Weight Load Testing Methods for Surgical Operating Tables
theGrod
I am looking for weight load testing methods for surgical operating tables. One thing in particular I am looking for is a diagram that shows the out line of a patient on a table and the approximate weights of each section of the person, head, torso, arms, legs and where they are on the table to show how much weight each segment of the table is expected to safely handle. Do any of you have one of these? Thanks
SteveK
Re: Weight Load Testing
I do not know if this of use (a) because it is a European Standard and (b) I do not know what is in the standard with respect to weight testing (if anything), but there is:
EN 60601-2-46:1998 Medical electrical equipment — Part 2-46: Particular requirements for the safety of operating tables IEC 60601-2-46:1998
Steve
Check clause 9.8.3 of 60601-1 ed. 3.
And in the rationale annex A you will find Fig A 19 which is a diagram showing exactly how to distribute the load. The 'standard' patient is 135kg, 40.7% load from the torso etc.
MIREGMGR
...in the rationale annex A you will find Fig A 19 which is a diagram showing exactly how to distribute the load. The 'standard' patient is 135kg, 40.7% load from the torso etc.
This.
We design at times for specified load ratings up to 550kg. In the absence of quantitative guidance, our approach to mass distribution for load ratings greater than 135kg is to proportionately distribute the excess mass among the A19-zones other than the head, hands and lower legs.
Our internal standard also quantifies the lateral dimensionality of the standard mass distribution. We regard that as important in some designs.
We also have internal standards for child/infant devices, and variants on A19 for persons of shorter stature.
Our view is that internal standards to extend A19 are obligatory per 9.8.3.1, unless your company does only plain-vanilla 135kg designs.
MIREGMGR
We, and as far as I know all of our customers, regard 2-46 as obsolete for new designs.
theGrod
What applies to new designs? Not that what we have is new but It would be interesting to know.
MIREGMGR
2-46 was (wildly) inconsistent with the base standard (second edition), and as far as I know was created because fixing the base standard was politically/systematically too difficult, but it was generally recognized that its structural requirements were useless.
2-46 unfortunately wasn't written well enough to be all that much better than the base standard, at least without lots of extension and justification.
The third edition is much improved all around regarding structural issues.
I'm not aware of an intent to issue an updated version of 2-46, given that the base standard does a decent job in the first place, particularly in regard to its direct support for user justification of local extension of its technical breadth.
There is a new version published by IEC:
IEC 60601-2-46:2010 specifies safety requirements for operating tables, whether or not having electrical parts, including transporters, used for the transportation of the table top to or from the base or pedestal of an operating table with detachable table top. This second edition cancels and replaces the first edition published in 1998 and constitutes a technical revision. This edition of IEC 60601-2-46 was revised to align structurally with the 2005 edition of IEC 60601-1.
I don't think it has been 'harmonised' yet.
But I agree that the handling in 60601-1 Ed 3 is pretty good.
It would appear that different versions of the base standard may have different numbering. The test equipment that theGrod found in his section 10 is in my section 9! (figure 33 Human body test mass - used for dynamic loading test). Anyway - the whole section of "Protection against mechanical hazards of ME equipment and ME systems" provides useful info along with the corresponding part of Annex A.
