I found most of the definitions by searching the forum, however I was not able to find 'waste'
What would be the definition of waste?
Other definitions:
Other definitions:
- Repair - Defined as action that makes the object usable but not to drawing specifications. Requires customer approval.
- Rework - Defined as action that returns the object back to drawing specifications. Does not require customer approval.
- Use As Is - Although the item is nonconforming, it can be used because it does not violate the 'Form, Fit and Function 'rule'. May or may not require customer approval. No rework or repair is involved.
- Scrap - The product cannot be Reworked, Repaired or Used As Is.
- Sorting - A sort is an inspection (determination of conformity of specified requirements).
