What can be Root Cause Analysis Methodology - Heat Treatment of Carbon-based Products
W
wny4ever
We employ a multiple process system of forming, heat treating, densifying, heat treating, final heat treat (extremely high temperature), and machining for the manufacture of our carbon-based product. In our largest cross-section product, we are experiencing product failure (internal structure). For the slightly smaller cross-section products, with the same process system, there is generally no such problem. The manufacturing process takes about 2 months, with hundreds of process variables, including inherently variable raw materials. The customer application is basically the same among customers, but the severity of their process conditions vary widely.
Using 5 Whys, 8D, fishbone, etc., seems just too simplistic for this complex manufacturing system. We are using DOE to explore continual improvement of our products/processes. We recently have also employed the Shainin Red X process, with seemingly good results at first, but now the results are uncertain.
My question is what advice can be offered as far as what type of methodolgy to use for root cause analysis?
Stijloor
Re: What can be Root Cause Analysis Methodology - Heat Treatment of Carbon-based Prod
My experience with root cause analysis is that folks are trying to bite off too much. Often, the problem experienced is poorly defined; opinions, rather than facts and the scope is poorly defined as well. A possible suggestion is to break the problem up based the various processes that may have contributed to the issue. A process flow diagram can help to "chop up" the problem into manageable pieces.
Stijloor.
Duke Okes
For chemical processes basic RCA (5-whys, etc.) is unlikely to be powerful enough, and Shainin technique are much better suited to discrete manufacturing. DOE is likely to be your best bet, assuming you have a lot of variables, several of which could be interacting.
bhmdave
I would agree that DOE is likely to be the best way to go, and breaking the process into smaller steps can be helpful. I have found that defining the problem is crucial and then using a fishbone diagram to generate potential variables for the DOE works well.
W
wny4ever
We have broken down the root cause analysis into our manufacturing processes, with the first Shainin methodology application resulting in the Red X being a process variable in the forming process (that we consider to be important but not critical). Our scenario is made "tough", by the number of batch processes in the chain, the magnitude of the number of variables, the long processing time, and the variable raw materials.
somashekar
Hi, It would also help if you can describe your input raw material and final products a bit more, and perhaps its typical applications ...
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
T Tactics for Root Cause Analysis Problem Solving, Root Cause Fault and Failure Analysis 4
T Root Cause Failure Analysis - Not following Customer packaging Specification Problem Solving, Root Cause Fault and Failure Analysis 9
I Root Cause Analysis as Training ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
F Struggling with a root cause analysis - Customer Returns - Escape issue Problem Solving, Root Cause Fault and Failure Analysis 15
I Root Cause Analysis when someone simply stops performing a task? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
S Root cause analysis - The system of developing a work instruction is not effective Problem Solving, Root Cause Fault and Failure Analysis 1
I What if your root cause analysis is -- they just didn't do it?" Nonconformance and Corrective Action 3
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
Q Loss of Personnel - Root Cause Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Risk Tools in ISO 31010 - Root Cause Analysis vs. Cause-and-effect Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
E Root Cause Analysis - Is Insufficient Understanding an acceptable Root Cause? General Auditing Discussions 9
W Root Cause Analysis Requirements per TS 16949:2009 Problem Solving, Root Cause Fault and Failure Analysis 8
J Required on-site training on writing deviations & root-cause analysis Training - Internal, External, Online and Distance Learning 3
D Root Cause Analysis done on the wrong observation Problem Solving, Root Cause Fault and Failure Analysis 9
I What's special about your RCAs (Root Cause Analysis)? Problem Solving, Root Cause Fault and Failure Analysis 11
K Quality Manual Problem Root Cause Analysis Nonconformance and Corrective Action 8
E Using Facebook to discuss Root Cause Analysis (8D) ! Nonconformance and Corrective Action 3
F Need advise on Root Cause analysis for printing issue Problem Solving, Root Cause Fault and Failure Analysis 3
P Is it necessary to perform Root Cause Analysis for each failed part? Problem Solving, Root Cause Fault and Failure Analysis 16
B Root Cause Analysis and Corrective Action Program for Inventory Inaccuracies Nonconformance and Corrective Action 8
R Root Cause Analysis of Audit Findings - New Quality Manager Quality Manager and Management Related Issues 20
A Recommend good Root Cause Analysis Training Courses in the UK Training - Internal, External, Online and Distance Learning 8
J Nadcap finding Inadequate Procedure and Inadequate Root Cause Analysis Nonconformance and Corrective Action 4
B Root Cause Analysis for Minor Non-Conformities identified in an Audit Nonconformance and Corrective Action 13
S Root Cause Analysis of Motor Performance Failure Manufacturing and Related Processes 5
R Triggering Root Cause Analysis for Hardware Returns Nonconformance and Corrective Action 3
Fender1 Corrective Action and Root Cause Analysis for a Missing Assembly Part ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
D Root Cause Analysis and "Comprehensive List of Causes" Nonconformance and Corrective Action 4
P Which Root Cause Analysis Method is the most Effective? Quality Tools, Improvement and Analysis 16
K Complex Cause Root Cause Analysis Quality Tools, Improvement and Analysis 3
P Smart or Sexy (CAR) - Poor Root Cause Analysis and Poor Effectiveness Check Nonconformance and Corrective Action 8
Moncia How to do a Root Cause Failure Analysis ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
R Assembling a Cross Functional Root Cause Analysis Team Problem Solving, Root Cause Fault and Failure Analysis 4
T Lollipop Production Line Problems - Defectives and Root Cause Analysis Reliability Analysis - Predictions, Testing and Standards 6
K Do all Customer Complaints require Root Cause Analysis? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K Incident Investigation vs. Root Cause Analysis ? What?s the difference? Customer Complaints 16
Anerol C Root Cause Analysis Coding System Nonconformance and Corrective Action 11
J Root Cause Analysis in a ISO 17025 Testing Laboratory ISO 17025 related Discussions 6
M Root Cause Analysis and Personal Blame ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Noneffective Root Cause Analysis: 6M Fish-Bone Template Problem Solving, Root Cause Fault and Failure Analysis 1
L Root Cause Analysis Training Training - Internal, External, Online and Distance Learning 12
Z Root Cause Failure Analysis for NADCAP AMS2750D Audit Finding help wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Root Cause Analysis & Cause and Effect Diagram Customer Complaints 5
J Root Cause Failure Analysis of a Shipping Error Problem Solving, Root Cause Fault and Failure Analysis 37
S Root Cause Analysis Taxonomy - Categorising the reasons for non-conformances ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
D Do all Non Conformance Reports need a detailed Root Cause Analysis? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
D Root Cause Analysis (Medical Devices) - Management Support Quality Manager and Management Related Issues 14
F Root Cause Analysis Problem Case Study for Exercise? Problem Solving, Root Cause Fault and Failure Analysis 10
