What can I do if I cannot meet PPAP deadline?
Caroline54
Hello everyone,
I was asked to preprare a procedure of what to do in case we can't meet PSW Deadline.
Do you have any clues?
Thank you for your help.
I need this to write this procedure because of a customer audit.
Caroline.
Howard Atkins
Forum Administrator
Hello everyone,
Caroline.
This seems to me to be a pessimistic way of looking at things.
Why does the customer want a procedure?
What is the typical reason why you are not on time? Tooling?
I would want to see effective corrective actions on the last occasion rather than a procedure.
The fact you do not make the date is a non conformance!
Howard
Manix
Get Involved!!!
I am not sure it is a procedure you need, rather a contingency plan, if your existing PPAP procedures fails to deliver PPAP on time. I do agree however with Howard, in that you should not be planning to fail, but rather investigating the causes behind why you have previously failed, and tackling these in a revised procedure.
Back to the original question though, if you need a contingency plan, it should start and end with communication with the customer. Always ensure the customer knows in advance that you will not meet with the deadline, have clear reasons why not, ensure you agree a revised deadline that is realistic and satisfy all of the customers requirements in the interim. Most customers will have an interim submission requirement, if you are not going to make a full submission deadline. I always find it useful to offer them this option on the basis of full approval being obtained upon completion of the required level of PPAP information.
Hope that helps.
D.Scott
Caroline,
I agree with the others. In my system, this would be considered a nonconformity and should be handled the same way any other nonconformity is handled.
You should already have a procedure for corrective action and the auditor should have accepted that instead of saying you need a procedure specifically for missing a PPAP deadline. Your corrective action procedure presumably follows the standard 8D format which includes everything the others have already pointed out (communication, root cause, corrective action, etc.)
Dave
Manix
Get Involved!!!
I would also say get a copy of MS Project and create a template plan of typical APQP activity. Therefore you can plan each activity based on experience and you will see whether you are on schedule or not etc..... No need for a procedure specifically geared to towards failing to meet a deadline.
You can also identify areas that have been delayed in the past and allow extra contingency for these in your timing plan. This approach lets you see all the dependencies on the process and plan the time accordingly. If you customer requires a certain deadline that you feel cannot be met, then you can show them your timing calculations, and if reasonable, the customer could review the deadline.
Improve your APQP planning phase before setting up procedures to fire fight.
supadrai Possible to Submit a 510(k) if you have never, do not and cannot produce the device for which you're submitting the application? US Food and Drug Administration (FDA) 4
I Cannot Export multiple sections from Excel to PDF without losing pagination Excel .xls Spreadsheet Templates and Tools 23
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
BradM Cannot stay logged in Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 16
S Cannot create Rejects for TMV on a medical instrument with an LCD Other Medical Device and Orthopedic Related Topics 10
K What is supposed to happen when a CA cannot be closed out or the root cause... General Auditing Discussions 1
insect warfare Cannot determine what type of medical device this product is.... 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
K Anyone who audits 8.2.2 cannot audit other clauses of the standard? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 31
rob73 If NB's (notified bodies) cannot be trusted how can we? EU Medical Device Regulations 39
C Document Control using Wiki - Cannot Create all Documents as Wiki Pages Document Control Systems, Procedures, Forms and Templates 10
K Corrective Action cannot be completed within the agreed time frame Nonconformance and Corrective Action 7
X Cannot Verify until Customer uses Product - Clause 7.5.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
L Preventive Action should not / cannot be taken when rectifying a problem ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 94
W What can/cannot be placed on packaging/advertising relating to ISO/TS? Registrars and Notified Bodies 1
M 'Searched' virus? Cannot delete folder - HELP please After Work and Weekend Discussion Topics 33
A Changes to QRI (Quick Reference Instruction)? What I can or cannot change ISO 13485:2016 - Medical Device Quality Management Systems 2
T Control Chart on Paper vs. Software where trend cannot be seen (Alarm only) Statistical Analysis Tools, Techniques and SPC 8
J Is it true that the Quality Manual cannot be a Procedure? Quality Management System (QMS) Manuals 13
D New thread ring cannot be threaded onto the truncated part of the master General Measurement Device and Calibration Topics 4
E MSA Manual says the sum of EV,AV,GRR, and PV cannot equal 100%? Why? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Disaster Recovery Plan - I cannot find references to same in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 3
C What is the best practice to label small tools (small pins) which cannot be scribed? General Measurement Device and Calibration Topics 5
A Goals cannot be reached, don't adjust the goals, adjust the action steps Coffee Break and Water Cooler Discussions 8
Casana Auditor changing ISO 9001 AUDIT scope midstream - Cannot exclude all of 7.3 anymore General Auditing Discussions 26
V MINITAB and non-normal unilateral tolerance data - Cannot confirm Ppk values Using Minitab Software 15
M ISO 9001 Clause 7.6 Measuring Devices cannot be excluded!? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 48
R 17025 Calibration Requirements - External calibration service cannot calibrate ISO 17025 related Discussions 4
T Some Suppliers to TS 16949 companies told they cannot register to TS 16949 IATF 16949 - Automotive Quality Systems Standard 4
Casana Distributors cannot convert to TS? IATF 16949 - Automotive Quality Systems Standard 2
L I looking for a book, but cannot remember the name? . . . . HELP! Book, Video, Blog and Web Site Reviews and Recommendations 3
T Scope and Purpose - For some reason cannot seem to write anything - ISO 9001 - 7.2.2 Document Control Systems, Procedures, Forms and Templates 8
M Gage R&R and Capability - Between 10% and 30% and cannot be improved Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
Q Nonconformance vs. Nonconformity - I cannot find major and minor, either! Nonconformance and Corrective Action 36
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Risks of failure to meet intended use ISO 14971 - Medical Device Risk Management 6
B Qualifcations of Staffing Agency Employees to meet job description General Auditing Discussions 6
F What to do when you don't meet the 1:10 ratio Measurement Uncertainty (MU) 3
Sidney Vianna 40 miles per gallon...on an airplane?!?! 65,000 ft altitude....with a propeller? Meet the Celera 500L Coffee Break and Water Cooler Discussions 1
M Informational Team-NB published a press release regarding the capacities of notified bodies to meet the sector needs Medical Device and FDA Regulations and Standards News 0
M Informational MDDI - It’s Time to Meet the Users of Medical Devices Medical Device and FDA Regulations and Standards News 0
W AS9120B - How to meet clause 7 Support that covers 7.1., 7.1.1, 7.1.2, & 7.1.3? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
C Must your reference standard provider be ISO17034 certified to meet your testing lab's ISO 17025 certification requirements? Other ISO and International Standards and European Regulations 2
P REACH - A few of the hundreds components in my product no longer meet requirement REACH and RoHS Conversations 2
Wes Bucey International Manufacturing Technology Show - 10 September 2018 - Chicago (meet up?) Coffee Break and Water Cooler Discussions 6
BradM Where knowledge and industry meet... Coffee Break and Water Cooler Discussions 10
M Is referenced content sufficient to meet record content requirements? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Label Translations - Translation procedure to meet the requirements of MEDDEV 2.5/5 ISO 13485:2016 - Medical Device Quality Management Systems 4
M Forced NOT to meet End Customer Expectations - Corrupt Third World Country ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Finding a Fixture Design Course to meet Customer Requirements General Measurement Device and Calibration Topics 3
B Risk Requirements to meet the explicit Risk Based Approach of ISO 13485:2016 Examples ISO 13485:2016 - Medical Device Quality Management Systems 21
