Visual Inspection of a Weld - MSA (Measurement System Analysis)
automoto
Control plan state visual checking of weld. There are instructions (pictures) at workplace that explain which weld is OK and which is NOT OK. 3rd party auditor asks me if we perform MSA for mentioned case. Until now we did not conduct MSA for visual inspection. Does anyone have experiences wit that? What are your practices?
Aleš
bobdoering
Stop X-bar/R Madness!!
Re: MSA for visual inspection
We do it with welds. It is a reasonable request - your gage is your visual criteria (charts, samples, etc.), and you perform an attribute study on a series of specimens to determine that all levels of skill inspectors pick the correct category (pass or fail) for the specimens you provide.
W
wweng7
Can you attach some samples of this type of study?
Thanks in advance
automoto
Reference manual state on page 125 "Visual standards may result in five to seven distinct categories. The analyzes described in the proceeding chapter cannot be used to evaluate such system"
Therefor could you explain how to perform attribute MSA for visual inspection of weld. Which method shall I use. Could you attach an example...
Thanks in advanced.
bobdoering
Be sure to understand that it is true that if you are trying to categorize your product into separate visual criteria categories, that you can not use Section C to verify that you are getting all of the specimens into the correct categories (even worse if you have more than one reject condition possible per part.)
BUT - you can use it if you are using the visual standards to determine pass/fail specifically. Chances are, the bottom line of your visual criteria is pass/fail (any one or more conditions on the part is "fail") as far as the ultimate point of the inspection. The Section C layout would be adequate for such an MSA.
5 Visual Weld Inspection Report - Example needed Manufacturing and Related Processes 3
R Visual Weld inspection training Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
I Overwhelmed with attribute MSA requirement for visual inspection IATF 16949 - Automotive Quality Systems Standard 8
K Visual Inspection Effectiveness Inspection, Prints (Drawings), Testing, Sampling and Related Topics 16
Marc Visual Inspection - Color Vision Coffee Break and Water Cooler Discussions 15
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
John Predmore What size pinhole can be reliably detected using visual inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
R Can a Attribute Study be considered a Visual Inspection? Reliability Analysis - Predictions, Testing and Standards 6
P Gage R&R on Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
B Gage R & R on Visual Inspection using the Cross Tabulation Method IATF 16949 - Automotive Quality Systems Standard 4
L IATF 16949 7.1.5.1.1 Measurement System Analysis (MSA) - Visual Inspection IATF 16949 - Automotive Quality Systems Standard 14
S Do you use audio-visual streaming during FDA inspection? US Food and Drug Administration (FDA) 3
D Visual Inspection with No Visual Reference General Measurement Device and Calibration Topics 2
N How to reduce RPN of Visual Inspection Process FMEA and Control Plans 6
alonFAI Finished PCB Final Visual Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
N Visual Inspection, Terminology for Process (Tin Soldiering?) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Visual Inspection of Machined Parts - Best Methods Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
S Visual Inspection Galvanized Attribute Study Quality Tools, Improvement and Analysis 2
A Cosmetic Visual Inspection Specification Advantages Manufacturing and Related Processes 7
A Cosmetic Spec - Convincing Management Visual Inspection Standard is Necessary Manufacturing and Related Processes 5
S FMEA Visual Inspection Detection Rating FMEA and Control Plans 5
G Thoughts on Audit Finding for not doing Gage R and R for Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
J Visual Inspection of Roughness General Measurement Device and Calibration Topics 5
S Gage R&R for Visual Inspection for Sheet Steel Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
J MSA for Attribute Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
T Repeated Inspection - Probability of Visual Inspection catching Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
G Sample Size for 2900 ppm Visual Defects Inspection Requirement Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
J The appropriate Attribute MSA for Automatic Visual Inspection Machine Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Attribute MSA Visual Inspection Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
P Visual Inspection Device for Tiny Rubber Parts General Measurement Device and Calibration Topics 10
B Control Plan Entries - Outgoing Visual Inspection - What should be on a Control Plan? FMEA and Control Plans 18
S High Speed Visual Inspection System vs. Coordinate Machining System Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
I Defectives (ppm) coming from Visual Inspection Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Effectiveness of 200% Visual Inspection to Identify Defects and Defectives Inspection, Prints (Drawings), Testing, Sampling and Related Topics 32
B Attribute MSA for Visual Inspection via Camera Automatic Inspection Tool Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
S Visual inspection standards - VDA 16 or Equivalent Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T Inspection Method and Control Method for Visual Inspection? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
B Visual Inspection (Attribute Data) Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 27
N Tyvek Pouch Seal - Visual Inspection 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 19
Chennaiite High Technology Visual Inspection for Casting and Forging Parts - Zero Defects Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
A Injection Mold 100% Visual Inspection - Short Shots and Debris not being found Inspection, Prints (Drawings), Testing, Sampling and Related Topics 22
A Ford's requirements for Lumens/Lighting for Visual Inspection Customer and Company Specific Requirements 11
F MSA and Control Plan - Satisfying Visual Inspection Requirements IATF 16949 - Automotive Quality Systems Standard 5
D Visual Inspection - How do you quantify Visual Inspection for TS16949 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S Applying ANSI/ASQ Z1.4 given known lot size and 100% visual inspection AQL - Acceptable Quality Level 2
R Visual Inspection Calibration Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
A Visual Inspection Frequency and is there any standard that for visual attributes? AQL - Acceptable Quality Level 2
K Visual inspection and acceptance criteria Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
Q PCBA Visual Inspection Tools & Methods - discounting Optical Tools Manufacturing and Related Processes 11
V Detection rating for visual inspection in PFMEA FMEA and Control Plans 19
