What are the current Calibration Standards for Calibration Laboratories
Douglas E. Purdy
#11
Hello Doug! :bigwave:
Ok... I'm a bit confused (which is not hard to do these days...:bonk:) :)
Are you performing calibrations yourself?
Or, are you looking for some type of criteria to hold external calibration vendors to?
(Sorry, not able to open your attachment at this time).
If you're talking about outside providers, Andy is correct. 17025 is a general standard requirement that most providers should comply with.
Then, you can have non-accredited providers, but have some level of evaluation/ scrutiny that you apply to them (traceability, documentation requirements, etc.).
BradM,
I look forward to your response when you are able to review my draft.
I do want to know if a calibration service can be accredited to ANSI Z540-3!?
Thanks!
Doug
#12
BradM,
Thanks!
Doug
Doug. I believe so, but I'm going to check tomorrow. I did a simple Google search and quite a few Z540 results turned up for labs who have, apparently, been accredited by A2LA and AClass to that requirement.
But let me find out from the right person...
Douglas E. Purdy
#13
Not to rush you, but I presume you are still waiting to hear from the right person concerning accreditation to ANSI Z540?
Thanks,
Doug
Wes Bucey
#14
Wes,
Thanks! I was unemployed for 2 years and then under employed for 2 months before accepting a Quality Management position back here in the Chicagoland Area. I am trying to get my bearings as to what has been going on with the system standards for calibration. So any information would be helpful!
Doug
Hershal Brewer is our resident expert on everything to do with 17025 and calibration. He is usually busier than a cat with two mouse holes to watch, but he has always been gracious about answering direct questions in his field.
Call me sometime. Perhaps we can meet for lunch.
Hershal
Metrologist-Auditor
#15
Thanks for the kind words Wes. I down to only two mouse holes? Woo Hoo! Making progress!
Seriously, for a cal lab, there are three documents that you should have, and also for more nuts and bolts things there are others too.
The first three are the VIM, which is the Dictionary of General and Specific Terms in Metrology (title may be slightly different but it is the dictionary). You need the GUM which is Guide to the Expression of Uncertainty in Measurement. That is an ISO document, but the U.S. version is ANSI/NCSL Z540-2-1997. And you need to get ISO/IEC 17025:2005. Whether you seek accreditation or not, operating the lab per that standard makes lab management a bit easier.
ANSI/NCSL Z540.3-2006 is necessary if you are doing work for NASA, but currently is pretty much optional otherwise. Still, not a bad move. Accrediting Bodies (ABs) can include Z540.3 depending on body, but there is almost certainly an extra cost as extra time is required.
To the earlier question about ABs, yes, ABs are evaluated by theMutual Recognition Arrangements (MRAs) to ISO/IEC 17011, and Signatory status can be checked at the MRA websites, including www.ilac.org and www.aplac.org Also remember in the U.S. there are numerous signatory bodies. Some are dedicated like the police forensics one, but there are six that accredit cal labs. Those are: IAS, NVLAP, A2LA, L-A-B, ACLASS, and PJLA. Talk to all six before selecting one to do business with.
Other documents you find of value include The Metrology Handbook, available from ASQ. Also, for the technical aspects of the lab management including guidance on environments and so forth, go to www.ncsli.org and make sure you get the Recommended Practices (RPs). They are developed by the metrology industry to represent best practices.
Hope this helps.
#16
Thanks,
Doug
Here is the reply I got:
"So to answer your question….sort of. People always say they are “accredited” to ANSI z540 as if they would be accredited to ISO 17025. Technically you claim “conformance” and not actually accreditation to z540. It is typical to be assessed against these requirements as an appendage to ISO 17025. Even companies that are audited to z540 tell people that they are accredited but technically speaking it is not true."
