Weld Penetration Standards and Requirements
I am trying to find a standard that specify the weld penetration(depth)requirements? So basically my company is automotive supplier and also do a lot of TIG and MIG welding on stainless steel and we basically we use GMW14058 standard but this standard does not talk about how much penetration you have to have and its only talk about leg length and throat thickness on fillet weld. From my past experience, I have seen company submitting vertical & horizontal penetration, throat thickness and leg length data in PPAP for weld validation. So just wondering if anyone knows any other standards for finding what should be the minimum penetration on the weld joint should be? Thank you.
optomist1
A Sea of Statistics
This is a very specialized and sometimes contentious subject...my first instinct is to ask have you discussed this with you OEM SQ rep? Assuming you are a Tier 1, if not then whoever you customer is....the best course of action especially in the Automotive field is open and continuous discussions. Your customer is the best source or at least the first step in establishing what is required/specified. A bit more if your cusotmer is an OEM, they typically have one if not several metal joining experts on staff in the SQ dept and then of course one or more in their materials lab
Hope this helps
A Weld Penetration on GM 6122M Various Other Specifications, Standards, and related Requirements 2
J Weld Penetration - ANSI/AWS D14.3-94 - Qualifying welding procedures Various Other Specifications, Standards, and related Requirements 8
M Weld Symbol--Bubble Drawings for FAI Document Control Systems, Procedures, Forms and Templates 4
B CQI-15 Weld Inspector vision reviewed annually Various Other Specifications, Standards, and related Requirements 5
H FCA projection weld nut IATF 16949 - Automotive Quality Systems Standard 0
R Robotic weld cell - maintenance issues - expertise needed Manufacturing and Related Processes 0
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
K Spot weld - Peel test failure Manufacturing and Related Processes 3
E European Weld Callouts - Confused with the "/C" and the "a2" portions Various Other Specifications, Standards, and related Requirements 7
B Weld Validation on Titanium Parts ISO 13485:2016 - Medical Device Quality Management Systems 1
V Tolerance achievable for Sheet Metal Part with some weld - 0.4mm TP Manufacturing and Related Processes 5
V Rust and Paint adhesion with new Weld Nut Supplier Manufacturing and Related Processes 5
R How to Inspect the Weld Strength of High Pressure Vessel & Oil Pipe Line Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
F Welder Recertification to AWS 17.1 Groove Weld AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
M Weld Stud Length Poka Yoke Nonconformance and Corrective Action 3
5 Visual Weld Inspection Report - Example needed Manufacturing and Related Processes 3
Fender1 Controlling Documents and Records in a Custom Weld/Fabrication Company Document Control Systems, Procedures, Forms and Templates 10
B Laser Weld Strength - Laser Welding Medical Instruments Reliability Analysis - Predictions, Testing and Standards 8
J Weld Current Monitor Calibration Laboratory in North America General Measurement Device and Calibration Topics 6
S Weld Cell Repeatability Studies - Origin - The 'drilled hole panel' Methodology Manufacturing and Related Processes 3
L AWS Certified Weld Inspector (CWI) Requirement Question Manufacturing and Related Processes 16
K Inspecting a Length of Weld - High Reject Rates Manufacturing and Related Processes 7
hogheavenfarm Does anyone know of a calibrated Fillet weld gage? General Measurement Device and Calibration Topics 12
automoto Visual Inspection of a Weld - MSA (Measurement System Analysis) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Laser Weld Operational Qualification ISO 13485:2016 - Medical Device Quality Management Systems 3
C ID (Inside Diameter) Threads Shrinking due to Heat Treatment and Weld Manufacturing and Related Processes 11
I Weld Repair and Nonconformance reporting Nonconformance and Corrective Action 3
Domoreto Spot Welding aust. 304 Stainless Steel - Report on Contrition of Weld Manufacturing and Related Processes 1
L Eliminating a Recurring Problem of Missing Weld Nuts/Fasteners Manufacturing and Related Processes 27
L How to Avoid Missed Welds - Job shop and weld several small quantity jobs Manufacturing and Related Processes 11
bobdoering Determining a Good Variable for Small Scale Weld Integrity Capability Evaluation Capability, Accuracy and Stability - Processes, Machines, etc. 7
P Process vs. Product on Control Plan - Weld a nut attachment on the subassembly FMEA and Control Plans 3
J Pull test standard? Wires coming off the electrodes at the weld ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R Visual Weld inspection training Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
J Spot Weld Current Tester Calibration Supplier needed - 5000 to 20000 A range General Measurement Device and Calibration Topics 2
B Weld Specifications - EU vs. AWS - Are AWS procedures recognized by the EU? Manufacturing and Related Processes 2
M Cost Estimating Spreadsheet for a CNC Machine & Weld Shop Manufacturing and Related Processes 8
A Toyota Weld Specification TSH5603G needed Customer and Company Specific Requirements 6
3 General MIG Weld Workmanship Standard or Procedure Manufacturing and Related Processes 2
F Weld Symbol Interpretation Training Resources - Video and/or overheads, etc. Manufacturing and Related Processes 4
L Weld Nut Thread Quality - Thread chaser for a M8-1.25 internal thread? Manufacturing and Related Processes 3
D Calibration Standard N24: PFM NO 1841 - Ultrasonic Inspection of Resistance Spot Weld Document Control Systems, Procedures, Forms and Templates 1
D Weld Stepper Validation in production weld-cells Preventive Action and Continuous Improvement 6
G Is a Weld Destruct Test Effective - Have any of you ever used this test? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
R Gage R&R for a Destructive Test - Weld Breakout Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
K Weld Inspection of Assemblies - Agricultural spreaders manufacturer Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
G Destructive Testing MSA - Weld Bond Pull - Both destructive and non destructive Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
W ASTM F1929 dye penetration test - Validation for in-house testing ISO 13485:2016 - Medical Device Quality Management Systems 17
M Medical Device DMR's - List of the Marketing or Market Penetration documents ISO 13485:2016 - Medical Device Quality Management Systems 14
M What Marketing/Market Penetration information should go on the DMR? ISO 13485:2016 - Medical Device Quality Management Systems 4
