What are the differences between Medical and Non Medical Grade Adhesives
csterling
I would appreciate any explanation on what are the difference between medical and non medical grade adhesives.
Thanks in advanced.
Ronen E
Problem Solver
Moderator
Re: Loctite as Manufacturing Material use in Medical Device Assemblies
Thanks in advanced.
If you search Elsmar's relevant forums you'll find numerous discussions around the term "medical grade". In short, this is more a marketing term than a regulatory or even a technical one. It is loosely defined and therefore could have lots of different meanings. In general, I'd say it's the minimal starting point for a candidate adhesive evaluation (except in special cases). If an adhesive is NOT tagged by its manufacturer as "medical grade" then it's more likely to miss on some important requirements. This doesn't mean that an adhesive tagged as medical grade automatically qualifies as anything; it just means somewhat better odds. It's always the user's responsibility to verify and prove that all applicable requirements are met in the final product state.
Cheers,
Ronen.
MIREGMGR
I agree with Ronen's comments. A bit more:
Some industrial materials are made with quite unclean processes because if what one is going to do with the material is threadlock some four inch bolts on a steel mill rolling press, biological cleanliness is quite beside the point.
So a medical grade of the same material might have the same nominal formulation, but it's made in a cleanroom environment in pristine, regularly cleaned, validated equipment and the raw materials and process cleanliness are tightly controlled. Obviously if your application may have indirect patient contact or may be associated with a patient-critical aspect of your product, the medical grade would be your choice.
On the other hand, sometimes "medical grade" means they sell you the exact same product as their already-suitable-quality industrial grade, but you get to pay 200% more in return for them using a different label and including a certification sheet. Typically in this case their entire production is done to medical quality standards, but they allocate those production costs only to their medical customers so that their industrial product can remain cost competitive.
And one hears of instances where the product isn't suitable quality, but it's sold in a marked-up "medical grade" version anyway to take advantage of customers that will pay the difference.
It's up to you to end up with a safe and effective product. You can do that by doing your homework to determine what vendor you can trust (for which good reputations over long periods of time in business, certs from them of reputable third party auditing and testing, and contractural promises not to change formulations and processes, can be useful) and paying any markups involved, or by technically understanding the material involved and your use of it, performing your own testing as needed to verify and validate, putting controls in place to assure detection if a material changes between received batches due to a raw materials or process change, and selecting what to buy and use on that basis. Often it's simpler, faster and thus cheaper to work with the well-organized, medical-requirements-aware maker than to do it on your own.
In any case, merely assuming that because a vendor labels a material as "medical grade" it'll be safe and effective in a medical device is an insufficient approach.
Thanks in advanced.
First of all you will not get a non medical grade adhesive. You get adhesive and medical grade adhesive. It helps one to select adhesive for a medical device application based on provided details that gives a fair assurance to the user about meeting bio-compatibility requirements of the finished medical device. Rest of the mechanical properities are to be validated by the user before use. Even the manufacturer perhaps will not reveal more details except terming medical grade and references to the various standards to which the adhesive properties have been tested. Perhaps the word Hypoallergic is mentioned within the technical litrature of such an adhesive which means "to have a decreased tendency to cause allergies; hypo means less, not none."
