Wabash Press Calibration - Lab-sized Wasbash Presses
Craig H.
Hi! Does anyone have any experience with lab-sized Wasbash Presses? We have one in our lab that is used to form test specimens of rubber and plastics. The specimens are then tested for flex, modulus, etc.
Our press is coming due for calibration, and the question has been raised as to whether or not we should pay the $4G fee to have this done. My gut tells me that we should, but plastics are out of my area so I can't really make a good case. Can anyone help?
Jerry Eldred
Re: Wabash Press Calibration
That's a tough one. Hopefully someone will be able to give some informed advice. Are there any plastics industry forums out there that you could also post on in case you don't hear anything.
Craig H.
I'm looking now. What worries me is, of course, the effect on the final test results because of variances in thickness etc. Reducing the concern is that usually a group of specimens are made in a group and comparisons are made within that group only. There is also usually a test run on a control within that group, and the control is run whenever that type of material is run.
Still...
Jerry Eldred
My metrologist instincts tell me the following (in absence of someone qualified in this discipline):
These may be thoughts you've already had. So if nothing else, perhaps my input may help confirm your thoughts. Evaluate specs of materials/specimens associated with its use, and how the calibrated specs of the press relate to outgoing product quality. If the calibrated tolerances of the press relate to outgoing product's ability to meet it's specs, then it needs to be calibrated.
If the calibration of the press is a "convenience" (makes it simpler to make specimens that are near correct, but does not ultimately make a decision regarding product final specs), then I'd give it a "maybe."
My ignorant perception is that having the press calibrated associates with the ability to make specimens of known flex, modulus, etc. based on given press parameters; essentially correlating press parameters to specimen parameters. Without the calibration, that association becomes more an unknown.
Craig H.
Yes, Jerry, and thanks for your input. The thing is that I don't know how much effect being out of calibration would have. If we ran the same material on it all of the time it would be different, but we run PVC, nylon, rubber, etc. in this lab, which, in my mind complicates things more.
Since our ISO 9001 audit starts in the morning I am going to do a little more on this today and then pick it back up next week.
Thanks again, Jerry!
P Corrective Action Response for Missed bumps on brake press Manufacturing and Related Processes 2
M Informational Team-NB published a press release regarding the survey run among its members to analyse the certificates being issued Medical Device and FDA Regulations and Standards News 0
M Informational Team-NB published a press release regarding the capacities of notified bodies to meet the sector needs Medical Device and FDA Regulations and Standards News 0
M Medical Device News Team-NB publishes a press release regarding the designation process in the framework of the IVDR regulation – Regulation (EU) 2017/746 Medical Device and FDA Regulations and Standards News 0
J Mechanical Press Machine Foundation Requirements and Recomendations Manufacturing and Related Processes 2
V Root Cause help needed - Sheet metal breaking at press Problem Solving, Root Cause Fault and Failure Analysis 9
Z Stamping Press Die Specification Manufacturing and Related Processes 2
O Need Example PFMEA for Turret Punch Press Manufacturing and Related Processes 2
K Machine Press Tooling Operation Inspection Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 5
F ISO 9001 Quality Management System for Printing Press ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Break Press or Bending A36 Carbon Structural Steel Plate Manufacturing and Related Processes 1
J Press Brake Tooling / Back Gauging - Holes for the back stop instead of the Part Edge Manufacturing and Related Processes 8
R Microbiological Cleaning Validation of Tablet Press Machine Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 6
L Calibrating Press Brakes, How to do? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
E Traceability in Press Shop - Metal Parts Document Control Systems, Procedures, Forms and Templates 11
A Process Validation Format for Press (Stamping) Operations - Help needed APQP and PPAP 11
G Company or organization press NSA 211.00 specification Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
P Tool (Press Tool & Plastic Mould) Buy Off Template Supplier Quality Assurance and other Supplier Issues 6
S Advice Please regarding CE Marking requirements for Printing Press CE Marking (Conformité Européene) / CB Scheme 4
B Legal requirements - India - Painting, press shop, machining Miscellaneous Environmental Standards and EMS Related Discussions 1
B Question on ISO 9001:2000 for a Printing Press Implementation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
Sidney Vianna Press releases that makes you wonder World News 19
L Attribute gage in stamping press as poke yoke Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Single Minute Exchange of Dies and Rollfeeds - SMED in press shops Manufacturing and Related Processes 1
D Filtration Industries - Fabrication in Filter Press, Fluid bag, drier bag or etc. Various Other Specifications, Standards, and related Requirements 3
C Is stamping or press operation considered as noise pollutant? Miscellaneous Environmental Standards and EMS Related Discussions 9
D Work Instructions - Press Settings - TS 16949 IATF 16949 - Automotive Quality Systems Standard 10
P Die (Press Tool) Manufacturing Process Key Indicators (KPI) Manufacturing and Related Processes 5
Wes Bucey Some companies "muzzle" employees to prevent them talking to press Philosophy, Gurus, Innovation and Evolution 7
Hershal Press release regarding the USMC and IAS World News 2
J Book Review: Internal Audit Training from Patton Press Book, Video, Blog and Web Site Reviews and Recommendations 10
V Can I press our suppliers for certifications of their products? Supplier Quality Assurance and other Supplier Issues 2
Marc US TAG176 Press Release - 12 August 1999 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 0
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
N IATF Calibration Lean in Manufacturing and Service Industries 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E Calibration Records needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
D Limited Range Calibration - 5000 lb Industrial floor scale General Measurement Device and Calibration Topics 3
D Calibration of Small Scales General Measurement Device and Calibration Topics 26
I IQOQ or just initial calibration required? General Measurement Device and Calibration Topics 3
B Calibration in real life ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Ron Rompen Calibration by manufacturer ISO 17025 related Discussions 4
Q Calibration verification records 7.1.5.2.1 IATF 16949 - Automotive Quality Systems Standard 2
