What are Validation Requirements for Vendor (Supplier) Processes
E
ElmerF
I have a question with regard to the level of validation required from vendors. My understanding of validation is you either 100% inspect or you validate.
With off the shelf items from vendors, they are not likely to supply a validation of their process. Is it sufficient that they provide a COC saying that their product meets their specification. What incoming ispection must be conducted thereafter. Is an AQL depending on criticality sufficient? Typically Z1.4 or Z1.9 as applicable?
What about a component made to our specification? Must we get an IQ, OQ, PQ from the vendor or have them conduct 100% inspection or is an AQL sufficient? Will a COC suffice in place of a validation? If in turn that vendor receives a sub-component from a sub-supplier do they need to do the same (validate or 100% inspect) and are we responsible for ensuring our vendor has completed this or again rely on their certification (COC).
Thanks for the help.
Elmer
somashekar
Re: What are validation requirements for vendor processes
Hi Elmer.
The simple bottom line is that if x process needs a validation for quality assurance, it must be so identified, planned and validated before the run, so that consistency and quality assurance is maintained and traceable.
Nothing can replace validation.
It is for this as one of the understanding that an organization selects a supplier who has implemented a QMS.
COC is meaningful only when the conformance comes from validated process runs.
Ex: Painting
1. Color match to spec comes out from validation but a 100% inspect may do the same, but only after the painting is done and cured.
2. Paint thickness assurance comes out from validation, and can be verified in samples
3. Paint adhesion strength assurance comes out from validation, and can be verified in samples.
Remember that operator qualification is a part of process validation.
E
ElmerF
Thanks Somashekar,
With regard to off the shelf items, for example, suture, what level of assurance do I need from the vendor. It is an ISO 13485 certified vendor and the suture is CE marked. Therefore it will have been validated. However, being an off the shelf item the validation data is not available to customers. As it is being incorporated into another medical device it will be validated but the process can only be validated by the vendor.
I am trying to write a Master validation plan that addresses all critical vendor components. Just wondering how to handle off the shelf components. Is it sufficient to ask for a COC that states it has been validated under ISO 13485? If not what else can be done?
somashekar
Thanks Somashekar,
When you are buying an off the shelf item like a suture in your case, you are selecting this item based on the manufacturers specs after you test and agree that it meets your requirements.
The supplier being ISO 13485 certified is your added criteria providing assurance to your selection.
As a customer you can get (or ask and be provided) the COC for the batch you purchase which shows evidence that the suture has met the manufacturer's own specs that are claimed, and based on which you have decided to buy and use that suture.
Here you are not having any control directly over his process and so you have no scope in this activity. This is purchasing and not outsourced process.
On the other hand, if you draw up specs for a suture, and this manufacturer agrees to make and supply to you, you can (before ordering) chart out your controls for this purchasing activity which is outsourcing and must include validation.
When you buy product off the shelf, you can:
1. Base your acceptance on the supplier's COC +
2. Conduct your own sampling tests to assure the supply meets your requirements +
3. Seek a 3rd party lab to test the product against the supplier's specs
However these are your own inspection and assurance activities and are not any controls over the supplier's off the shelf products.
