Warehouse temperature and humidity control
Storage condition for the finished medical device are -40 to 70 °C and 0 to 100 %RH. Do I need to control the warehouse environment for the temperature and humidity? Normal temperature and humidity of my country fully covered and meet the requirements. I think... what I need to do is.. accumulate the history of the temperature and humidity and make a justification. Please give good advice.
Kind regards,
yodon
You say "normal" temperature is in range but, obviously, it's the excursions that are the biggest concern. Those are pretty extreme temperatures so you're probably right in that you wouldn't need any controls. I would agree with you that it's probably a good idea to set up some monitoring to have objective evidence that your storage conditions are (always) in range.
Ed Panek
QA RA Small Med Dev Company
To CYA I would go to weather.com or equivalent and check out the past decade highs and lows and RH ranges. Unless you have a steel melting furnace in the building that should be enough to justify no controls needed. Obviously, 70'C is an insanely high temperature. If it is that high your warehouse workers are likely deceased.
my point is you don't need to control but you have to set up an alert alrm system in place , for exam you can set temp "-20,55"celsius degree as alert point, this is easy to implement at current technology , as same question why we need to set up fire-fighting system in place but never have outbreak of fire .:)
AgnieszkaSz
If your storeroom is susceptible to getting very hot in summer in direct sun (like, under light steel roof), just make sure that the temperature in such places is within limit.
dwperron
Kind regards,
An auditor is going to say "Prove it".
You will need to produce records that show you have been monitoring environmental conditions.
There are plenty of devices out there that will do the job for you.
Thanks for your comments. My plan is to prepare the monitoring sensor and collect 1-year data. After 1-year, I will prepare the report including justification using the raw data. If there is no deviations during 1-year, I think I don't need to monitor the current temperature and humidity. Hot about this concept?
dwperron
You will need to continually monitor the environmental conditions. Even though it is very unlikely that you will ever go outside the environmental limits an auditor will still be looking for proof that you are continually monitoring conditions. It's easy and inexpensive, and it will save you from having to justify why you don't monitor and record the results.
M Pharmaceuticals Warehouse temperature control (room temperature) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
R VMP template for Temperature Data Loggers in a Pharma Warehouse Qualification and Validation (including 21 CFR Part 11) 4
J Warehouse Floorspace Utilization Manufacturing and Related Processes 3
R Product Recall - medical devices in the hospital warehouse Canada Medical Device Regulations 2
L Significant change notice for outsourced warehouse Medical Device and FDA Regulations and Standards News 2
B Software for setting up New Warehouse Manufacturing and Related Processes 0
R Is there a mandatory medical device warehouse standard for europe? EU Medical Device Regulations 3
R Warehouse and shipping/receiving activities need to be part of our scope? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
G How to cover another manufacturing "site" or warehouse into current ISO 13485 cert ISO 13485:2016 - Medical Device Quality Management Systems 7
P Non Conforming Material in the Warehouse..to tag or not? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
D AS9100 section for Warehouse/Preservation of materials? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Brand New Warehouse - FMEA example wanted FMEA and Control Plans 9
B Fire Extinguisher Requirements for a Warehouse Vehicle Miscellaneous Environmental Standards and EMS Related Discussions 2
S Package Storage Direction in an I.T. Warehouse ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M FDA Wall Clearance Requirements For Warehouse 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
M Critical Limits for CCP in a food storage warehouse Food Safety - ISO 22000, HACCP (21 CFR 120) 4
A Food Warehouse ISO 9001 Audit and Newbie Introduction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
D Calibration in Warehouse Environment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Movement of Final Product from One Warehouse to Another Manufacturing and Related Processes 2
R HACCP for Packaging, Labeling and Warehouse of Food Products Food Safety - ISO 22000, HACCP (21 CFR 120) 13
S Building and Warehouse requirements of OHSAS 18001 Occupational Health & Safety Management Standards 8
S Single Warehouse used by two different companies - One is ISO 13485 registered Quality Manager and Management Related Issues 1
T Outsourcing Shipping Product directly from our Warehouse to the End Customer ISO 13485:2016 - Medical Device Quality Management Systems 2
J HACCP and ISO22000 - Brewery and Warehouse Food Safety - ISO 22000, HACCP (21 CFR 120) 13
M Kanban vs. Line Balancing - Process Engineering our Warehouse Process Lean in Manufacturing and Service Industries 3
M Internal Warehouse Handling - A Reverse Logistic Case! Process Maps, Process Mapping and Turtle Diagrams 6
N 100% Inspection in Retail Warehouse which Ships Products to Customers Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
B TS 16949 Upgrade for Distribution Warehouse IATF 16949 - Automotive Quality Systems Standard 4
L Writing a Shipping and Receiving Procedure - Designated Warehouse Locations ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Electronic Process Examples (IT Data Warehouse) Human Factors and Ergonomics in Engineering 1
N Managing Subcontracting Process - Material Traceability from Warehouse to Processing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Warehouse Layout Design Lean in Manufacturing and Service Industries 11
Q Control plans for Incoming, Warehouse and Shipping process FMEA and Control Plans 5
bgot62 Secondary Operations and an uncontrolled document in the warehouse ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
H Forklift Safety - Driver loses control in warehouse (Video) Occupational Health & Safety Management Standards 2
P Warehouse Audit - Nonconformance or not - That is the question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
A Rental Warehouse Audit required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
G Manufacturing -> Warehouse -> Tier 1/OEM - Process flow, PFMEA, & Control Plan FMEA and Control Plans 9
D Should I put Warehouse under Manufacturing Department? Misc. Quality Assurance and Business Systems Related Topics 8
A Production Planning, Scheduling and Warehouse Management Manufacturing and Related Processes 8
I How to Balance a Warehouse System Lean in Manufacturing and Service Industries 2
I Time Analysis of Logistics in a Warehouse Lean in Manufacturing and Service Industries 3
C Requirements for Process Chemical Storage in a Warehouse Miscellaneous Environmental Standards and EMS Related Discussions 20
M Dock to Stock Template for Distributor/Warehouse of Industrial Metals Document Control Systems, Procedures, Forms and Templates 5
A Warehouse Internal Audit - Seeking Tips and Advice Internal Auditing 17
J Free Warehouse Layout & Planning Guide and Facilities & Workplace Design guide Design and Development of Products and Processes 10
M President of company wants ISO 17025 for testing - Warehouse distributor ISO 17025 related Discussions 3
M Warehouse Space Utilization Spreadsheet Document Control Systems, Procedures, Forms and Templates 5
L Warehouse Design Layout - FDA Regulated Medical Manufacturer Design and Development of Products and Processes 3
T Warehouse Fire: QMS Involvement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