K What are the differences between the certificates required for home and medical medical equipment? US Food and Drug Administration (FDA) 1
D Differences between (c)GMP for Drugs and Medical Devices Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
R SQA in the medical field - Differences between WinXP Pro and WinXP Home Software Quality Assurance 2
L Differences between IEC 60601-1-2 and IEC TR 60601-4-2 US Food and Drug Administration (FDA) 1
B For professionals from an amateur: What are the differences between some plans and procedures? EU Medical Device Regulations 5
U How to pick between ANSI Z1.4 vs. ISO2859-1 for AQL Inspection? What are the major differences? AQL - Acceptable Quality Level 4
N R&R for Differences between 2 measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
DuncanGibbons Clear differences between ISO 13485 and AS 9100D requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
K Differences between Manufacturing Process Audit & Layered Process Audit Lean in Manufacturing and Service Industries 4
S Differences in CB expectations between the US and Europe Registrars and Notified Bodies 3
M What are the differences between "Process Flowchart form" and "Process Flow Diagram form"? IATF 16949 - Automotive Quality Systems Standard 5
K Differences between EN ISO 11607-1:2009 vs. 2017 Other Medical Device Related Standards 1
M What are the differences between TIR 13004:2013 and TIR 33? Other Medical Device Related Standards 2
H Differences between CQI 15 and CQI 17 IATF 16949 - Automotive Quality Systems Standard 0
A ISO 13485:2003 vs ISO 13485:2016 - What are the differences between the two? ISO 13485:2016 - Medical Device Quality Management Systems 1
C Differences between IATF 16949 and AS9100 IATF 16949 - Automotive Quality Systems Standard 13
T PPAP differences between TS16949 and VDA APQP and PPAP 1
E Differences between IEC 60601-1-11:2015 and 2010 Other US Medical Device Regulations 0
J Differences between a Risk Management Plan vs. Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Y Differences between the Classic 7 QC Tools and New QC Tools Quality Tools, Improvement and Analysis 3
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
L Differences in the requirements between IEC 60601-1 3rd ed. and EN 60601-1:2006 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
Q What are the differences between ISO 13485 vs. AS9100C ISO 13485:2016 - Medical Device Quality Management Systems 3
L AQL ANSI z1.4 & z1.9 - What are the differences between these 2 standards? AQL - Acceptable Quality Level 5
V Differences between ISO 13485 & FDA Requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Differences between Clauses 7.5, 8.2.3 and 8.2.4 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
V Statistics - Designs - Differences between Orthogonality and Confounding Using Minitab Software 5
K Differences between ISO 9001 and API Q1. Other ISO and International Standards and European Regulations 1
M Differences between international and regional standards (EN, AAMI, CSA...) Other Medical Device Related Standards 6
C Control of Records - Differences between Controlled Documents and Controlled Records Records and Data - Quality, Legal and Other Evidence 18
S What are the differences between Traditional 510(k) and a PMA to meet 21 CFR 814.20 ? Other US Medical Device Regulations 3
O Differences between EN 61326-1:2006 and EN 61326-1:2013 CE Marking (Conformité Européene) / CB Scheme 2
K The differences between ISO 9001 vs a QMS (Quality Management System) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Y Differences between Top Management, Management & Organization ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
W Differences between VDA 6.3 and ISO 9001 VDA Standards - Germany's Automotive Standards 2
G Differences between Quality Objectives and Business KPI's ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
P Differences between an NCR and CAR Internal Auditing 35
M Differences between High, Medium, Low Risk Suppliers Supplier Quality Assurance and other Supplier Issues 5
G Differences between Design, Development, and Production Misc. Quality Assurance and Business Systems Related Topics 4
C Differences between ISO 9001:2008 and AS9100 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
S Differences between Conductive vs. Dissipative ESD Flooring Manufacturing and Related Processes 3
D Quality Management Systems - Differences between ISO 13485, 21 CFR Part 820 & ICH Q10 Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
A EN 60601-2-51 - Differences between the 2003 and the 2005 edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
V Differences between Business Process Reengineering (BPR) and Total Quality Management Quality Manager and Management Related Issues 3
V Differences between Quality Tools and Quality Concepts? Quality Tools, Improvement and Analysis 4
G What are the differences between US and EU Pharmacopeias? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 11
N Differences between a Safety Nonconformance and a Quality Nonconformance Nonconformance and Corrective Action 14
F Differences between ISO 9001 and ISO 9004 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
A Defining the differences between Prototype vs. Production Guidelines? Contract Review Process 5
S Differences between the SAE AS9100C and BS EN AS 9100:2009 versions of the standard AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