S Calibration - Isolated current meter - Measuring patient auxiliary leakage current Calibration and Metrology Software and Hardware 4
Gman2 The current state of our Calibration System General Measurement Device and Calibration Topics 28
R Documented Procedure for the Calibration of Pulse Current Monitors/Tranformers General Measurement Device and Calibration Topics 4
J Weld Current Monitor Calibration Laboratory in North America General Measurement Device and Calibration Topics 6
J Spot Weld Current Tester Calibration Supplier needed - 5000 to 20000 A range General Measurement Device and Calibration Topics 2
O Scale Calibration Frequency - Low Volume - Current Cycle is 6 Months Calibration Frequency (Interval) 6
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
S Forced ServiceNow validation - No change in our current user and functional requirements IT (Information Technology) Service Management 4
W Need for current design or process control FMEA and Control Plans 2
A Earth leakage current test for Permanently installed Large scale MEE IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
E Best way to keep up with pharmaceutical quality knowledge and current affairs Service Industry Specific Topics 1
T Iec 60601 Impedance and current-carrying capability IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
M Informational TGA – Current status of breast implant products in Australia Medical Device and FDA Regulations and Standards News 0
F Proficiency Testing for ISO 17025: AC Current Ranges ISO 17025 related Discussions 1
A Touch current in single fault conditions test and earth leakage current in normal conditions test, are they really different tests? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
T Tests IEC 60601-1 - Grounding Resistance, Leakage Current and Dielectric Rigidity in an automated way IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
Q Raising A CAPA on Current CAPA system US Food and Drug Administration (FDA) 3
A SPC for Eddy Current Testing Statistical Analysis Tools, Techniques and SPC 28
A Adding Remote Site to Current IATF 16949 Certification IATF 16949 - Automotive Quality Systems Standard 2
S Leakage Current test and Dielectric strength for Battery operated ECG device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
M Leakage current measurement with non-frequency-weighted device IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
A QMS - Medical Device - New company under a current one ISO 13485:2016 - Medical Device Quality Management Systems 3
E IEC 60335-1 leakage current measurement Other ISO and International Standards and European Regulations 3
K Questions on Technical File to show it is current EU Medical Device Regulations 5
H IS there any database for list of CE marked Medical devices and there current status EU Medical Device Regulations 8
B Mains fuses and OVER-CURRENT RELEASES IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
P Adding an additional distributor to a current Mexico Medical Device Registration Other Medical Device Regulations World-Wide 0
M IEC 60601-1 and Active Current Protection Requirements IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
M Testing a Low Current (Battery) DC Medical Device Other Medical Device Related Standards 4
D Referencing Standards in Procedures - Current version or actual? Document Control Systems, Procedures, Forms and Templates 6
I Curious if a List of Current Standards Revisions Exsists Other Medical Device Related Standards 3
C Touch Current for Exposed Charging Contacts on Bodyworn Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R Current version of EN62304/A1 IEC 62304 - Medical Device Software Life Cycle Processes 5
A Power Traceability certificate for values for voltage, current and phase General Measurement Device and Calibration Topics 1
Q What constitutes current technical data? Federal Aviation Administration (FAA) Standards and Requirements 2
M Current standard references IEC 60601:1988 instead of current version EU Medical Device Regulations 5
K What are the current ISO/ TS 16949 Semiconductor Manufacturer Requirements IATF 16949 - Automotive Quality Systems Standard 12
G How to cover another manufacturing "site" or warehouse into current ISO 13485 cert ISO 13485:2016 - Medical Device Quality Management Systems 7
P Document references need to be updated to correspond to the current year? Document Control Systems, Procedures, Forms and Templates 5
P Humidity Pre-Conditioning before leakage current and dielectric strength tests IEC 60601 - Medical Electrical Equipment Safety Standards Series 7
R Is EN/IEC 60417 still current? Other Medical Device Related Standards 4
R New Draft Guidance Document for FDA's current thinking on De Novo submission Other US Medical Device Regulations 1
W How can I test the Patient Leakage Current of an Infusion Pump? IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
J Looking for feedback from current/former Intelex users Quality Assurance and Compliance Software Tools and Solutions 4
A Using your current QMS to plan for ISO 9001 2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
A Accuracy Calculation of Leakage Current for an Electrical Safety Analyzer General Measurement Device and Calibration Topics 5
E How do I stay current on Regulatory Affairs? ISO 13485:2016 - Medical Device Quality Management Systems 8
J Exceeding the DC Leakage Current Limit IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
Q Seeking Examples of current ISO/TS 16949 Training Procedures IATF 16949 - Automotive Quality Systems Standard 2
