Interesting Discussion Was this the fastest ever stage 2 ISO9001:2015 audit?
Big Jim
#62
At the very least it is confusing because of the lack of clarity.
Unless you think it is a good idea to build traps into the standard that will lead users astray. I don't.
#63
"The answer is, all they did was inform me... I had to do the paperwork to correct the spec. What do you want me to do, agree with you?"
It looks like you just did. There was more to it than just informing the customer. A mutually agreeable solution was determined.
You are putting YOUR spin on this to justify your point, which is fruitless. The numbers suggest more see your point of view as incorrect than support it. Apparently you know more about the situation than I do, even though you weren't there, which makes any comments from now on completely futile. My last posting on the topic. Bye.
tony s
Information Seeker
#65
If just "informing the customer" will satisfy 8.7 if an organization provided nonconforming products/services to its customer. Then, using the same logic, if a bank lose a customer savings - the bank only needs to "report this to the customer and retain documented information on what has occurred" and this can already satisfy 8.5.3.:read:
jmech
#67
Thank you. Yes, defending the indefensible 8.7.1c is just as silly as you example.
In the case of nonconformance detection after product has been delivered and consumed, if the customer refuses to grant a retroactive concession, what else should the standard require for dealing with the nonconforming outputs?
Keep in mind that a corrective action to prevent recurrence (as required by 10.2) is not dealing with the nonconforming outputs.
Sidney Vianna
Post Responsibly
#68
The answer is right there in b) product return, also known as recall.
I really don't understand what is so controversial in 8.7 as it applies to the whole product realization cycle from raw material and components incoming all the way through after delivery.
jmech
#69
Product return is not possible if the nonconformance detection occurs after the product has been consumed.
I also do not see the problem with 8.7. It gives the minimum requirements that are always applicable. They make sense.
Big Jim
#70
jmech
I beg to differ with you about the application of 10.2. It certainly DOES NOT exclude nonconforming outputs.
"10.2.1 When a nonconformity occurs, including any arising from complaints, the organization shall . . ."
Perhaps you are trying to dodge 10.2.1a2 "deal with the consequences . . ."
What doesn't make sense is as plane as the nose on your face. To say that "one or more" and then listing something that could never be used by itself doesn't take a rocket scientist to recognize as a problem.
M Are you allowed to reuse the same asset number if the device was replaced? General Measurement Device and Calibration Topics 10
L Significant Production Run - How 300 was determined to be the minimum quantity APQP and PPAP 2
K OEM specific requirements - PPAP was rejected by STA Customer and Company Specific Requirements 5
K %GRR was between 10-30% so we have to have a "backup plan" per auditor IATF 16949 - Automotive Quality Systems Standard 15
I When exactly was "competence" added to the ISO-9001 standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
I "On the job training" as a response to how someone was trained? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 75
T Was Just told we could ONLY buy material for AS9100 customers if the DISTRIBUTION house is AS9100 / AS9120 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
U Own Procedure was not effectively implemented Problem Solving, Root Cause Fault and Failure Analysis 3
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
R Major nonformance finding was given during a closing meeting of a ISO9001 certification audit General Auditing Discussions 76
M Case study - If the restaurant (ISO 9001:2015 certified) was run by 2 persons covering cooking and purchasing processes (Mother and Father) supported ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Ed Panek ISOTECH TTI-10 found out of calibration - Calibration house was wrong? General Measurement Device and Calibration Topics 7
E Audited to ISO 13485 standard although customer was aware we're not and have no plans to be ISO 13485:2016 - Medical Device Quality Management Systems 23
H Claiming equivalence with the product that was sold earlier in the market but not now EU Medical Device Regulations 1
M Products Manufactured while CE was valid CE Marking (Conformité Européene) / CB Scheme 1
S Corrections and Removals - Fiber Content in our textile products was incorrect Other US Medical Device Regulations 1
qualprod Risk closeout , mitigation was not effective, next? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
J AS9100D Clause Brain Fade - Tool was past due for Calibration AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
P Retired equipment that was never validated Qualification and Validation (including 21 CFR Part 11) 2
Jane's What steps do you take to terminate a product which was licensed for sale in Canada Canada Medical Device Regulations 14
Q Change revision number in document when only codification was changed Document Control Systems, Procedures, Forms and Templates 8
Marc Before the 760mph Hyperloop dream, there was the atmospheric railway Coffee Break and Water Cooler Discussions 1
Ninja Getting eaten by Big Business - My company was bought by a huge multinational Coffee Break and Water Cooler Discussions 54
M When was ISO started and Where? Other ISO and International Standards and European Regulations 3
R Why was Drip-Rate Infusion Pump removed from IEC 60601-2-24:2012? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Dinged on Internal Audits for supervising an auditor I was training Internal Auditing 10
Q 21CFR820 as it was in 1993 or 1997? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R 5.4.1 Quality Objectives - Nonconformity: The process was not fully effective ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 36
C CB Accreditaton - CB that was accredited by IAS Registrars and Notified Bodies 5
GStough Rx-360 - Has Anyone Used This and What Was Your Experience? Supplier Quality Assurance and other Supplier Issues 3
R IEC 62304 was brought up during an FDA Inspection/Audit IEC 62304 - Medical Device Software Life Cycle Processes 6
M I was wondering what happened to them (Joke) Funny Stuff - Jokes and Humour 5
U Major Nonconformance - We had a control in place that was not on the control plan IATF 16949 - Automotive Quality Systems Standard 14
J What are the changes in CMDR that was revised in Dec 2013? Canada Medical Device Regulations 2
W The 2nd printing of the AWS D17.1 2010 which was 2011 - Page missing? Various Other Specifications, Standards, and related Requirements 3
T Suppose Aristotle was holding a conference Brain Teasers and Puzzles 10
P ISO 15197:2013 (Blood glucose monitoring system) was released in May Other US Medical Device Regulations 10
B Was EN 980:2008 superseded by EN 15223-1:2012 on January 31, 2013 CE Marking (Conformité Européene) / CB Scheme 2
Q Reduced Device License Fee was rejected for being sent in too early Canada Medical Device Regulations 2
M AS9100A (old revision) - Required C=0 sampling plans if sampling was used? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S The days before International Standards - Has ISO done what it was supposed to? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R Internal Auditing Checklist - Major NCR because the Checklist was not Completed Internal Auditing 17
Richard Regalado ISO 22301 was published 2012 May 15 - New Standard for BCM - Published! Business Continuity & Resiliency Planning (BCRP) 2
Q I was assigned as Kaizen Leader for our MRB Area - Your advice appreciated Quality Tools, Improvement and Analysis 5
R New to MSA - I was told to use ANOVA for the GRR's Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
S Multiple Prints Sent by Customer Over Time as Design was Developed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
V Can't PPAP to Customer because a Supplier was Re-Sourced APQP and PPAP 2
B Which type of DOE was likely used for this transfer function? Six Sigma 4
Wes Bucey One of his habits was to call the World Series the "World Serious" Coffee Break and Water Cooler Discussions 24
chris1price The final version of the RoHS2 recast was published last week as 2011/65/EU RoHS, REACH, ELV, IMDS and Restricted Substances 8
