Warning about Deltronic Gage Pins - The "Certification of Accuracy" document
GFish
Please be aware that when you purchase Deltronic Gage Pins, the "Certification of Accuracy" document that accompanies them is not valid for calibration and new gage pins must be calibrated before use in order to meet ISO 9001 and/or ISO 13845 requirements.
Per the applicable standard - the requirement is for traceability to national or internal standards, in the US this of course is NIST. To establish this traceability, I (our 3rd party Orion Auditor) looks for an unbroken chain of calibration, validated through, at a minimum, the identification of the standards used, and their calibration information provided on a calibration certificate.
As this information is not included on Deltronic's certificate of accuracy, traceability to NIST is not evident.
As a result of this - both of the facilities that I work at received minor non-conformances requiring corrective action which seems to only include - send these out for calibration by someone who provides you with traceability to NIST. Deltronic's response to this issue that I brought to their attention was that a "long form certificate" is available for a premium charge.
Problem that I have is - how would anyone know that they need a long form cert to begin with? Seems that Deltronic's is playing on the ignorance of Quality professionals.
I just wanted people to be aware of this issue in order to prevent potential ISO 3rd party findings at their companies.
Al Rosen
PO can state that a calibration certificate traceable to NIST or other national recognized standards is required. Most manufacturers add on fees for traceable certs.
GFish
Good point Al.
Deltronic only sells through distributors. I checked and all POs issued included requirement for cert traceable to NIST. Seems that both Deltronic and distributors do not understand ISO requirements.
Good point Al.
The Deltronic website says this about certification/traceability:
We take gages seriously. National Institute of Standards and Technology (NIST) Calibrated Masters Certification of Accuracy and traceability to the NIST is included with every Deltronic gage. This no-charge feature has its foundation in masters calibrated for us by the National Institute of Standards and Technology.
Michael_M
.......Problem that I have is - how would anyone know that they need a long form cert to begin with? Seems that Deltronic's is playing on the ignorance of Quality professionals.
A simple solution to this is to verify pins prior to use with a traceable calibrated gage. Our procedure is to validate the gage pin with a calibrated digital micrometer before using. Just make sure that everyone knows how to use the micrometer and you will not have to spend money calibrating the gage pins, unless you are working under some requirement that requires gage pins to be calibrated. We have some custom gage pins used as 'masters' so they are calibrated by an outside lab, but if they are just used to check acceptance, use a good micrometer to validate.
GFish
Another good thought Michael but the accuracy of Deltronic gages requires that they be checked with a laser micrometer which we don't have and is not cheap.
Michael_M
GFish, We use a digital OD micrometer to verify as we hold this device to a calibration of ±.0001. However, if this is not good enough, I know Mitutoyo makes a digital Micrometer that has an accuracy rating of .00002 (Mitutoyo part number 293-130-10). The last time I priced this device it was about $1,600. I don't know how many pins you have to calibrate, but the device might pay for itself in the short term (if each pin cost $20.00 to calibrate, as soon as you do 80 pins, it has paid for itself).
dwperron
First, I have reviewed more calibration certificates than I want to remember.
Even with the best of them you rarely see any that exhibit an unbroken chain of calibration to a national lab, validated through, at a minimum, the identification of the standards used, and their calibration information provided on a calibration certificate. And those would typically be physical / dimensional devices only. Normally you will get a traceability statement, but in order to demonstrate actual traceability you would need to have them trace each item used in the calibration back individually through all of their calibration sources as well. I've had to do that a few times, and it can be a painful endeavor.
If traceability is important to you then deal with 17025 accredited labs. They have proven their traceability to independent auditors.
Also, the tolerances on Deltronics plugs are +40 µin / -0. A supermike can be barely adequate for this. Lasermikes are not up to this job. And at Class X accuracy the environment is a critical factor in the measurements. Add the time you spend calibrating and it gets less cost effective to calibrate them yourself. Then when you add all of the back end costs of running a calibration facility it becomes obvious - unless calibration is a main part of your business then leave it to the experts.
mr500
So when the labs verify a pin gage, is it recorded as Maximum Inscribed / Minimum Circumscribed Circle taking the 3 largest or smallest points???
Or do they use a least squared approach?
dwperron
On plug gauges like Deltronics you would typically report the diameter at each end and the center then the same points rotated 90°.
Class Z or ZZ pin gauges are often just checked for diameter at each end.