D 8.5.1.2 Validation and control of special processes requirements for Heat Treat External Processor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S In Field Validation Requirements Other Medical Device Related Standards 1
S Forced ServiceNow validation - No change in our current user and functional requirements IT (Information Technology) Service Management 5
F 21 CFR Part 11 - Implicit requirements - Validation plan for a Software as a Service Other US Medical Device Regulations 1
R FDA Requirements - Printing Equipment Software Validation Qualification and Validation (including 21 CFR Part 11) 1
Ed Panek Verification & Validation requirements - Patch that adheres to skin ISO 13485:2016 - Medical Device Quality Management Systems 2
R CNC Software Validation requirements as per ISO 13485:2016 Other ISO and International Standards and European Regulations 8
N ISO 14644-1 Clean Room Occupancy State Validation Requirements Manufacturing and Related Processes 3
N China's CFDA - Medical Device Validation Requirements China Medical Device Regulations 8
L ISO 17025 Para. 5.4.5 - Method (Calibration Procedure) Validation Requirements ISO 17025 related Discussions 2
R ISO 13485 Validation and CAR Requirements ISO 13485:2016 - Medical Device Quality Management Systems 6
D User Requirements Tracing - Verification and Validation Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S COTS (commercial off-the-shelf) Validation FDA Requirements Software Quality Assurance 4
R Document Management Software : Validation and other requirements Medical Information Technology, Medical Software and Health Informatics 8
A Products for Design Validation - FDA Requirements US Food and Drug Administration (FDA) 3
N Do new requirements always need a validation? IEC 62304 - Medical Device Software Life Cycle Processes 5
C Saboraud's Agar Incubation Temperature and Validation Requirements Other Medical Device and Orthopedic Related Topics 10
K What are the minimum requirements for Process Validation (Software)? ISO 13485:2016 - Medical Device Quality Management Systems 5
R TS 16949 Process Re-Validation Frequency Requirements IATF 16949 - Automotive Quality Systems Standard 3
E How to write requirements for Medical App Validation and Verification IEC 62366 - Medical Device Usability Engineering 7
T "Special Process" Validation Requirements (21 CFR Part 820) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
Z Final Validation Unit Requirements - Annex D of IEC 62366 IEC 62366 - Medical Device Usability Engineering 6
E FDA Requirements for Implantable Medical Device Software Validation ISO 13485:2016 - Medical Device Quality Management Systems 5
I Minimum and Maximum Validation Batch Size Requirements Qualification and Validation (including 21 CFR Part 11) 3
R ISO 13485 Software Validation Requirements - Help needed ISO 13485:2016 - Medical Device Quality Management Systems 4
X EtO Steriliser Software (PACS) Update Validation Requirements Qualification and Validation (including 21 CFR Part 11) 5
I Work Instruction for Validation of Packaging to EN ISO 11607-2 Requirements Document Control Systems, Procedures, Forms and Templates 3
A Eto Sterilisation Re-Validation Requirements Other Medical Device Related Standards 4
A IVD Label Requirements - For Validation Only Other Medical Device Regulations World-Wide 4
P Sterile Packaging Validation Requirements - Accredited Laboratory or not? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R Only Commissioning Software? COTS, GAMP Category 3 Software Validation Requirements IEC 62304 - Medical Device Software Life Cycle Processes 7
F ISO 13485 & FDA Requirements - What kinds of software require validation? ISO 13485:2016 - Medical Device Quality Management Systems 2
L Validation Plan Requirements when moving to a new Plant - Medical Device Industry Qualification and Validation (including 21 CFR Part 11) 19
Q Software Validation - FDA Regulations and Requirements US Food and Drug Administration (FDA) 4
P Sterile Packaging Validation - FDA Requirements for Statistically Valid Tests 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
A Software Validation Requirements for Class I Active Medical Device EU Medical Device Regulations 4
M CCP Validation and Pre-Requisite Program Reassessment Requirements Food Safety - ISO 22000, HACCP (21 CFR 120) 4
B Validation Method Requirements - 21 CFR Part 820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
R CLIA Equipment or Software Validation Requirements Qualification and Validation (including 21 CFR Part 11) 5
R Clean Room Validation Requirements ISO 13485:2016 - Medical Device Quality Management Systems 7
S ISO 17025 Validation Requirements - "calibration using reference standards or..." ISO 17025 related Discussions 5
R Equipment Cleaning Validation Requirements - Medical Device Class II or Class III Other Medical Device and Orthopedic Related Topics 5
V "Value" and "Overhead(s)" of implementation of "CSV - Validation requirements" Qualification and Validation (including 21 CFR Part 11) 1
M Microsoft Sharepoint as Document Control Software - FDA Validation Requirements Document Control Systems, Procedures, Forms and Templates 15
R Swab, Rinse and Visual Cleaning Validation Requirements Qualification and Validation (including 21 CFR Part 11) 5
A Re-Validation criteria and Requirements for Manufacturing equipment on site ISO 13485:2016 - Medical Device Quality Management Systems 8
T Software Validation Requirements Quality Manager and Management Related Issues 4
J 21 CFR 820 - Stability and Validation Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
I GMP Stores qualification/validation plan or protocol - New Store requirements ISO 13485:2016 - Medical Device Quality Management Systems 3
L Understanding FDA requirements for Software Validation Qualification and Validation (including 21 CFR Part 11) 7
