What are the specifications required in the preparation of a calibration laboratory?
F
FIRAS_N
Hello everybody ....
this the first thread for mine and i happy to share with u.
few days ago i decided to prepare a laboratory in my company to calibrate and test electronic scales and balances so i bought the iso/iec17025:2005 standard and read it. in the accredtitation stage we need to prepare the lab and implement the standard and quality manual. but i want to ask what is the specifications required and needed to prepare the lab? furthermore, my lab is now without palace, painter, electric sources, windows,etc. if anyone have electronic scales calibration lab can tell/give me links, files, photos for the laboratory, help me in the preparation of the lab, i think that necessary to prepare it with a standard specification.and what is the equipement necessary for the calibration methods for the electronic scales and balances?
sorry if my thread is repititve.
with my best rigards
Firas_N
BradM
Re: What are the specifications required in the preparation of a calibration laborato
Firas,
Welcome to the Cove! We greatly welcome your question.
First, if you have not conducted the search already, this is a very popular question. I am hoping that you have searched the other threads on the Elsmar Cove to ascertain a basic understanding of your query.
Any metrology laboratory will make every effort to minimize undue influences to measurements being made. Saying, temperature and humidity should be tightly controlled. To what extent will depend on what specification you will attempt to follow. You will want a measurement method to assure temp/RH are not unduly influencing your measurements. Other factors like noise, electrical noise, vibration, air handling units, air flow within the lab, and the like are considerations also.
As far as the general items, you will want to consider things like adequate lighting, high purity air and vacuum sources, regulated/isolate power supplies, low voltage supplies, calibration-grade ice machine (if you are doing temperature calibrations) etc. Understanding, every item may not be mandatory, but just some general items.
Analytical balances have many environmental influences, including vibration, temp/RH effects, etc. If you can install granite tables or the like, this can assist in leveling, minimize vibration, and changes due to things being sat on counter-tops, etc.
Depending on what accuracy requirement you have for the balances will determine what class weights you will have to look at. You will want at least two sets, so you can keep them alternating while one is being calibrated.
Are you going to have floor scales? how is the item to be measured going to be placed on the floor scale? Is there adequate room for an external vendor to place weights and all on the floor scales?
Depending on where you are, there are professionals who are good at cleanroom construction/ certification. They can provide much needed assistance.
These are a few things that came to mind. There are some real pros here; they will probably add some valuable information for you.
Hershal
Metrologist-Auditor
Welcome to the Cove.....
I recommend going to
http://www.ncsli.org
They have a Recommended Practice (RP) that tells one how to set up a calibration lab.....it covers almost everything.....
The other thing is your uncertainty budgets.....there are a number of influences to consider for scales and balances that do not apply to anything else.....local acceleration of gravity, essentricity, and bouyancy just to name a few.....
Hope this helps.
Hershal
F
FIRAS_N
hello,
thank you Mr. BradM & Hershal for your reply, it is useful.
but i want to ask about the instruments and the equipments that are necessary for the calibration laboratory of balances and scales for different uses?
if there are certain instruments please tell me about it.
because now i want it to complete the finishing of my lab, unfortunitlly that the legal body i deal have a few experiance about the subject.
if u have photos or list of the instruments, help me.
thank you
with my best regards
Hershal
Metrologist-Auditor
For scales and balances, you will need weights, also sometimes called mass standards. The range that you will need depends on the scope of calibration you intend to offer. If you go to Google and type in mass standards or type in weights you should be presented with numerous suppliers. I recommend finding one that is an accredited supplier and make sure you get the certificate issued under their accreditation.
You mentioned in your first posting that you will need accreditation, and you will need the accredited certificate for the weights for that.
Also, depending on your country (where the lab is), you will need to select your accrediting body, if it is not a Government mandated body. To find the accrediting bodies, go to:
http://www.ilac.org
Hope this helps.