S CQI-23 - Molding System Assessment - Control of part weight IATF 16949 - Automotive Quality Systems Standard 5
M Informational FDA discussion paper – Consideration of Benefit-Risk Approaches for Weight-Loss Devices Medical Device and FDA Regulations and Standards News 0
D Measuring fine tubing (< 0.100") "Wall by weight" General Measurement Device and Calibration Topics 11
Q FDA 3500A Reports - Trip and Fall - Weight scale with a fold out platform Other US Medical Device Regulations 1
P Calculating a weight for a machine for the CE label CE Marking (Conformité Européene) / CB Scheme 0
M Informational US FDA final guidance Characterization of Ultrahigh Molecular Weight Polyethylene (UHMWPE) Used in Orthopedic Devices Medical Device and FDA Regulations and Standards News 0
Y How to fix weight tolerance for plastic injection molded part? Does it vary with material groups? Manufacturing and Related Processes 1
M Perform a coating weight test within 3 hours of processing the parts Manufacturing and Related Processes 2
A IMDS - Changing the Locked Weight Value RoHS, REACH, ELV, IMDS and Restricted Substances 1
N PFMEA Potential Failure Mode for Weight FMEA and Control Plans 5
S Powder Weight Proportion Measurement Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
J Calculating impact force, expressed in lbs, of a 5 lb weight dropped 48 inches Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
A Calibration of Disposable Weight Scales General Measurement Device and Calibration Topics 2
R Weight Sets for Checking Table Balances Quality Assurance and Compliance Software Tools and Solutions 5
T Calculation Question - Calculate the runner weight for a part Manufacturing and Related Processes 2
T Calculating Plating/Coating Weight for IMDS RoHS, REACH, ELV, IMDS and Restricted Substances 3
H FDA Classification of a Body Weight 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
smryan Weight Calibration Standards - External Calibration Frequency General Measurement Device and Calibration Topics 11
C Verifying In House Laboratory Weight Sets General Measurement Device and Calibration Topics 2
K Calibration Standards - Master weight having more tolerance than our gram scale General Measurement Device and Calibration Topics 3
K Weight Calibration to meet the Z17025 Standard ISO 17025 related Discussions 1
F Calibration Reference Standard for Mass Weight Calibration General Measurement Device and Calibration Topics 2
F Injection Molding Weight Control Systems Document Control Systems, Procedures, Forms and Templates 2
P Pressure Corrections and associated MU for Dead Weight Testers Calibration and Metrology Software and Hardware 1
B SPC on Weight of Plastic Injection Molded Parts - What variables affect my process Statistical Analysis Tools, Techniques and SPC 2
J Classes for Hydraulic Calibration - Dead Weight Tester or Automated Controller General Measurement Device and Calibration Topics 1
J Galvanizing and ASTM A90 - Coating Weight Test Compliance Validation Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
I Connection of Secondary Circuits to Medical Weight Scale Enclosure IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Stijloor Best way for girls to lose weight.... Funny Stuff - Jokes and Humour 2
T Required ISO 17025 Traceability - The specific ID/SS number of the test weight ISO 17025 related Discussions 6
V What has more weight: Master Print or Part Submission Warrant? APQP and PPAP 4
S What is the 10d in the owner's manual for a balance's minimum weight? General Measurement Device and Calibration Topics 5
S Selecting weights for daily Calibration Check - Using just one weight? General Measurement Device and Calibration Topics 10
R Timber Harvest Weight - Combining Error between Model & Sample in JPM Design and Development of Products and Processes 2
M GRI (Global Reporting Initiative) En 1 Materials used by Weight or Volume Sustainability, Green Initiatives and Ecology 1
G IMDS (International Material Data System) - Is there a minimum weight? RoHS, REACH, ELV, IMDS and Restricted Substances 17
M Calibrating a Weight Scale in a Laboratory Calibration Frequency (Interval) 4
Randy Loss of gravitational attraction (Weight loss for you PhD's) Coffee Break and Water Cooler Discussions 29
M To Calibrate or Not to Calibrate various Weight Scales ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
K Recording Weight Values on Calibration Certificates General Measurement Device and Calibration Topics 13
Marc Solid Glass Jellyfish Paper Weight - How do they make this? Coffee Break and Water Cooler Discussions 12
S Weight Scale Gage R&R (Gage Repeatability and Reproducibility) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A Process Capability Study using Variables Data (weight of the product) Statistical Analysis Tools, Techniques and SPC 9
F How to determine Minimum Weight of analytical Balance Measurement Uncertainty (MU) 11
O Weighting Problems (Statistics) - Weight distribution for a machine setup Capability, Accuracy and Stability - Processes, Machines, etc. 5
A Plastic Parts Mass - Plastic part weight to be +/- 0.5% from PPAP parts APQP and PPAP 14
V Daily weight checks of floor scales General Measurement Device and Calibration Topics 9
smryan Count by weight statistical analysis Quality Tools, Improvement and Analysis 24
