Calibrationian
Hi all,
A simple question for weighing scale calibration.
We have a standard weights set used to calibrate digital weighing scales.
Just confused with the previous calibration report, in which the used weights as "Nominal Value" was the actual value of the weights from the calibration certificate.
Now here is the scenario:
A certain standard mass weighs 1.00023 grams from the calibration certificate.
After the "Self calibration" of the weighing scale, it measures the standard mass as exactly 1.0000 grams...
Which prompts it to a correction of about -00023 grams...
Should we still put the standard mass of 1.00023 grams for Nominal Value? or simply follow the engravings on the mass that says "1g"?
Thanks...
Thanks...
