What Compliance to ISO 9001, 6.2.2 Competence, Awareness and Training Means
F
fallon
Hi all,
I'm looking for clarity to what compliance to 6.2.2 actually means. The standard states in 6.2.2, "The Organization shall a) determine the necessary competence for personnel performing work affecting product quality, b) provide training or take other actions to satisfy these needs, c) evaluate the effectiveness of the actions taken, ...) In performing an ISO audit to Element 6 I asked the QM how he complied with 6.2.2c. His said after initial training, which is documented on an internal training form, no other evaluations are needed. I mentioned in 4.2.4 where it states, "Records shall be established and maintained to provide evidence of conformity to requirements and of the effective operation of the quality management system. Records shall remain legible, readily identifiable and retrievable." My question is should there be records in place documenting some form of evaluation that any training of operators given is a) understood by the trainees and b) being implemented properly by said trainees? Anyone run into this? Thanks for any input.
qusys
Re: Compliance to ISO 9001:2000, 6.2.2 Competence, Awareness and Training
Hi all,
Rather than focusing on the record to meet this "shall", the intent is to have in place a process/activity according to that that the organization evaluates the effectiveness of the actions taken for training. If you want, a document filled shall be also considered a record, but this is not the point.
My question to you is: how did the organization evaluate the effectiveness of the training in all its shapes ( I mean, on the job training, class room training , training with industry,coaching, mentoring and so on).
If the organization set the required competencies, it should have done also to check for the effectiveness.
My experience is that the effectiveness can be assessed by the supervisor/manager of the employee attesting that he/she is able to perfmor his/her job after job evaluation performance.
This is an indirect way, but it could work, as well as the certification of techs/operators after a certain ojt or the results achieved by a manager who was assigned to projects/task.
Clearly it is required formation and training are required for this and if the results are in line or exceed expections, this could be an indirect way to measure the effectiveness of the training.:bigwave:
Rickser
AndyN
Moved On
Hi all,
Fallon: I believe you are in danger of confusing things. Unless you are doing some type of gap evaluation against the ISO requirements, you should be auditing to your own QMS. By phrasing audit questions in "ISO speak" isn't going to get you what you - or the auditee - really need from any audit. Your QMS is supposed to be constructed and the 'touch points' of compliance, to these specific requirements should be clear to someone (the Management Rep, hopefully) Hence, your audit should be of the implementation not 'interpretation'.
Rickser
Andy, you make a point that is so often misconstrued by lots of folks. The standard (AS9100) indicates (and auditors agree) that you write your QMS so that it reflects what your company does and in your company's language. You then perform internal audits to make sure that is the case and that your processes meet the Standard's requirements. I've had auditors tell me that if they see a QMS that is wrtten in "ISO Speak", they are immediately suspicious of it and will almost bet that most employees don't understand the QMS.
Mikishots
Sub-clause (c) closes the loop by asking you to follow-up to see if the training provided addressed the inconsistencies that you identified in sub-clause (a). If a competency gap was identified through something like an annual performance review or simply from observation by a supervisor or manager, then checking whether the gap was addressed after the training took place can be done by subsequent reviews or observations.
We use pre- and post-tests to measure the degree of learning that took place. In addition, the participants fill out an evaluation questionnaire. These are processes that our organization has chosen to use.
For the auditee to state to you that no evaluation takes place after initial training, this raises a red flag.
Big Jim
I'm sure that there are many ways to evaluate the effectiveness of training or other actions to help employees to become competent.
Some companies perform annual employee reviews.
Some follow up training activities by having a manager or supervisor interview the employee and observe his work to determine that recent training was effective. A simple note in the training file provides a record. It can even be a column on a training record form or matrix.
Some use their KPI results, particularly product quality tracking as evidence that people know what they are doing.
I'm sure that there are many more.
Figure out what you are already doing or at least what would be easy to do, and do it.
qusys
Agree with you, Jim.
My response was anly an attempt to share experiences and ideas to the question of the original poster Fallon.
The question of the verification of effectiveness of the training etc.etc. was debating many times in other threads of this forum.
Each organization can meet the clause in whatever way, the importance is that the way is effective to sustain the process/activity .
As we know, the standard does not say "how" to proceed.
Thank for your imput, hope my post, like the others of the Covers, was helpull for Fallon.:bigwave:
Big Jim
I think your post was helpful.
db
I would like to exand on this just a bit. Also consider non-training methods to meet the requirement for competency. If you need someone competent in welding, you could train a welder, or you could hire someone who is already competent. But if you hire them, how do you really know they are competent. I mean no one every embellishes on applications or resumes, do they? Well, just as qusys says, use the same things for hiring, or transfering, or whatever as well.
