What are the FAI requirements for an assembly? New to AS9102
mlubbs
I am new to AS9102 and the one thing that I do not understand is this.
I have an assembly part number 12345-6.
It is made up of sub assemblies:
67891-0 and 67891-1
Sub assembly part number 67891-0 is made up of parts:
1, 2, 3, 4, 5, 6, 7, 8, and 9
Sub assembly part number 67891-1 is made up of parts:
11, 12, 13, 14, 15, 16, 17, 18, and 19
If I am reading AS9102 correctly I need to do an FAI for parts:
1, 2, 3, 4, 5, 6, 7, 8, 9, 11, 12, 13, 14, 15, 16, 17, 18, and 19
then an FAI on sub assemblies:
67891-0 and 67891-1
Then on final assembly:
12345-6
Or am I off my rocker??
Thanks for your help
Michael
domingue
Re: New to AS9102
Correct. The only exception is if any of parts 1-19 can be classified as Standard Catalog Hardware as defined in the standard. You don't need to do an FAI for these - they are simply included in your sub-assembly FAI's.
mlubbs
Re: New to AS9102
Thanks for the quick response. Unfortanetly our purchasing manager thinks that I am crazy for thinking this. Have a great weekend!
Michael
Jeff Frost
Re: New to AS9102
Of course you should start by reading AS9102 cover to cover.
Next the FAIR is created based on customer requirements to do so in the contact with you. It is based on their, not your, drawing requirements. If their drawing only reflects the top level assembly then that is as far as you go and you mark AS9102, Form One, Box 13 as “Assembly FAI”. Boxes 15 through 18 are marked N/A.
Now if they show two components that make up the top assembly on their drawing but they do not have drawings for these components you still perform the FAI as a “Assembly FAI” because the only requirement is that the top assembly contains part “A” and part “B” which you verify on AS9102 Form Three per their drawing. Your customer may still try to get this dimensional information on the two sub-component parts but this information is proprietary and you should not disclose it to them
If customer has also issued sub-component drawings for the top level assembly then you will need to complete FAI’s on sub-components and top level as the have specified their requirements which you must verify via the FAI.
J Allen
Re: New to AS9102
Question,
Do the FAIs that are required on detail parts 1,2,3,4,5,6,7,8, etc......, require AS9102 Forms 1,2, or can that information be filled in on the top assembly FAI.
I'm sure that form 3 is a definite requirement.
andygr
You have the correct basic understanding of the FAI required.
The FAI for each part always needs a form 1 the need for the other forms will depend on the actial design data involved for the part.
IF your assemblies are made from nothing more than catalog parts then you would have a form 2 in addition to your from 1 but would not nessarly need a form 3 in my view but as we know "the more paper the better it must be" so you would be better off to send all 3 forms.
P
PaulJSmith
Re: New to AS9102
Agreed.
Next, you should confirm with both the customer's drawing requirements and the contract requirements (which hopefully match) for what is actually required by your customer.
If you are still not clear after that, by all means ask the customer for clarification. With your being new to the game, they will understand. They want you to get it right, too.
M FAI Requirements of Detail and Assembly AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M When is FAI required? AS9100 8.5.1.3 and 8.4.3 requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
A AS9100D FAI requirements needed? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
APHX02 AS9102 FAI Requirements that pertain to a Dimension 'delta' AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
WCHorn AS9102 Paragraph 5.3-5 - Lapse in Production - FAI Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S AS9102 FAI requirements - Inspecting with fixtures, templates AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
C Opposite Parts - Mirror Image FAI Requirements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
D Partial FAI form requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
P What is the acceptable content on FAI form 3? AS9102 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D FAI Reporting of Downstream Requirements Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
S AS9102 Form 1 Item 19 FAI Complete / Not Complete Box - Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
S FAI (First Article Inspection) and Key Characteristics Requirements - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S FAI compliant to AS9102(A) - Quantity - Measurement Range Results Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
I AS9102 lapse in production requirements - Customer FAI request AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
R Service Company dealing with FAI requirements - Small stocklist broker AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
C Definition ATP Requirements (QAT, FAT, OSAT, FAI) - How to Satisfy FAT and OSAT? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
R Requirements of Inspection Documentation in AS9100 - Mini-FAI - 8.2.4.1 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
D Following AS9102 for FAI Requirements - Does EVERY Component Need Its Own FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 40
Q Change the shape of the raw material FAI AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P FAI Ballooning ASME Y14.5 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q Full or Partial FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Partial FAI - AS9102 - One single drawing has 10 part numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M AS9102B Detail Part/Assembly FAI Form 1 box 13; AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
A When there is a 2 year lapse in production, is a full FAI required? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
M AS9102 FAI Report formats - Boxes in form 1, 2, 3 of AS9102 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R AS9100 DELTA FAI - Sub-supplier for plating changed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
B FAI and ANSI Y14.5 Trailing Zeros and Print Tolerances Manufacturing and Related Processes 3
D AS9102 - Assembly FAI for Use As Is or Repaired Parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A AS9102 Delta FAI Require after Rework stock item from stock AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
B AS9102 - Completing Partial FAI's for Baseline Part Numbers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
K First Article Inspection (FAI) - Equipment used - Dimensions vs. Go/No-Go ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
C Is a First Article Inspection (FAI) Procedure required by ISO 13485? ISO 13485:2016 - Medical Device Quality Management Systems 3
B AS9102 FAI & Lower Level Drawings - How should we perform the FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P AS9102 full FAl or a partial FAI after production inactivity period AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M FAI AS9102 - What does a First Article Inspection cover? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
ScottK Statistical basis for 30 pieces for FAI 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
U Whether First Article Inspection Report- FAI is mandatory for regular Human Factors and Ergonomics in Engineering 4
D FAI. Form 2, process or functional test? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
G FAI Objective Evidence AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
O AS9102 FAI report Forms 1-3 Document Control Systems, Procedures, Forms and Templates 6
J FAI per AS9102 affecting Fit, Form, Function AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R AS9100 FAI - First Article Inspection to a prior Customers PO AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
R AS9102 FAI with No Drawings Supplied AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
G FAI (First Article Inspection) Responsibility - QC or Engineering? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K FAI (First Article Inspection) vs PPAP (Production Part Approval Process) APQP and PPAP 15
W Am I allowed to ship parts without FAI approval from the customer? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
G Is it mandatory to record all processes in form 2 of AS9102 FAI report AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
T FAI (First Article Inspection) of Large Assemblies/Tooling after move to new building AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
