Visual Inspection: Can Visual Inspectors be Evaluated?
cortiz01
Hello everybody!
My question is if someone knows a method to check if visual inspectors are ok to do the job or not. In my plant we have a lot of people checking visually and we still have defects detected after this inspection, I know 100% visual inspection is not 100% effective, but I would like to know which inspector is better than other...:thanx:
Coury Ferguson
Moderator here to help
First, you need to verify their competency, second, if they are color blind, third, that they have reasonable vision acuity to a known standard.
That would be the first three things that I would evaluate them on, in my opinion.
silly girl
Couldn't you do a measurement system evaluation? I am no statistician, and it probably depends on but I think the process is something like this:
  • Take a random selection of parts from production
  • Have each inspector inspect each part at least twice (making sure they don't know they are re-inspecting the same part)
  • Assess the variation between inspectors and within inspectors
Hmmm well, anyway I don't know if this could work for attribute inspection... perhaps a statistician will reply.
Silly Girl
use a Kappa test with known good and bad units. % of bad should equal the current defect rate.
The Kappa will test both the inspectors repeatability within themselves and between other inspectors.
I use it to qualify new inspectors, new inspections or inspection criteria and and as a recheck on an annual or semiannual basis (like a calibration of a gage. in fact I put the inspectors in the calibration system so I have the reminder and the record...)
I have attached a spreadsheet that I use for the math - it's not simple. also there is a good article on this at:
http://www.asq.org/pub/qualityprogress/past/1995/may.html
"When Quality is a Matter of Taste, Use Reliability Indexes" by David Futrell
you have to be an ASQ member to view the article I think...
Excellent suggestion!
Kappa is a specific type of Attribute MSA. Any of the Attribute MSAs shown in the AIAG MSA manual would be suitable, but the Kappa analysis would be my recommendation also.
David Hartman
The Third Edition of Juran's Quality Control Handbook defines a method for measuring an Inspector's accuracy (evolved in 1928 by J.M. Juran and C.A. Melsheimer).
I have used this method in the past for what we referred to as Inspector Effectiveness Audits. Perhaps it might be of use to you.
Helmut Jilling
Auditor / Consultant
I use reading glasses, as many 50 somethings do. When I audit an older guy (like me), I sometimes ask them to read some small print to me (a control plan or drawing) to see if they read read small print. If they reach for reading glasses, I ask how they can see small visual defects, and we evaluate the audit trail from there.
It is a common oversight. Color blindness is a problem as well.
PS: the website www.4readers.com sells bifocal reading glasses which are full size and suitable for low impact safety glasses. Best part is they are $6.95!
gard2372
Hello everybody!
Cortiz,
Please refer to this link it may help.
http://Elsmar.com/Forums/showthread.php?t=16929
Even a common visual inspection has a certification in NDT (Non-Destructive Testing). I have attached a link to a Q&A article on the Jager Eye Tests we had to perform annually.
http://www.asnt.org
A Certified Level III NDT can train and certify personnel to the Level I or II for VT Visual Testing if you situation warrants it.
Here are a few more links with Visual Testing Certification and Requirements. I found this website at the beginning of my NDT training several years ago when I was an inspector and it helped me to understand many aspects of inspection I would not have otherwise thought of.
Visual and Optical Testing (VT)
Visual inspection involves using an inspector's eyes to look for defects. The inspector may also use special tools such as magnifying glasses, mirrors, or borescopes to gain access and more closely inspect the subject area. Visual examiners follow procedures that range from simple to very complex.
(Source NDT Resource Center © Copyright 2001 Iowa State University
All rights reserved)
http://www.ndt-ed.org/
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
John Predmore What size pinhole can be reliably detected using visual inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
R Can a Attribute Study be considered a Visual Inspection? Reliability Analysis - Predictions, Testing and Standards 6
P Gage R&R on Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
B Gage R & R on Visual Inspection using the Cross Tabulation Method IATF 16949 - Automotive Quality Systems Standard 4
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
S Do you use audio-visual streaming during FDA inspection? US Food and Drug Administration (FDA) 3
D Visual Inspection with No Visual Reference General Measurement Device and Calibration Topics 2
N How to reduce RPN of Visual Inspection Process FMEA and Control Plans 6
alonFAI Finished PCB Final Visual Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
N Visual Inspection, Terminology for Process (Tin Soldiering?) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Visual Inspection of Machined Parts - Best Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
S Visual Inspection Galvanized Attribute Study Quality Tools, Improvement and Analysis 2
A Cosmetic Visual Inspection Specification Advantages Manufacturing and Related Processes 7
A Cosmetic Spec - Convincing Management Visual Inspection Standard is Necessary Manufacturing and Related Processes 5
S FMEA Visual Inspection Detection Rating FMEA and Control Plans 5
G Thoughts on Audit Finding for not doing Gage R and R for Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Visual Inspection of Roughness General Measurement Device and Calibration Topics 5
S Gage R&R for Visual Inspection for Sheet Steel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J MSA for Attribute Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Repeated Inspection - Probability of Visual Inspection catching Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
5 Visual Weld Inspection Report - Example needed Manufacturing and Related Processes 3
G Sample Size for 2900 ppm Visual Defects Inspection Requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J The appropriate Attribute MSA for Automatic Visual Inspection Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Attribute MSA Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
P Visual Inspection Device for Tiny Rubber Parts General Measurement Device and Calibration Topics 10
B Control Plan Entries - Outgoing Visual Inspection - What should be on a Control Plan? FMEA and Control Plans 18
S High Speed Visual Inspection System vs. Coordinate Machining System Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
I Defectives (ppm) coming from Visual Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Effectiveness of 200% Visual Inspection to Identify Defects and Defectives Inspection, Prints (Drawings), Testing, Sampling and Related Topics 32
B Attribute MSA for Visual Inspection via Camera Automatic Inspection Tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Visual inspection standards - VDA 16 or Equivalent Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T Inspection Method and Control Method for Visual Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
N Tyvek Pouch Seal - Visual Inspection 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 19
Chennaiite High Technology Visual Inspection for Casting and Forging Parts - Zero Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
A Injection Mold 100% Visual Inspection - Short Shots and Debris not being found Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
A Ford's requirements for Lumens/Lighting for Visual Inspection Customer and Company Specific Requirements 11
F MSA and Control Plan - Satisfying Visual Inspection Requirements IATF 16949 - Automotive Quality Systems Standard 5
D Visual Inspection - How do you quantify Visual Inspection for TS16949 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
R Visual Inspection Calibration Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Visual Inspection Frequency and is there any standard that for visual attributes? AQL - Acceptable Quality Level 2
K Visual inspection and acceptance criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Visual Weld inspection training Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q PCBA Visual Inspection Tools & Methods - discounting Optical Tools Manufacturing and Related Processes 11