Hershal
Q Standards or Specifications required for Garbage Truck Compressors Various Other Specifications, Standards, and related Requirements 1
J Am I required to have specifications on file of processes done by suppliers? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
J What is required in Product Specifications? ISO 13485:2016 - Medical Device Quality Management Systems 3
R EU-MDR Article 9-common specifications Other ISO and International Standards and European Regulations 2
A Oven Controller Specifications - BAC5621 and AMS2750F AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
R BS EN 12060:1998 - Zinc and zinc alloys Method of sampling Specifications Manufacturing and Related Processes 4
M MDR "Common Specifications" (CS) - If not standards, then what? EU Medical Device Regulations 5
G Engineering Specifications - APQP APQP and PPAP 5
M Measuring Capability of Process with Multiple Specifications Capability, Accuracy and Stability - Processes, Machines, etc. 6
DuncanGibbons OEM specifications such as AIPS spec from Airbus AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
E Packaging Specifications Mercedes-Benz U.S. International IATF 16949 - Automotive Quality Systems Standard 4
C Taking exception to customer requirements or specifications & AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
P Software requirement and design specifications - Medical device contains both hardware and software IEC 62304 - Medical Device Software Life Cycle Processes 2
M Informational EU – Draft Functional specifications for the European Database on Medical Devices (Eudamed) – First release (High(1)) to be audited Medical Device and FDA Regulations and Standards News 0
M Specifications Aerospace - Who is responsible for providing the correct specification(s) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
D Raw Material chemical/Tensile Requirements Specifications (QQ-A-250/4, etc) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
2 ASTM or ISO Specifications on Prints Other US Medical Device Regulations 2
R Control of COTS (Commercial Off The Shelf) Specifications ISO 13485:2016 - Medical Device Quality Management Systems 2
I Procedures from recognized standards or specifications ISO 17025 related Discussions 3
S Test Specifications based on Vehicle Type Various Other Specifications, Standards, and related Requirements 0
P Help with 8.5.1 regarding Welding Procedure Specifications (WPS's) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
A Technical Documentation - Manufacturing Specifications EU Medical Device Regulations 4
Z How to Contractually Agree on Specifications for Raw Material Purchases Supplier Quality Assurance and other Supplier Issues 15
J Change in Lot Release Specifications - Definition of "Substantial Change" EU Medical Device Regulations 14
T ISO 13485 Label Specifications and Artwork Control ISO 13485:2016 - Medical Device Quality Management Systems 3
alonFAI SMT machine specifications and performance meet the requirements for our production Manufacturing and Related Processes 2
N Subscription Service to Raw Material Specifications AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
W Japanese Steel Specifications - A material called HNCM220M Manufacturing and Related Processes 1
A Procedure for Labeling Review and Approval and Specifications Matrix US Food and Drug Administration (FDA) 2
M Design Inputs - Final Medical Device Specifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
Q How to handle customer request for changing specifications 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
O Functional Specifications - Tracability to requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
H Resistance Temperature Detectors (RTD) Manufacturer's Specifications General Measurement Device and Calibration Topics 3
K Thermocouples Hot Junction and Number of Uses Specifications AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K What is included in Raw Material and Component Specifications for Medical Devices? Other Medical Device Related Standards 3
A Are Software Requirements Specifications part of Design Input? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
T How to keep Customer Engineering Specifications & CSRs Up to Date IATF 16949 - Automotive Quality Systems Standard 6
N Control of Documents Scope - Product Specifications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
O Specifications as requirements? Other US Medical Device Regulations 8
W Who in your company writes your policies, procedures, specifications etc. Document Control Systems, Procedures, Forms and Templates 10
M Thread Ring Gauge Specifications General Measurement Device and Calibration Topics 3
U Looking for Bolt Thread Specifications for Delrin & Aluminum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
V Where to get MS501 Chrysler Specifications APQP and PPAP 3
V Evaluation of Paint Specifications including such as GM 9984123 and GM 14671 APQP and PPAP 1
D M6X1 Thread Specifications Manufacturing and Related Processes 7
S ATA (Aerospace Testing Alliance) Specifications 100, 200 and 300 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S Template for Product Specifications for Calcium Salt with the Chemical Composition Food Safety - ISO 22000, HACCP (21 CFR 120) 3
Z Control Plan & FMEA Specifications - Level of Details FMEA and Control Plans 4
D Use of Customer Specifications to calculate Cpk IATF 16949 - Automotive Quality Systems Standard 13
