Visual Inspection Effectiveness
kwalityguy
I have a defect that happened on 1 part out of 10,000 pcs shipped over a 2 year time period. It is a faint line in a dull gray sheet metal part. Our customer wants to know why we didn't visually detect this. I'm saying visual inspection is not capable of detecting a 100 ppm defect. Anyone else go to battle about this? How did you handle it?
Sidney Vianna
Post Responsibly
I don't understand what the ppm has to do with the ability to detect the defect. The likely reason for failing to detect the problem is part of so called "human factors".
Mike S.
Happy to be Alive
Visual inspection is very rarely 100% effective. Now, it may be 100% effective or virtually so for gross stuff, like differentiating a car from a truck, or a similarly easily differentiated characteristic, but in most practical situations that employ it, visual inspection has varying degrees of inherent error. You may need to explain that to the customer. I certainly have to do it from time-to-time.
kwalityguy
I believe ppm is directly related to visual inspection. If the line problem occurred at a rate of 900,000 ppm (9 of 10 parts have the line defect), visual inspection should detect a good portion of these. But if the defect rarely occurs (just once every 2 years), visual inspection becomes very ineffective.
Sidney Vianna
Post Responsibly
Basically, you are saying that the inspector would only react to a defect if s/he observed it a number of times. If the inspector does not have visual acuity, the light conditions are inappropriate, the criteria for rejection is unclear, etc... s/he will miss the defect 100% of the time.
Tagin
Its not clear from your post if the inspectors saw it but let it pass, or did not see it and let it pass. If the former, it could be a "calibration" issue, if the inspector(s) did not consider this to be a defect, yet the customer did consider it a defect; if the latter, then it could be vigilance/human factors, as Sidney noted, or for such a small defect rate perhaps the inspected % of lot is inadequate to achieve the necessary confidence of acceptable defects.
In any case, it seems like there is a disconnect between the (previously unstated?) customer expectations for maximum defect rate vs. your inspection criteria that will need to be ironed out.
PPM Has nothing to do with it, or anything else for that matter. An inspector or operator missed one piece after 10,000 pieces of presumably "good" ones had been produced and shipped. I say "presumably" because we don't know how many the customer might have missed, or might have seen and figured it wasn't something worth making a commotion about. The only prudent way to handle this on the customer end is to notify the supplier as a courtesy and get back to work. On the supplier end, it should be enough to express regret, replace the "bad" part, and move on.
AgnieszkaSz
Visual inspection in manufacturing cannot be 100% effective. The simpler the task, the quicker human mind gets bored. I heard an opinion that maximal effectiveness is 40% - an inspector has limited time to perform inspection and repetitive tasks are boring to death. The mind wanders. If you don't assess such kind of answer too risky, just say that the company decided to take the risk of this particular failure because of economical reason - it is cheaper to accept this risk than to invest in 100% proof inspection system.
B Effectiveness of 200% Visual Inspection to Identify Defects and Defectives Inspection, Prints (Drawings), Testing, Sampling and Related Topics 32
B IATF 7.1.5.1.1 Measurement system analysis (Visual Inspection) IATF 16949 - Automotive Quality Systems Standard 3
J Justification for visual inspection ISO 13485:2016 - Medical Device Quality Management Systems 3
M Cameras and Visual Inspection Equipment General Measurement Device and Calibration Topics 3
C KAPPA index Reference Value for Visual inspection IATF 16949 - Automotive Quality Systems Standard 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 11
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
John Predmore What size pinhole can be reliably detected using visual inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
R Can a Attribute Study be considered a Visual Inspection? Reliability Analysis - Predictions, Testing and Standards 6
P Gage R&R on Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
B Gage R & R on Visual Inspection using the Cross Tabulation Method IATF 16949 - Automotive Quality Systems Standard 4
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
S Do you use audio-visual streaming during FDA inspection? US Food and Drug Administration (FDA) 3
D Visual Inspection with No Visual Reference General Measurement Device and Calibration Topics 2
N How to reduce RPN of Visual Inspection Process FMEA and Control Plans 6
alonFAI Finished PCB Final Visual Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
N Visual Inspection, Terminology for Process (Tin Soldiering?) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Visual Inspection of Machined Parts - Best Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
S Visual Inspection Galvanized Attribute Study Quality Tools, Improvement and Analysis 2
A Cosmetic Visual Inspection Specification Advantages Manufacturing and Related Processes 7
A Cosmetic Spec - Convincing Management Visual Inspection Standard is Necessary Manufacturing and Related Processes 5
S FMEA Visual Inspection Detection Rating FMEA and Control Plans 32
G Thoughts on Audit Finding for not doing Gage R and R for Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Visual Inspection of Roughness General Measurement Device and Calibration Topics 5
S Gage R&R for Visual Inspection for Sheet Steel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J MSA for Attribute Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Repeated Inspection - Probability of Visual Inspection catching Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
5 Visual Weld Inspection Report - Example needed Manufacturing and Related Processes 3
G Sample Size for 2900 ppm Visual Defects Inspection Requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J The appropriate Attribute MSA for Automatic Visual Inspection Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Attribute MSA Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
P Visual Inspection Device for Tiny Rubber Parts General Measurement Device and Calibration Topics 10
B Control Plan Entries - Outgoing Visual Inspection - What should be on a Control Plan? FMEA and Control Plans 18
S High Speed Visual Inspection System vs. Coordinate Machining System Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
I Defectives (ppm) coming from Visual Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Attribute MSA for Visual Inspection via Camera Automatic Inspection Tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Visual inspection standards - VDA 16 or Equivalent Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T Inspection Method and Control Method for Visual Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
N Tyvek Pouch Seal - Visual Inspection 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 19
Chennaiite High Technology Visual Inspection for Casting and Forging Parts - Zero Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
A Injection Mold 100% Visual Inspection - Short Shots and Debris not being found Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
A Ford's requirements for Lumens/Lighting for Visual Inspection Customer and Company Specific Requirements 11
F MSA and Control Plan - Satisfying Visual Inspection Requirements IATF 16949 - Automotive Quality Systems Standard 5
D Visual Inspection - How do you quantify Visual Inspection for TS16949 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
R Visual Inspection Calibration Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Visual Inspection Frequency and is there any standard that for visual attributes? AQL - Acceptable Quality Level 2
