Visual Inspection - Capability Study on Attribute Data
DJ5657
#11
Re: Capability Study on Attribute Data? Visual Inspection
Guys, and experts here, I also need your help. I want to know how to determine the process capability of my machine. My given data are weekly ppm of visual mechanical defects on ICs such as lead defect and package defect.
My idea as step by step procedure to get this are :
1. Get the measurement readings on IC samples that was processed on my machine. Let's say 100 samples. This will give me the value for standard deviation.
2. Determine my limits for parameters on lead and package defect.
3. Substitute the derived values in CPK formula to get the CPK or process capability.
The result will be a value and will tell to me my process capability. This will tell me how far my machine produces defects away from this limits. However, how can I translate the result to the recurrence rate? Or interpret it the chance of having a defect on processed units?
Does my idea posted above is correct? Please help me. I am new in this field. Thank You.
#12
just for clarity - are you only dealing with counts of defect data? no continuous or ''varables' data on input parameters?
if only using defect data do you also have the count of inspected units (with and without defects)
the best approach to defect data is to use a c chart (if the number of units per period is roughly equal) or a u chart if the number of inspected units has substantial variation.
If this is a standard inspection why use 100 units? why not use ALL of the inspection data?
you can use the upper control limit as the capability of the process. this provides a direct report of the defect rate that your process creates. (without calculating the Cpk.) IF you need a Cpk value for your customer, you can back calculate it using the Z formula.
DJ5657
#13
Hi, Bev D. Thank you so much for your reply. Yes, I am dealing only with a pass/fail result which was obtained from sampling inspection. Each sampling inspection is per lot and each lot has different lot size. So no same number of lot size from sampling inspection from previos weeks. I guess the U chart you mentioned is more appropriate with my condition, but can you help me how can I obtain from my defect rate data per week in PPM the upper and lower control limit? And how the U chart result will help me to assess the current process capability of my machine?
Thank you so much for helping a newbie like me.
Regards,
#14
Formulas for the u chart:
each plotted point = defect rate per lot = ui = sum of defects in the lot/sum of units inspected in the lot
center line = u_bar = (sum of all defects)/(sum of all items inspected in all lots)
LowerControl Limit = u_bar-3*sqrt(u_bar/n)
Upper Control Limit = u_bar+3*sqrt(u_bar/n)
each data point will have it's own control limits
n= the number inspected in each individual lot.
u_bar is the average defect rate across all lots and represents your capability.
the individual control limits represent the highest expected defect rate in an individual lot, given its sample size...
you can translate to a Cpk value (But only if required to do so by a Custoemr as it really is meaningless compared to the control chart which shows in direct terms the capability of the process):
Cpk = NORMSINV(1-defect proportion)/3
NORMSINV is an EXCEL function that converts teh defect proportion to a Z-score. Cpk = Z/3...
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
John Predmore What size pinhole can be reliably detected using visual inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
R Can a Attribute Study be considered a Visual Inspection? Reliability Analysis - Predictions, Testing and Standards 6
P Gage R&R on Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
B Gage R & R on Visual Inspection using the Cross Tabulation Method IATF 16949 - Automotive Quality Systems Standard 4
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
S Do you use audio-visual streaming during FDA inspection? US Food and Drug Administration (FDA) 3
D Visual Inspection with No Visual Reference General Measurement Device and Calibration Topics 2
N How to reduce RPN of Visual Inspection Process FMEA and Control Plans 6
alonFAI Finished PCB Final Visual Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
N Visual Inspection, Terminology for Process (Tin Soldiering?) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Visual Inspection of Machined Parts - Best Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
S Visual Inspection Galvanized Attribute Study Quality Tools, Improvement and Analysis 2
A Cosmetic Visual Inspection Specification Advantages Manufacturing and Related Processes 7
A Cosmetic Spec - Convincing Management Visual Inspection Standard is Necessary Manufacturing and Related Processes 5
S FMEA Visual Inspection Detection Rating FMEA and Control Plans 5
G Thoughts on Audit Finding for not doing Gage R and R for Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Visual Inspection of Roughness General Measurement Device and Calibration Topics 5
S Gage R&R for Visual Inspection for Sheet Steel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J MSA for Attribute Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Repeated Inspection - Probability of Visual Inspection catching Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
5 Visual Weld Inspection Report - Example needed Manufacturing and Related Processes 3
G Sample Size for 2900 ppm Visual Defects Inspection Requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J The appropriate Attribute MSA for Automatic Visual Inspection Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Attribute MSA Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
P Visual Inspection Device for Tiny Rubber Parts General Measurement Device and Calibration Topics 10
B Control Plan Entries - Outgoing Visual Inspection - What should be on a Control Plan? FMEA and Control Plans 18
S High Speed Visual Inspection System vs. Coordinate Machining System Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
I Defectives (ppm) coming from Visual Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Effectiveness of 200% Visual Inspection to Identify Defects and Defectives Inspection, Prints (Drawings), Testing, Sampling and Related Topics 32
B Attribute MSA for Visual Inspection via Camera Automatic Inspection Tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Visual inspection standards - VDA 16 or Equivalent Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T Inspection Method and Control Method for Visual Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
N Tyvek Pouch Seal - Visual Inspection 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 19
Chennaiite High Technology Visual Inspection for Casting and Forging Parts - Zero Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
A Injection Mold 100% Visual Inspection - Short Shots and Debris not being found Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
A Ford's requirements for Lumens/Lighting for Visual Inspection Customer and Company Specific Requirements 11
F MSA and Control Plan - Satisfying Visual Inspection Requirements IATF 16949 - Automotive Quality Systems Standard 5
D Visual Inspection - How do you quantify Visual Inspection for TS16949 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
R Visual Inspection Calibration Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Visual Inspection Frequency and is there any standard that for visual attributes? AQL - Acceptable Quality Level 2
K Visual inspection and acceptance criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Visual Weld inspection training Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q PCBA Visual Inspection Tools & Methods - discounting Optical Tools Manufacturing and Related Processes 11