G Compliance with ISO 9001-2015 for ISO 17025 Accredited Labs? ISO 17025 related Discussions 8
G ISO 9001 Legal Compliance and Legal Register Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B ISO 9001:2015 vs ISO 13485:2016 for MDR Compliance EU Medical Device Regulations 4
J ISO 9001:2015 8.2.3 - Review of Requirements (Clarification on compliance) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
A Action to demonstrate compliance with on clauses 4.1, 4.2 and 6.1 of ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Would compliance with ISO/TS 16949:2009 mean also compliance with ISO 9001:2015? IATF 16949 - Automotive Quality Systems Standard 1
U Compliance with CFR 21 Part 11 vs. ISO 9001 Certification Qualification and Validation (including 21 CFR Part 11) 9
D Customer will not submit Purchase Orders - System for ISO 9001 Compliance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
B What are Guidelines? Compliance to ISO 9001 Clause 4.2.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B ISO 9001 Compliance or Excellence: How is Quality best achieved ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q ISO 13485, ISO 9001 QMS and FDA Requirements - Process vs. Compliance Approach? ISO 13485:2016 - Medical Device Quality Management Systems 4
S Providing Evidence of Compliance to MIL-I-45208A and ISO 9001:2008 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Compliance with ISO 9001 Clause 7.6 Control of Monitoring & Measuring Devices ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Implementation of SAP and compliance to ISO 9001: 2008 Document Control Systems, Procedures, Forms and Templates 7
M Compliance with ISO 9001 Clause 7.1 - Planning of Product Realisation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
S ISO 17025 Compliance within an ISO 9001 Organization ISO 17025 related Discussions 13
J Oil & Gas industry - ISO 9001 Compliance - Rental Tool Company Quality Management System (QMS) Manuals 12
B I want to Decrease Procedures to 6 only - How do I do that? ISO 9001 Compliance Document Control Systems, Procedures, Forms and Templates 12
Marc Combined ISO 9001:2000 ISO 14001:2004 Compliance Audit Form General Auditing Discussions 8
N Document Control - Is this in compliance with ISO 9001:2000? Document Control Systems, Procedures, Forms and Templates 31
O Self Proclamation of ISO 9001 Certification and Compliance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 72
Crusader ISO 9001 Internal Audit Compliance Scoring System Benchmarking 38
J ISO 9001 compliance for Purchase and resale? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
RoxaneB ISO 9001:1994 Certificates of Compliance - Are any registrars extending these? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Supplier Audit Form to Determine Supplier Compliance to ISO 9001 Supplier Quality Assurance and other Supplier Issues 3
Marc Role of ISO 9004:2000 - Not Intended As Guidance For Compliance With ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J Maintaining site specific ISO Compliance/Certification within a non-certified organization & centralized processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Sidney Vianna ISO 37301 - Compliance management systems – Requirements with guidance for use Other ISO and International Standards and European Regulations 3
M Regulatory compliance ISO 14001 ISO 14001:2015 Specific Discussions 5
A Compliance with iso 14155 Other Medical Device Related Standards 1
K Compliance Obligations 6.1.3 of ISO 14001 ISO 14001:2015 Specific Discussions 3
Cats Clause ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
armani Environmental Compliance obligations and risks (ISO 14001:2015 6.1.3) ISO 14001:2015 Specific Discussions 3
G ISO 14001 - 6.1.3 Compliance Obligations ISO 14001:2015 Specific Discussions 1
N Which EN ISO 17664 version compliance to EU MDR? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 3
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
Sidney Vianna Interesting Discussion Legal compliance as part of ISO 45001 accredited certification. Major OSHA penalties in the USA. Occupational Health & Safety Management Standards 15
P Relevance of Offsite backups process compliance and ISO 27001 certification. IEC 27001 - Information Security Management Systems (ISMS) 3
E Compliance to standards (ISO 80369) but the ID is out of specification Other ISO and International Standards and European Regulations 0
E Template of a Management Review Agenda or Report in compliance with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 6
S Saving QMS documents in cloud drive - Compliance with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 3
L Implementation of ISO 27001 as part of the GDPR compliance journey Other Medical Device Related Standards 2
C ISO 13485 certified as precursor to regulatory compliance to 21 CRF Part 820? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
S What records are required to show compliance to ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 1
N ISO 17025 Clause 4.6 Purchasing Services & Supplies (Compliance) ISO 17025 related Discussions 3
M Partial Compliance to an ISO Standard for Medical Device CE Marking EU Medical Device Regulations 13
J Anyone here use Paradigm Sofware to manage compliance with ISO standards Quality Assurance and Compliance Software Tools and Solutions 3
N ISO 20000 Implementation Guide and Compliance Checklist wanted IT (Information Technology) Service Management 2
J Assessing compliance with ISO 13485 Section 6.1 ISO 13485:2016 - Medical Device Quality Management Systems 10