M Informational US FDA issued the first warning letter for UDI violations to help ensure compliance Medical Device and FDA Regulations and Standards News 0
P Warning Letter 1999 - Where does the FDA make older warning letters available? US Food and Drug Administration (FDA) 4
W IMDS - Help (Common Warning and Error Fixes) RoHS, REACH, ELV, IMDS and Restricted Substances 9
N IMDS Warning Polymer Material Two Substances RoHS, REACH, ELV, IMDS and Restricted Substances 8
J Employer Warning Notice a Controlled Document? Document Control Systems, Procedures, Forms and Templates 7
9 EU Medical Device Manufacturer Warning Letters EU Medical Device Regulations 2
H Most Poorly Written FDA Warning Letter Ever? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
J FDA 483 Warning Letter for use of Calipers 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 18
W Medical Device Warning Lights Colors IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
T FDA Form 483 Warning Letter - What next? US Food and Drug Administration (FDA) 7
S FDA Warning Letter Remediation - Enforcement Resolution & Remediation Process US Food and Drug Administration (FDA) 3
L Warning Letter adressed to owner/operator or facility? US Food and Drug Administration (FDA) 1
AnaMariaVR2 Agila Specialties Private Limited Warning Letter US Food and Drug Administration (FDA) 0
AnaMariaVR2 Warning ? Don?t Confuse ?Made In USA? And ?Inspected By FDA? With Patriotism US Food and Drug Administration (FDA) 3
S FDA Warning Letter on Medical Device Reporting Interpretation 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
AnaMariaVR2 Gilead plant joins the FDA's "warning club" US Food and Drug Administration (FDA) 0
K Where you can read other companys' 483 FDA Warning Letters 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
AnaMariaVR2 Jubilant HollisterStier General Partnership [warning letter] US Food and Drug Administration (FDA) 1
M FDA Warning Letter - Product Association with Search Engine Results - Problems Ahead? US Food and Drug Administration (FDA) 10
AnaMariaVR2 St. Jude Medical does the unthinkable: Warns of FDA warning letter before FDA issues US Food and Drug Administration (FDA) 5
AnaMariaVR2 Warning Letter to Fercy Personal Care Products - company kicked out FDA Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
I IMDS Warning - Chromate Filming of Zinc Plating RoHS, REACH, ELV, IMDS and Restricted Substances 4
A FDA 483 Warning Letter Response Time Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
AnaMariaVR2 FDA writes up Warning Letter to British Homeopathic Drugmaker US Food and Drug Administration (FDA) 0
Y Siemens Healthcare - FDA Warning Letter Analysis 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
AnaMariaVR2 FDA Global Clampdown: 8 Warning Letters - Failing to Register Plants US Food and Drug Administration (FDA) 0
D Appropriate Statistical Methods to set up an Alert/Warning Limit Quality Assurance and Compliance Software Tools and Solutions 15
M MDR Rules Change Revealed in Warning Letter 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
AnaMariaVR2 FDA issued Warning Letters to Beckman Coulter - 2011 US Food and Drug Administration (FDA) 1
Ajit Basrur FDA issues Warning Letters for misleading advertising of Lap-Band US Food and Drug Administration (FDA) 3
T FMEA Severity 9 &10 - Example of "with warning?" FMEA and Control Plans 6
A FDA Audit Documentation - Recently released FDA Warning Letter Qualification and Validation (including 21 CFR Part 11) 12
AnaMariaVR2 The Top 12 FDA 2011 Warning Letters Report US Food and Drug Administration (FDA) 7
AnaMariaVR2 FDA has issued three Warning Letters... US Food and Drug Administration (FDA) 13
C Cleanroom Class 8 (100,000) Particulate Control and Warning Limits Statistical Analysis Tools, Techniques and SPC 1
AnaMariaVR2 Anulex sees layoffs after FDA warning letter 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
A How long does it take US FDA to issue a Warning Letter Close Out Letter Other US Medical Device Regulations 2
AnaMariaVR2 Cordis CAPA Warning Letter US Food and Drug Administration (FDA) 0
AnaMariaVR2 Shocking Warning Letter - Baxter Healthcare Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 4
AnaMariaVR2 4 API Warning Letters focusing on Laboratory Practices US Food and Drug Administration (FDA) 0
E How to Respond to a US FDA untitled letter - Form 483 or Warning Letter Other US Medical Device Regulations 2
AnaMariaVR2 Warning letter addresses lack of training/education 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 22
F Breakdown and Analysis of FDA Warning Letters US Food and Drug Administration (FDA) 11
Jim Wynne Glass-top Patio Tables Shatter Without Warning Coffee Break and Water Cooler Discussions 14
V Evidence for Preventive Action & Early Warning Vigilance procedure Preventive Action and Continuous Improvement 4
C The warning letter of ONBO - Why FDA require identification of 510(k) ownership? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
L Risk of Bodily Harm - Warning vs. Caution Statements on Medical Device Labeling 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
C 510(k) Issuance & Warning Letter - to spec. developer or contract manufacturer? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
B ISO 14971 DFU IFU Warning Adding Accessory ISO 14971 - Medical Device Risk Management 1
T Wine warning!!! Funny Stuff - Jokes and Humour 3
