What are the differences in plants with and without TS16949 certification ?
Tom W
#11
You can't go wrong with meeting customer expecations. It's really a busniess decision, do you want TS or not. If you have systems in place that are solid and providing the expected results then you are probably right to just sit pat (if the customers are ok with that).
No cert on the wall will ever ensure good quality, your systems and your people will (System + People = Culture). If the culture is high quality strong relationships and high levels of customer service then you will be able to continue and build strong relationships with your customers and gain cusotmer loyalty.
One question though; you said TS is a cost that gives you no benefit. How do you know that? Is it because you are doing automotive work now without it and having it will not get you any more work? Or the added requirements add no value to your organization?
whtan02
#12
Thank you all for the replies, guidance, advice,
How about QS9000? I think QS9000 in this case is about should be similar to TS16949 ( = ISO9001 + core tool + CSR + etc tool). As I remember we also hace tools like Control-plan, FMEA, SPC, etc in QS9000, right? How about then QS9000 vs TS16949 ?
Thank you very much for your time & advice.
#13
QS-9000 is dead and gone. Replaced by ISO/TS 16949 when ISO 9001:2000 changed the game. It is like comparing chalk and cheese. It did include the tools you mentioned because it was a supplier requirement for the (then) "Big 3". Auto makers in the RoW didn't adopt it.
TPMB4
#14
For us it seems that we are not losing any work or missing out on new opportunities due to not having TS. We are not getting pressure to go for TS and as long as that changes it does not make sense from a business point of view at this stage. Our customers have TS and we do a lot of the elements companies with TS would need to do or ask for of their suppliers.
I do think that since we are probably close to the TS level what the extra steps would be and cost. Certification/external auditing costs I guess. Also management costs here to make the last step. Is it worth it? Just not sure what benefit it offers.
My question is whether there are any benefits to quality going for TS if you fulfil ISO 9001:2008 and customer requirements? If you have systems in place that enable you to meet their requirements with good stability of processes and low defect rate (can you ever guarantee zero defects?). I guess the only possible answer is if not having it means customers pass you by.
Tom W
#15
I would agree, if you are not being pushed there, and you have a solid ISO system then there really would not be a point to going for it from a strategic advantage point of view. It sounds like you have a mature system that is used and followed as intended. The quality benefits of TS over ISO are none really; it is just how you set up the processes and how you use them. If your doing that with ISO then you are in good shape.
Very little of any of these standards are about part quality, they are about desk quality mostly. Systems set up to help establish processes that produce the intended results, but also include a lot of requirements for how to react when they fail. So you can have the best systems in the world, but they better include effective problem solving, be cause failure is the only guarantee.
N R&R for Differences between 2 measurements Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
A VDA2 - 6th edition June 2020 | Differences for the previous VDA2 VDA Standards - Germany's Automotive Standards 0
A Coverage and differences: EN 60601-1:2006+A12:2014 Vs AAMI/IEC 60601-1:2005+AMD1:2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S SAE AS13004 vs. SAE J1739 - What are the main differences? FMEA and Control Plans 0
M Differences in post market safety reporting for Combination Product Applicants Medical Device and FDA Regulations and Standards News 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
DuncanGibbons Clear differences between ISO 13485 and AS 9100D requirements ISO 13485:2016 - Medical Device Quality Management Systems 10
K Differences between Manufacturing Process Audit & Layered Process Audit Lean in Manufacturing and Service Industries 4
S Differences in CB expectations between the US and Europe Registrars and Notified Bodies 3
M Authorized Rep (AR), competent authority, NCA and notified body - Differences EU Medical Device Regulations 9
D USFDA vs NRTL/IEC 17025 Differences - Compliance testing lab ISO 17025 related Discussions 0
D USFDA vs NRTL/IEC 17025 Differences - Compliance testing lab US Food and Drug Administration (FDA) 6
P HVAC System vs Air Handling Unit (AHU) - Differences Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 16
M What are the differences between "Process Flowchart form" and "Process Flow Diagram form"? IATF 16949 - Automotive Quality Systems Standard 4
K Differences between EN ISO 11607-1:2009 vs. 2017 Other Medical Device Related Standards 1
M What are the differences between TIR 13004:2013 and TIR 33? Other Medical Device Related Standards 2
I "Method" vs "Process" - Differences Document Control Systems, Procedures, Forms and Templates 33
S The key differences in 510k types - Traditional vs. Abbreviated vs. Special US Food and Drug Administration (FDA) 0
M Differences in CQE, CSTE, CSQA, CQA Professional Certifications and Degrees 3
H Differences between CQI 15 and CQI 17 IATF 16949 - Automotive Quality Systems Standard 0
L GMDN code differences, Manufacturer and Sponsor Other Medical Device Regulations World-Wide 3
F UMDN vs GMDN - What are the differences? EU Medical Device Regulations 1
D AS9100D vs AS9120B differences AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
A ISO 13485:2003 vs ISO 13485:2016 - What are the differences between the two? ISO 13485:2016 - Medical Device Quality Management Systems 1
F EU IVD registrations - CFG or CFS - Differences EU Medical Device Regulations 1
C Differences between IATF 16949 and AS9100 IATF 16949 - Automotive Quality Systems Standard 13
P Differences CSQA vs CQA ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 1
T PPAP differences between TS16949 and VDA APQP and PPAP 1
E Differences between IEC 60601-1-11:2015 and 2010 Other US Medical Device Regulations 0
J Differences between a Risk Management Plan vs. Production Part Approval Process AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Y Differences between the Classic 7 QC Tools and New QC Tools Quality Tools, Improvement and Analysis 3
M Standard work, standardized work instruction & work instruction: What are differences IATF 16949 - Automotive Quality Systems Standard 7
M Barrier Free vs. Wheelchair Accessible - Differences Occupational Health & Safety Management Standards 1
F IEC 60601-1-2: Differences 2007 and 2015 IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
R 510(k) Executive Summary vs 510(k) Summary - Differences 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Differences between IATF 16949:2016 vs ISO/TS 16949:2009 IATF 16949 - Automotive Quality Systems Standard 13
A ISO 13485:2003 vs. ISO 13485:2016 Differences Comparison ISO 13485:2016 - Medical Device Quality Management Systems 4
L Differences in the requirements between IEC 60601-1 3rd ed. and EN 60601-1:2006 IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
V Application and differences of OC Curve and Acceptance Sampling Statistical Analysis Tools, Techniques and SPC 2
Q What are the differences between ISO 13485 vs. AS9100C ISO 13485:2016 - Medical Device Quality Management Systems 3
L AQL ANSI z1.4 & z1.9 - What are the differences between these 2 standards? AQL - Acceptable Quality Level 5
V Differences between ISO 13485 & FDA Requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
J EMI/EMC Test differences for Radiography Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Q Differences between Clauses 7.5, 8.2.3 and 8.2.4 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
V Statistics - Designs - Differences between Orthogonality and Confounding Using Minitab Software 5
K Differences between ISO 9001 and API Q1. Other ISO and International Standards and European Regulations 1
Q RUO (Research Use Only) vs. IVD (In Vitro Diagnostic) - Differences EU Medical Device Regulations 6
M Safe Work Practice vs Safe Work Procedures - Differences Occupational Health & Safety Management Standards 6
M Differences between international and regional standards (EN, AAMI, CSA...) Other Medical Device Related Standards 6
