Weld Penetration on GM 6122M
alexoigres
Does anyone knows what the minimum weld penetration required on this standard?
I have the standard Feb 1994 and I can't find any place in the standard where they mention it
Thank you
Alex
Stijloor
Thank you
Alex
Alex, is it possible for you to contact the welding engineer at your customer's site? I looked around, but could not find the info you were looking for.
Can anyone else with automotive welding expertise help?
Stijloor.
alexoigres
Thank you for all your help... if someone knows anything that it can help me please let me know..... I have asked at some welding engineers and they don't know exactly about it. Some people said normal (regular) welding process is 20% penetration to minimum material thickness. But I know I remember one customer was sending parts to GM at 5% penetration.
Alex
R Weld Penetration Standards and Requirements Manufacturing and Related Processes 2
J Weld Penetration - ANSI/AWS D14.3-94 - Qualifying welding procedures Various Other Specifications, Standards, and related Requirements 8
B CQI-15 Weld Inspector vision reviewed annually Various Other Specifications, Standards, and related Requirements 5
H FCA projection weld nut IATF 16949 - Automotive Quality Systems Standard 0
R Robotic weld cell - maintenance issues - expertise needed Manufacturing and Related Processes 0
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
K Spot weld - Peel test failure Manufacturing and Related Processes 3
E European Weld Callouts - Confused with the "/C" and the "a2" portions Various Other Specifications, Standards, and related Requirements 7
B Weld Validation on Titanium Parts ISO 13485:2016 - Medical Device Quality Management Systems 1
V Tolerance achievable for Sheet Metal Part with some weld - 0.4mm TP Manufacturing and Related Processes 5
V Rust and Paint adhesion with new Weld Nut Supplier Manufacturing and Related Processes 5
R How to Inspect the Weld Strength of High Pressure Vessel & Oil Pipe Line Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
F Welder Recertification to AWS 17.1 Groove Weld AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Weld Stud Length Poka Yoke Nonconformance and Corrective Action 3
5 Visual Weld Inspection Report - Example needed Manufacturing and Related Processes 3
Fender1 Controlling Documents and Records in a Custom Weld/Fabrication Company Document Control Systems, Procedures, Forms and Templates 10
B Laser Weld Strength - Laser Welding Medical Instruments Reliability Analysis - Predictions, Testing and Standards 8
J Weld Current Monitor Calibration Laboratory in North America General Measurement Device and Calibration Topics 6
S Weld Cell Repeatability Studies - Origin - The 'drilled hole panel' Methodology Manufacturing and Related Processes 3
L AWS Certified Weld Inspector (CWI) Requirement Question Manufacturing and Related Processes 16
K Inspecting a Length of Weld - High Reject Rates Manufacturing and Related Processes 7
hogheavenfarm Does anyone know of a calibrated Fillet weld gage? General Measurement Device and Calibration Topics 12
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Laser Weld Operational Qualification ISO 13485:2016 - Medical Device Quality Management Systems 3
C ID (Inside Diameter) Threads Shrinking due to Heat Treatment and Weld Manufacturing and Related Processes 11
I Weld Repair and Nonconformance reporting Nonconformance and Corrective Action 3
Domoreto Spot Welding aust. 304 Stainless Steel - Report on Contrition of Weld Manufacturing and Related Processes 1
L Eliminating a Recurring Problem of Missing Weld Nuts/Fasteners Manufacturing and Related Processes 27
L How to Avoid Missed Welds - Job shop and weld several small quantity jobs Manufacturing and Related Processes 11
bobdoering Determining a Good Variable for Small Scale Weld Integrity Capability Evaluation Capability, Accuracy and Stability - Processes, Machines, etc. 7
P Process vs. Product on Control Plan - Weld a nut attachment on the subassembly FMEA and Control Plans 3
J Pull test standard? Wires coming off the electrodes at the weld ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Visual Weld inspection training Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Spot Weld Current Tester Calibration Supplier needed - 5000 to 20000 A range General Measurement Device and Calibration Topics 2
B Weld Specifications - EU vs. AWS - Are AWS procedures recognized by the EU? Manufacturing and Related Processes 2
M Cost Estimating Spreadsheet for a CNC Machine & Weld Shop Manufacturing and Related Processes 8
A Toyota Weld Specification TSH5603G needed Customer and Company Specific Requirements 6
3 General MIG Weld Workmanship Standard or Procedure Manufacturing and Related Processes 2
F Weld Symbol Interpretation Training Resources - Video and/or overheads, etc. Manufacturing and Related Processes 4
L Weld Nut Thread Quality - Thread chaser for a M8-1.25 internal thread? Manufacturing and Related Processes 3
D Calibration Standard N24: PFM NO 1841 - Ultrasonic Inspection of Resistance Spot Weld Document Control Systems, Procedures, Forms and Templates 1
D Weld Stepper Validation in production weld-cells Preventive Action and Continuous Improvement 6
G Is a Weld Destruct Test Effective - Have any of you ever used this test? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
R Gage R&R for a Destructive Test - Weld Breakout Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Weld Inspection of Assemblies - Agricultural spreaders manufacturer Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
G Destructive Testing MSA - Weld Bond Pull - Both destructive and non destructive Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
W ASTM F1929 dye penetration test - Validation for in-house testing ISO 13485:2016 - Medical Device Quality Management Systems 16
M Medical Device DMR's - List of the Marketing or Market Penetration documents ISO 13485:2016 - Medical Device Quality Management Systems 14
M What Marketing/Market Penetration information should go on the DMR? ISO 13485:2016 - Medical Device Quality Management Systems 4
