia? Can we change so many paradigms in 40 years? Sustainability, Green Initiatives and Ecology 4
Sidney Vianna The ISO 9000 ecosystem - a clear(?) vision for the future of the ISO 9000 family ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
R Starrett AV612 (combo vision and touch probe) Galileo Instrument Software Validation General Measurement Device and Calibration Topics 3
R How to Validate Vision Inspection Systems Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
Z How to Establish Quality Policy Based on Vision of Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Sidney Vianna Is the ISO TC176 fulfilling its Vision & Mission? ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 3
J Customer Complaint Corrective Action Response - 100% Vision Inspection Customer Complaints 9
W What is difference between the company policy & company vision or strategy Misc. Quality Assurance and Business Systems Related Topics 9
Sidney Vianna ISO TC's 176 & 207 & other Stakeholders Joint Vision ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
