What condition is your company in, if you score 3.0?
W
William Gr
#11
attached is the audit sheet we use here, It is a little more conveluded than most 5S sheets as we add Safety. Are machines are cicra 1970 and most have no guards to protect the workers or trays to collect the large amount of metal chips we produce.
On the form the auditor answers each questrion yes, no, or not applicable (one sheet covers all areas) Then they total the yes's and no's in each column. Then they add the total yes's and no's together (10 yes + 5 no's =15, NA's are not counted) Then divide the yes's by the total (10/15 = your score for that column ie.. 10/15 = .666) add the column scores for the total area score.
With this method if you answer yes to every question you will have a 1 for the total column score, times 5 columns, you get a total score of 5.
Like I said, I was not very crazy about this sheet.
RoxaneB
#12
William:
If the form works for your organization, great. :agree1:
My concern with it is Yes/No can be somewhat subjective. Do they get 'Yes' if they do it 50% of the time? 75% of the time? 100% of the time? Does the scoring for 'Yes' change from auditor to auditor?
One way to take away some of the subjectivity is to assess each criteria on a scale of 0-4. If everything is perfect, 4 out of 4. If one thing is wrong, 3 out of 4. If two things are wrong, 2 out of 4. You get the idea. Of course, some common sense is required. If you see three empty coffee cups on someone's desk, I'd group them as 1 item...not as 3.
Try doing a search here in the Cove for 5S forms...we've had this discussion before and I don't think we all need to attach our forms here again. Besides, this thread is under the category of 'Lean'. If we're going to resume the 5S discussion on tools and methodology, we should do so in a previously started thread.
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
J Supplier Controlled Shipping (GM CS1) Condition Manufacturing and Related Processes 3
E Normal Condition Hazards in Risk Analysis ISO 14971 - Medical Device Risk Management 3
C Ambient temperature_how we claim storage condition in label? Other Medical Device Related Standards 2
M Which incubation condition should be selected to recover both bacteria and fungus effectively Miscellaneous Environmental Standards and EMS Related Discussions 3
K How to verify the Storage and Transport environmental condition for Medical Device Miscellaneous Environmental Standards and EMS Related Discussions 3
S VW Special status condition IATF 16949 - Automotive Quality Systems Standard 3
G IEC 61010 - Single Fault Condition - Protective Impedance Implementation IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Calibration of a Width Gage Slot with an Attribute Gage - Maximum Width Condition General Measurement Device and Calibration Topics 16
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
E Single Fault Condition Simulation IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
J ISO 13715 Edge Condition Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
C Calibration Certificate "As Found" condition - TS16949 Section 7.6.2 General Measurement Device and Calibration Topics 7
I Run a batch every year to revalidate the validated condition? Qualification and Validation (including 21 CFR Part 11) 4
C Q as the Datum Maximum Material Condition then MINUS 0.020 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Managing Tooling Condition at Suppliers Supplier Quality Assurance and other Supplier Issues 6
G What is the exact meaning of Single Fault condition? EU Medical Device Regulations 4
R Single Fault Condition for Internally Powered Medical Device IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
D As Found Condition - In or out of tolerance? General Measurement Device and Calibration Topics 4
W Supply Voltage Condition for Transformer O/L and S/C (open & short circuit) testing IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
K Maximum Material Condition on Diameter Tolerance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Zero Tolerancing on True Position using MMC (Maximum Material Condition) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
D "As Found" Condition and Calibration Interval Changes Calibration Frequency (Interval) 5
M Common Reasons for Out Of Tolerance condition of DC Calibrator or any reference std General Measurement Device and Calibration Topics 1
R Single Fault Condition - Motor Test IEC 60601 - Medical Electrical Equipment Safety Standards Series 17
R What Standard or method to use to measure Bow condition in M6 Bolts Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
R Is foreseeable misuse considered as single fault condition? IEC 60601 - Medical Electrical Equipment Safety Standards Series 33
G Single Fault Condition for 3-Phase Medical System - IEC 60601 Clause 8.1b IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
C How Long it takes to Condition Pressure Gauge and Test Gauge General Measurement Device and Calibration Topics 4
B CMM Stylus Calibration - Required to record the As Found condition AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
D Process Capability Study which involves MMC (Maximum Material Condition) Capability, Accuracy and Stability - Processes, Machines, etc. 8
G ANSI & ASME regardless of Maximum Material Condition when none is specified Various Other Specifications, Standards, and related Requirements 3
D Herringbone Defect Condition in Rolled Steel Misc. Quality Assurance and Business Systems Related Topics 3
B Analytical Lab Environmental Condition (Temperature & Humidity Control Limit) General Measurement Device and Calibration Topics 5
howste Condition of Item Calibrated - ISO 17025 Clause 5.10.2f - Calibration Certificate ISO 17025 related Discussions 13
L Root Cause Condition / Corrective Action Condition Problem Solving, Root Cause Fault and Failure Analysis 2
Chennaiite Process Capability for a specification with Maximum Material Condition (MMC) Statistical Analysis Tools, Techniques and SPC 4
S Condition of 100% inspection in organization. Capability, Accuracy and Stability - Processes, Machines, etc. 7
A Initial condition for establishing significant environmental aspects Miscellaneous Environmental Standards and EMS Related Discussions 1
J How is everyone else handling Machine Condition Standards? IATF 16949 - Automotive Quality Systems Standard 1
U Tolerancing Tool called 'Material Condition Modifier' created by Staneley Parker Misc. Quality Assurance and Business Systems Related Topics 0
S GD&T Rule 1: Gage size for form check at MMC (maximum material condition)? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
I Considering Mental Condition Related to Ill Health in Risk Assessment Occupational Health & Safety Management Standards 5
C Capability Study Required as a Condition to Adopt a Sampling Plan? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
T Automotive equipment sine wave vibration test condition - BMW requirement? Reliability Analysis - Predictions, Testing and Standards 4
U Nonnormal vs. Normal Operating Condition Aspect for each Environmental Aspect? Miscellaneous Environmental Standards and EMS Related Discussions 4
apestate Advice on maintaining surface plate condition - Starrett crystal pink surface plate Inspection, Prints (Drawings), Testing, Sampling and Related Topics 14
J Condition of Metrics prior to audit IATF 16949 - Automotive Quality Systems Standard 4
R Moving all of our SPC charts to an Electronic System - Software to flag OOC Condition Statistical Analysis Tools, Techniques and SPC 7
