Visual Inspection - Capability Study on Attribute Data
Barahir
Is it possible to do a capability study and get a Cpk or Ppk value on an attribute dimension? Specifically I'm looking at an end finish where the inspection method is visual - there is no numeric value for which I can measure or test - it is a pass/fail attribute. Boss wants to know if I can get a process capability study on something like that. Do I do visual inspections and put a 1 for pass or 0 for fail? I'm not sure that something like this is at all possible.
ScottK
Not out of the crisis
Re: Capability study on attribute data?
If you can't measure it you can't get a Cpk.
That's not to say you can't do a capability study on an attribute.
The goals are just different.
You can define defects per million opportunities and use that as a measure, comparing to what your acceptable level would be. Or Z. That would work too.
For example - your end finish is the only attribute you're concerned with.
So you have two opportunities per part for this defect because there are two ends. (I'm making an assumption here - it may be more or less because I don't know what you make)
You inspect 100 randomly chosen parts and find one defect.
Therefore you have:
.010 defects per unit
.005 defects per opportunity
5000 defects per million opportunities
This would correlate to a Z value of 2.58 I believe.
Barahir
Re: Capability Study on Attribute Data? Visual Inspection
Thanks, that confirms what I was thinking as well. I told him that I didn't think it would be possible to get a Cpk or Ppk on an attribute dimension, but that we could base capability off defects/rejects. The end finish is only on 1 end of the product, and if we've produced roughly 20,000 parts with zero defects that would (to me) prove the process as either:
1. capable, or
2. really lucky. :)
bhartigambhir
Hi
For Attribute Data Like Visual Inspection A Study Called Kappa In Msa Is Availabile.... I Have A Soft Copy To Conduct This Attribute Study......
In This Study They Give Us An
- False Alarm
- Miss Rate
I beleive the last poster is confusing MSA with process capability of categorical data (aka attributes).
Of course you can calculate a Cpk (technically a Ppk value) from categorical data. Many customers actually insist on the Ppk value instead of the yield number. go figure :confused:
You simply go "backwards" from your defect rate to a Z score to the Ppk/Cpk value. Ppk = Z/3
Thre are 2 reasons we wantto know a Ppk score:
  1. what is projected yield
  2. what is spread of process (for stackup issues etc.)
only 1 really applies for categorical data.
The true complicating issue here is when you have a highly capable process and you have no defects for large volumes. I typically calculate the upper confidence interval for the exact binomial and use that value as my "yield" number. (yes it's a worst case estimate, but it provides context between a sampel size of 20 and 20,000) there are other accepted approaches and I can post them later if someone is interested...
massfrompak
can someone let me know how attributes can be deal
regards
ahsan
H
himanshugosain
Hiya,
u can use Binomial Process Capability Chart if u know the number of defective parts / %of defectives.
If u know the number of defects then use Possion Capability Study Chart.
Cheers, Himananshu
rjfavro
I'm in the same boat. My boss wants defect tracking on visual defects of automotive glass. There are 30 visual reject types.
any help or examples
thanks
We have done a visual capability study on defects in steel. We used 3 inspectors and had 50 samples with 25 good and 25 defective. I was quite surprised how well they did with less than 10% error in identifying the good vs defective. I used Mintab and it has a very user friendly format for these if you have never done one before.
Again there seems to be two interpretations here:
  1. a capability study on the process: what is the stable rate of defects that is produced by this process (capability study, Cpk)
  2. what is the capability of the inspectors for these visual defects (MSA, kappa score, McNemer's test)
it would be helpful if rjfavro would elaborate on what he is really looking for. saying that 'his boss is looking defect tracking' makes me think he is simply looking a control chart...
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
John Predmore What size pinhole can be reliably detected using visual inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
R Can a Attribute Study be considered a Visual Inspection? Reliability Analysis - Predictions, Testing and Standards 6
P Gage R&R on Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
B Gage R & R on Visual Inspection using the Cross Tabulation Method IATF 16949 - Automotive Quality Systems Standard 4
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
S Do you use audio-visual streaming during FDA inspection? US Food and Drug Administration (FDA) 3
D Visual Inspection with No Visual Reference General Measurement Device and Calibration Topics 2
N How to reduce RPN of Visual Inspection Process FMEA and Control Plans 6
alonFAI Finished PCB Final Visual Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
N Visual Inspection, Terminology for Process (Tin Soldiering?) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Visual Inspection of Machined Parts - Best Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Sean Kelley Visual Inspection Galvanized Attribute Study Quality Tools, Improvement and Analysis 2
A Cosmetic Visual Inspection Specification Advantages Manufacturing and Related Processes 7
A Cosmetic Spec - Convincing Management Visual Inspection Standard is Necessary Manufacturing and Related Processes 5
Sean Kelley FMEA Visual Inspection Detection Rating FMEA and Control Plans 5
G Thoughts on Audit Finding for not doing Gage R and R for Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Visual Inspection of Roughness General Measurement Device and Calibration Topics 5
Sean Kelley Gage R&R for Visual Inspection for Sheet Steel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J MSA for Attribute Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Repeated Inspection - Probability of Visual Inspection catching Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
5 Visual Weld Inspection Report - Example needed Manufacturing and Related Processes 3
G Sample Size for 2900 ppm Visual Defects Inspection Requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J The appropriate Attribute MSA for Automatic Visual Inspection Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Attribute MSA Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
P Visual Inspection Device for Tiny Rubber Parts General Measurement Device and Calibration Topics 10
B Control Plan Entries - Outgoing Visual Inspection - What should be on a Control Plan? FMEA and Control Plans 18
S High Speed Visual Inspection System vs. Coordinate Machining System Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
I Defectives (ppm) coming from Visual Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Effectiveness of 200% Visual Inspection to Identify Defects and Defectives Inspection, Prints (Drawings), Testing, Sampling and Related Topics 32
B Attribute MSA for Visual Inspection via Camera Automatic Inspection Tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Visual inspection standards - VDA 16 or Equivalent Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T Inspection Method and Control Method for Visual Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
N Tyvek Pouch Seal - Visual Inspection 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 19
Chennaiite High Technology Visual Inspection for Casting and Forging Parts - Zero Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
A Injection Mold 100% Visual Inspection - Short Shots and Debris not being found Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
A Ford's requirements for Lumens/Lighting for Visual Inspection Customer and Company Specific Requirements 11
F MSA and Control Plan - Satisfying Visual Inspection Requirements IATF 16949 - Automotive Quality Systems Standard 5
D Visual Inspection - How do you quantify Visual Inspection for TS16949 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
R Visual Inspection Calibration Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Visual Inspection Frequency and is there any standard that for visual attributes? AQL - Acceptable Quality Level 2
K Visual inspection and acceptance criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Visual Weld inspection training Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
quality1 PCBA Visual Inspection Tools & Methods - discounting Optical Tools Manufacturing and Related Processes 11
V Detection rating for visual inspection in PFMEA FMEA and Control Plans 19
I Contract Visual, Basic Dimensional Inspection Services Service Industry Specific Topics 2
