Welding Process Validation Plan
K
kgott
#12
As welding is considered as special process..so it needs validation such as
1) Welding parameters... temperature, pressure, colling water temp etc.. must be as per defined standards..
2) The operators must be trained and skilled to do the job..
3) The destructive testing must be carried out as per defined frequency/customer rqmnt..
As welding is considered as special process..so it needs validation such as:
4) we have done xyz numbers of these welds to this specification and they are still in service and we have had no negative feedback from customers.
5) in addition to destructive testing we have carried out NDT on a representative number of samples and our acceptance criteria for both destructive and non destructive testing has been met x out of y times. Therefore, the weld specification, the welding procedure specification, welding operator qualification testing and welding machine calibration have demonstrated the welds performed using these specifications are are proven and valid for application the welding is performed for.
E
ewemily
#13
I think, validation plan of welding process may include equipment used for welding, temperature and other technical concerns.
call me Jon
#15
Our company is trying to earn ISO 13485 certification. Along with that we have been introduced to process validation. Our company is a contract manufacturing shop specializing in welding. We do a lot of work for medical device manufacturers as a second or third tier vendor. We frequently get work from machine shops who require welding, mainly laser welding.
We keep running into problems when trying to create a validation plan specifically process performance and qualification. We have installation qualifications and operational qualifications in place. 100% of our work is on customer supplied parts. So getting parts to qualify our process performance is like trying to squeeze water from a rock. The other problem is that we have little to no defined tolerance or quantitative acceptance criteria. Inspections are typically only visual. A few customers require a tensile test or cross sectioning, but this is only about 5% or less. If they do require this, it's only when we initially weld parts. It's not done with any frequency. There are next to zero specs for the weld itself. Rarely is there a penetration requirement or weld size. Rare being <1% of our orders.
Has anyone else had similar issues? What was your explanation regarding process validation to an ISO auditor? What did you do to qualify your processes with no quantitative criteria?
Thanks for the help.
As a medical device supplier, maybe you need to refer GHTF-process validation guidance (maybe you didnot heard of it, please google it)which recommended by the FDA,
MarosJ
#16
Hi Jason !
I´m solving very similar topic ...
Did you solved validation of welding?
I´m preparing validatioon for capacitive discharge welding (basically this is the easiest welding method for validation), TIG, MIG, MAG and spot resistance welding...
#17
Hi Jason !
Jason is no longer active on this forum. Hopefully, someone else will respond to your question.
#20
Your final responsibility is to meet your customers expectations. If they don't give you parameters, then it can be a safe assumption that if the reject/ failure rate is low that the customer is happy.
For ISO sake, you could develop your own parameters. Red line the drawing for weld sizes, develop a WPS for weld machine settings, etc. Get rid of the "tribal knowledge" and document what you do.
Yeah, I think this should be more on the client's side. Are they auditing you? Did they just throw out: ISO 13485 ? You should be providing at a minimum what would be required for commissioning, but if they're requiring you to do process validation they should be setting up shop inside your facility to help you out. Especially with all the design planning, tracking, and requirements.
V Laser Welding Process - Impact on Electrical Properties Reliability Analysis - Predictions, Testing and Standards 4
E What Data do we need for Welding and Repair Process Capability? Six Sigma 1
T First Pass Yield - Welding Process Improvement Manufacturing and Related Processes 3
F Process FMEA for Welding and Laser Cutting FMEA and Control Plans 3
R Specific Special Process requirements in TS 16949 for MIG Welding IATF 16949 - Automotive Quality Systems Standard 1
K Environmental Aspects and Impacts of a Welding Process (ISO 14001) ISO 14001:2015 Specific Discussions 5
R Special Process Checklists for Plating, Phosphate Coating, Welding and NDT AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
F Inspection Companies in China - Rubber and Welding Manufacturing Process Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
R CQI-15 Welding System Assess. & CQI-17 Special Process: Soldering Various Other Specifications, Standards, and related Requirements 6
P TIG Welding NG Mode Matrix for Robo Welding process IATF 16949 - Automotive Quality Systems Standard 1
D Laser Welding PFMEA (Process FMEA) - Metal FMEA and Control Plans 14
M Internal NCR - Welded steel - Fixes during welding process Nonconformance and Corrective Action 6
eternal_atlas Is cable jointing process is a special process like welding? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Process FMEA (PFMEA) for D.C. Welding of Sheet Metal Parts - Electrode Material FMEA and Control Plans 1
Anerol C Welding Process Control Manufacturing and Related Processes 2
M Trouble Shooting for Welding Process Quality Tools, Improvement and Analysis 1
S Welding - Is welding always a special process per ISO9001:2000 Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
K Resistance welding process - Cold rolled and some zinc plated welding Various Other Specifications, Standards, and related Requirements 2
R Spin welding - Is it a special process? QS-9000 - American Automotive Manufacturers Standard 5
R CQI-15 for ultrasonic welding splices on wiring harness, is applicable? Customer and Company Specific Requirements 3
Z CQI-15 Welding System Assessment - Robotic Ultrasonic Foam onto Plastic "Weld" applicable? Various Other Specifications, Standards, and related Requirements 3
B CQI-15 Welding System Assessment - Required for all of the welding processes we have? IATF 16949 - Automotive Quality Systems Standard 2
E Requirements for hand-held laser welding equipment Other ISO and International Standards and European Regulations 0
M Butt welding of 13Cr tubing Manufacturing and Related Processes 0
A Adjusting Calibration Intervals for Welding related Gages AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
P Help with 8.5.1 regarding Welding Procedure Specifications (WPS's) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A AWS (American Welding Society) D17.1 & D17.2 Welding - Looking for help AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
C Practical use of Heat Input calculation for Manual MIG Welding Manufacturing and Related Processes 4
Q Welding filler material verification Manufacturing and Related Processes 4
C ISO9000 and CWF (Certified Welding Fabricator) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
V What document to use to document Welding PV testing - Supplier to Ford APQP and PPAP 1
N Projection welding of nuts on zinc coated surface Manufacturing and Related Processes 3
A Innovation in Laser Welding Manufacturing and Related Processes 2
V Concerning CQI-15 Welding System Assessment Form Document Control Systems, Procedures, Forms and Templates 1
R Please help me with Welding Symbols Manufacturing and Related Processes 5
F New Inspector Welding Test example wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
J Welding - WPS and PQR per AWS D17.1 Questions Various Other Specifications, Standards, and related Requirements 9
S Audit Points for Auditing a Welding Supplier General Auditing Discussions 14
A ISO 9001 company now adding Welding to the Scope - What needs to change? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Laser Weld Strength - Laser Welding Medical Instruments Reliability Analysis - Predictions, Testing and Standards 8
A Pressure Vessel Welding Question Various Other Specifications, Standards, and related Requirements 4
A Resistance Welding Customer Complaints - Cracking and Pitting Root Causes Customer Complaints 4
N CE Mark (CE directives) for Welding Electrodes CE Marking (Conformité Européene) / CB Scheme 5
M Welding Inspection Sampling - How to do? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
C Health and safety within a workshop - welding Occupational Health & Safety Management Standards 7
R Analysis of Welding Parameters - Can Taguchi methods provide equation? Using Minitab Software 11
K Small Welding Shop going for AC7004 (NADCAP) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 15
M Welding - to Validate or Not? If so, How? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Aluminum Castings Defects - Welding and what to Mark with Manufacturing and Related Processes 3
M HSLA100 (High Strength Low Alloy Steel) Welding Procedure and Consumables Manufacturing and Related Processes 3
